How to check the level and condition of my 2013 Takoma TDR?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ivokunc, Oct 16, 2022.
  1. Dec 14, 2022 at 12:49 PM
    ivokunc
    ivokunc [OP] Active Member
    2013 Tacoma TRD
    I'm reading it right now.
  2. Dec 14, 2022 at 1:23 PM
    ivokunc
    2013 Tacoma TRD
    Ok. I read the instruction. So, what I'm going to do is: Connect the Autel scanner to the vehicle port. Start the truck. Wait until the temperature rich 97-115 F. Go under the truck. Open the overflow plug. If nothing goes out add 0.400 liter of Toyota fluid or until fluid goes out from the overflow plug... All these must be done with the engine running on the idle park.
    Is that correct?
    cryptolime and Dm93 like this.
  3. Dec 14, 2022 at 1:24 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    yes
    Dm93 likes this.
  4. Dec 14, 2022 at 2:30 PM
    ivokunc
    2013 Tacoma TRD
    The fluid went out from the overflow plug. Not a lot just about 10 drops but it definitely went out. Also, the truck is parked on the driveway and there is a small level up where the engine is. But the color is not really red. The truck has 135k mi. I believe that the previous owner didn't change the transmission fluid ever.
    I'm having had this Tacoma for a couple of months already. The truck runs well. The reason to start this check is that the truck has some vibration when accelerating the speed between 35 and 45mph. the vibration then disappears. I had expect much more smooth running and fast acceleration. This 6-cylinder 4-wheel drive.
  5. Dec 14, 2022 at 2:35 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    no, you won't know until you unscrew the fluid check plug while the trans. pan temp. is in the correct range.
    :facepalm:
  6. Dec 14, 2022 at 6:43 PM
    ivokunc
    2013 Tacoma TRD
    Well, is there anybody to help me to understand what is the condition of this transmission fluid level? As I said when the fluid temperature riched 115 degrees I opened the overflow plug with the engine running and there were about 10 drops out of the hole. Do I need to add any fluid? Or this level is ok? Just wondering...
  7. Dec 14, 2022 at 6:46 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Probably should add a bit, it should trickle out of the check hole if it's full. You will always get a few drops when you take the plug out because it accumulates in the tube when the truck is off.
  8. Dec 14, 2022 at 9:03 PM
    ivokunc
    2013 Tacoma TRD
    Thanks, Dm93! Do I need to do a full change of the transmission fluid? It's dark. How do you look at this full fluid replacement of the fluid with a vacuum pump? The local dealership offers this service. Is it safe? The truck has 135k mi.
    Thanks!!
  9. Dec 14, 2022 at 10:46 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If done correctly a full fluid evacuation will not harm the truck.
    Correctly being the key word.
    I’d recommend a pan drop, filter replacement, and refill the fluid.
    Then another drain and fill @175k and each 50k-60k there after.
    A simple drain and fill would ok if the transmission is running fine.
    But I’d prefer the filter be replaced at least every 100k or sooner.
    SR-71A likes this.
  10. Dec 15, 2022 at 5:02 AM
    ivokunc
    2013 Tacoma TRD
    Thanks, ThShooter! I don't have any information about the quality of the work that these guys here are performing. So, I'll go to pan drop and filter replacement. Is the filter visual after the pan is removed?
  11. Dec 15, 2022 at 5:16 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    If you plan on going that route, read this thread here. This describes the work and parts needed to drop the pan and replace the filter/ strainer. Temp check procedure is the exact same after you are done the work.
    https://www.tacomaworld.com/threads...e-2nd-gen-transmission-pan-and-filter.726329/
    It is worth noting your 35-45mph vibrations are probably not caused by the transmission. Personally I would suspect a worn out carrier bearing first.
  12. Dec 15, 2022 at 8:11 AM
    TnShooter
    Deogee
    STOCK
    Yes. It it is visible.
    See the link @SR-71A provoded above.
    BE CAREFUL when reinstalling the filter bolts. It is INCH lbs.
    SR-71A likes this.
  13. Dec 16, 2022 at 8:56 AM
    ivokunc
    2013 Tacoma TRD
    Well, I think it is not the carrier bearing, because when I'm driving on the hiway and move the stick to Neutral the vibration is gone. It appears only with the gas pedal pressed. So, it is trany or engine(my poor opinion)
  14. Dec 17, 2022 at 8:56 AM
    ivokunc
    2013 Tacoma TRD
    Yes, I was wondering. Is it 84 inch/lbs?
  15. Dec 17, 2022 at 11:59 AM
    #35
    TnShooter
    Deogee
    STOCK
    Correct 84 Inch lbs. or 7 ft/lbs.
    Unless you have a good quality 1/4” torque wrench, you might be better of going by hand.
    Cheap(er) quality INCH lbs wrenches are notorious for being inaccurate. Breaking a bolt off, or worse stripping the threads, is not something you want to do inside the transmission.
    Wipe the threads CLEAN of any fluid before reinstalling the bolts.
    Oil/transmission fluid will change to torque value.
  16. Dec 17, 2022 at 7:30 PM
    #36
    ivokunc
    2013 Tacoma TRD
    Well, I used just one cheap wrench. Bought it from China Freight:):)
    Finished all jobs today. Wasn't easy to work under the truck in front of my house...Instead, to clean the filter I bought a kit from Advance Auto Parts - filter, pan gasket, and o-ring for $65. Installed new gasket and new filter. Was able to drain about 4qts. of the old fluid - it was really dark! Refilled with 5qts. Toyota ws. It took me about 4 hrs to do it including the temperature level check. This time the fluid streamed down from the overfill plug, not a lot but not just drops like last time.
    But the vibration remains the same. It looks like the engine is suffering. Wondering if some spark plug is defective. It happens only when I press the gas pedal and accelerate the speed. In the idle position, the engine runs smoothly.
    Is it possible to check that with Autel 806 scanner? I don't have an Owner Manual book for this scanner. Is there anybody with experience with this device?
    Thanks for any help!!
  17. Dec 17, 2022 at 7:36 PM
    #37
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    That could be one of your u joints going. Might want to check them as well for play.
  18. Dec 17, 2022 at 7:37 PM
    #38
    TnShooter
    Deogee
    STOCK
    35 mph seems a bit lower for it to converter related.
    But try driving in 4th, see if the problem is still there.
    These trucks have issues with the torque converter going bad.
  19. Dec 18, 2022 at 6:37 AM
    #39
    ivokunc
    2013 Tacoma TRD
    Do you mean on 4th speed like about 60mph?
    Or, do you have in mind 4 wheel drive position?
  20. Dec 18, 2022 at 10:08 AM
    #40
    TnShooter
    Deogee
    STOCK
    Does it still have a vibration in 4th gear.
    Put the shifter in 4 position.
