How to clean up wool wax application
Discussion in '3rd Gen. Tacomas (2016-2023)' started by specialscale, May 7, 2025.
  1. May 7, 2025 at 10:13 AM
    specialscale
    specialscale [OP] Active Member
    So I've taken my Taco in to a couple different places for maintenance and both have said that the dude who put my wool wax application on went way overboard. What's the best way to clean this crap up?
  2. May 7, 2025 at 10:30 AM
    JonF
    JonF Well-Known Member
    NJ
    22 OR Lunar Rock
    Of course tech's are gonna complain about it, everything they have to touch is going to be covered in a film of goo. I had to wipe down my suspension bits to put some bilsteins on recently but it wasn't that bad. You paid to have it sprayed on, why spend time or money to remove?
  3. May 7, 2025 at 10:36 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I just noted this in another thread. WW just wipes off easily. Hands or parts. I've pulled my trans twice since using WW. Non-issue.
    I tend to use about half of a bottle, which folks say is a lot. But, it's fun. What can I say?
    Hell, I even use Slime in my motorcycle tires and don't mind that when swapping tires.
  4. May 7, 2025 at 10:43 AM
    JonF
    NJ
    22 OR Lunar Rock
    Just spitballing here but... If i had to remove a WW application, i'd go after it with a pressure washer, a foam cannon and an undercarriage sprayer. I'd load up the cannon with simple green pro HD, purple power or other cannon friendly degreaser and foam the hell out of the undercarriage. drive the truck up on ramps to get under it a little easier. Then attach the rolling undercarriage sprayer and rinse the hell out of it. Might take a couple applications to get it clean enough to eat off of though. After that i'd hit it with some ChemX snake oil to give it an hydrophobic coating until you get it wool waxed again.
  5. May 7, 2025 at 10:52 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I used Krown, so I am not familiar with Wool Wax. That said; I would give it time, as I would guess it will degrade. How often is someone really under there working on it? I can't imagine this hinders regular maintenance.
    My buddy is a tech and comments on how he likes working on my truck, because everything is not rusted out, makes working on it much easier. Yeah, if he works on the truck within a week of a fresh application, there are some minor drips, but most is gone within a few days.
  6. May 7, 2025 at 8:20 PM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    Tech bitches it has too much corrosion protection, getting them "messy". Tech bitches the vehicle is rusty, and a pain in the ass to work on. Tech bitches... Get the picture?
    It is your truck not the techs. If they say the applier went overboard, you can guess... They did a good job. Dont worry about what the tech said.
    I hose my vehicles down when new, and hose the high wear areas every fall. I am protecting my investment. Like @tonered stated, even if you get some grime on you, it is lanolin based, so it is like cleaning hand lotion off ones self. It aint that hard. If the tech dont like it, maybe they can learn to code. ;) Ski
    Johnsmyname, barnaby, FRE1809 and 5 others like this.
  7. May 7, 2025 at 9:00 PM
    TACODOC1
    TACODOC1 Well-Known Member
    SoCal
    2024 Tacoma Trailhunter - Bronze Oxide
    Don’t remove any of it. It’s your friend :)
    Chew, usmc2msu, OZ TRD and 2 others like this.
  8. May 7, 2025 at 10:50 PM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    ^This.
    I would not remove only to re-apply...
    Woolwax is sticky for a bit after application. Then it hardens in place. It is not messy at that point...
    usmc2msu likes this.
  9. May 8, 2025 at 4:17 AM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
  10. May 8, 2025 at 8:18 AM
    OZ TRD
    Central Coast CA
    Oh - that's because you are using Fluid Film... Woolwax leaves an invisible protective finish. Much like a clean clear enamel coating . It is amazing. The taco looks like it just came off the assembly line - even better!
    Dust & mud simply slide off leaving a better than factory new looking underside...This is why I much prefer it!
    (The above is a joke and absolutely not true...) :D
    To be clear... I meant that once it is 'cured' or 'dry', it is 'not messy' as far as one could expect while working around the stuff.
    - As in: 'it wont drip copiously on your whiny tech' and it 'won't stick to clothes on casual contact'... that sort of not messy... Wax is messy and hard to wash off - hence its use in this application.
    You are applying a thick goopy wax coating to the underside of the vehicle. - I wonder what your expectations were as to what the end-result should look like after applying such a concoction to a vehicle!
  11. May 8, 2025 at 8:35 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    This is what I was imaging. OP maybe remind them of the alternative (crusty rusted fasteners) or find a shop with actual wrench-benders that don't watch and aspire to be Tik-Tok'ers working at Ferrari dealerships.
    Glenny and skidooboy[QUOTED] like this.
  12. May 8, 2025 at 6:43 PM
    CB350G
    CB350G Trust you inner Hobbes
    Western PA
    2023 SR Access Cab 3.5V6 A/T 4x4 MGM
    WTT: hood for skewp WTT: seats for util pkg
    Where did you have your Wool Wax done? I want to schedule an appointment! :)
    ^^ This. :thumbsup:
    Irons and skidooboy like this.
  13. May 9, 2025 at 5:02 PM
    Glenny
    Glenny Well-Known Member
    Glenn
    penns valley PA.
    2023 LR trail edition
    none I still have a warranty ;-)
    Cb350g you near state college pa?
    I have the gun and a 5 gl bucket of WW
    doublethebass likes this.
  14. May 9, 2025 at 6:16 PM
    CB350G
    Western PA
    Thanks for the offer - I was just ribbing the OP. No such thing as too much protection, especially here in PA.
    I used Krown when I first got my truck, but have since bought my own sprayer.
  15. May 14, 2025 at 4:33 PM
    GawainXR
    GawainXR Well-Known Member
    William
    2020 TRD Off-Road
    DashCam
    dawn detergent and heater pressure washer?
  16. May 14, 2025 at 4:57 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
