How To: Clutch Slave cylinder rebuild
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoMX, Jan 9, 2012.
  1. Jan 9, 2012 at 9:21 PM
    TacoMX
    TacoMX [OP] TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    I posted this in the tech section too...but figured it could be posted here too.
    This is for a 1st gen 2.7 5-speed, but most slave cylinders are pretty much the same so this should work with all of our truck that have a manual transmission.
    My clutch has been acting funny lately, no slipping but the pedal will sometimes lose its pressure and stick to the floor and pre-engage; that usually indicates a bad slave cylinder.
    So after looking for replacements; they run about $45-$80 for aftermarket and re-manufactured...I didn't even want to see how much OEM Toyota was. So me being the cheap SOB and tinkerer I am, I looked for alternatives.
    There are only a few small parts that get replaced, as the unit is just a cylinder with a piston.
    A rebuild kit is only $9-$12. The one I ordered was $12 from advanced autoparts by beck/arnley ; it includes the spring. The one for $9 is from autozone and doesn't include the spring. The beck/arnley kit is also made in Japan, which is nice.
    So we dive in:
    The slave cylinder is located on the drivers side of the tranny (on the 2.7). Its held onto the tranny with two 12mm bolts. And the hardline going into the unit is held on with a 10mm flare-nut fitting.
    The use of a flare nut wrench is advised when removing the hard line fitting, because potential corrosion can make removal of the fitting troublesome if you round off the fitting with an open-ended wrench. But here in FL corrosion isn't a problem and I used an open-ended wrench with no problem.
    It is also advised to bleed all the brake fluid out of the system before you remove the slave cylinder to avoid making a mess.
    The kit:
    Once you have the unit off the truck the first thing you want to do is remove the old dust boot and remove and clean up the push rod because the rod will be re-used.
    Next remove the old piston and spring. Your old one may just fall out depending on how worn it is, or you have to us air to blow it out.
    Old piston in the unit:
    Old (Left) vs. New (right):
    Note how the fins on the seals on the old piston are flattened out compared to the fins on the new ones
    Now you need to clean up the inside of the unit. It took a lot of paper towels and q-tips to clean mine out. Lots of debris and crap in it.
    After cleaning everything up, insert the pushrod into the new dust boot.
    Like so:
    Then after slipping the new spring onto the new piston, insert the new piston into the unit spring first. I read that using caliper grease is recommended to lube the seals, but I didn't have any so I just lubed up the seals with some brake fluid.
    Now is the hardest part...you have to strech the new dust seal over the lip on the unit while fighting against the spring pressure of the piston...and your hands are probably all greasy so it will be a PITA.
    After I got the dust boot on I safety wired the boot on the unit, which probably isn't necessary; but the spool of safety wire was within reaching distance so i did it :D
    Now all you have to do is re-install the unit. The end of the push rod goes in the slot on the arm thats on the tranny. Make sure you snug up the fitting on the hard line. Then all you have to do is bleed the clutch and your done!
    For about $12 and an hours work you can save yourself some decent cash.
    Have fun :cool:
    Running Board Man and 05Taco4x4 like this.
  2. Jan 10, 2012 at 8:44 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Great write up man! Gonna have to do this to my supra soon too :cool:
    Props man.
  3. Jan 10, 2012 at 8:53 AM
    TacoMX
    Jonathan
    Deltona, Florida
    thanks man :cool:
  4. Jan 13, 2012 at 3:24 PM
    TacoMX
    Jonathan
    Deltona, Florida
    I finally got a chance to take it for a spin with the rebuilt slave...what a difference!
    The pedal is nice and firm and the clutch engagement is nice and crisp :thumbsup:
  5. Feb 14, 2012 at 10:54 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    STICKY!!
  6. Feb 14, 2012 at 9:42 PM
    TacoMX
    Jonathan
    Deltona, Florida
    thanks :eek:
  7. Mar 11, 2012 at 3:34 PM
    ak47
    ak47 v.hey its my Avatar avatar.v
    Anthony
    Washington
    stock 2nd owner
    sweet
  8. Apr 27, 2012 at 12:01 PM
    shaniac
    shaniac Well-Known Member
    Charleston, SC
    2014 Double-Cab Tacoma SR5 V6 4x4
    Yeah, I used to rebuild my clutch slave cylinder on my old 1987 Toyota pickup all the time. It seems like mine wouldn't last a year before it would start leaking and a brand new slave cylinder is not cheap... Not sure why I had issues with mine...possibly where it was located and it took a beating :confused:
  9. Apr 27, 2012 at 2:33 PM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    Doing this monday :D
  10. Feb 22, 2013 at 4:15 PM
    Devout
    Devout Well-Known Member
    Seattle
    03 TRD 4X4
    None yet
    Thanks for taking the time to document your repair job.
    Sometimes if the cylinder has corrosion in it, you'll need to run a hone through it;
    I try to keep my fluid fresh by occasionally bleeding my clutch system, just like we do with our brakes.
  11. Feb 22, 2013 at 4:39 PM
    TacoMX
    Jonathan
    Deltona, Florida
    I wish I would have known about having to hone it now...My clutch hydraulics are bleeding off again and engaging close to the floor. I may just buy a slave from autozone
  12. Feb 23, 2013 at 4:53 AM
    Devout
    Seattle
    03 TRD 4X4
    None yet
    I see you're in a humid area. It can be tough keeping moisture out, especially with these damn nylon reservoirs.
    Between bleeds, the turkey baster is your friend for fluid changes. ;)
  13. Oct 28, 2013 at 8:48 AM
    usmctd32
    usmctd32 Member
    Deer Lodge, MT
    99 Tacoma v6 4x4
    Thanks for the post
  14. Jul 10, 2014 at 8:32 AM
    paulr
    paulr New Member
    memphis
    tacoma 4x4
    the seal kit can be installed with the cylinder still in place. Makes and hour job about 5 minutes instead.
  15. Jul 11, 2014 at 5:53 AM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    Yeah brake fluid for a lubricant not a good idea in my mind. Otherwise nice write up.
  16. May 25, 2017 at 12:25 PM
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
  17. May 25, 2017 at 2:50 PM
    quetzal
    Mario
    Long Beach, CA
    What is recommended to lube the seals that ISN'T the "Rubber Grease that Toyota sells? Thanks.
  18. Jun 2, 2017 at 5:52 PM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    what do you think lubes the seals when its assembled ?
    quetzal likes this.
  19. Jun 2, 2017 at 9:43 PM
    quetzal
    Mario
    Long Beach, CA
    I used caliper grease. The single use package from Autozone. It's worked out great so far.
