How To: Constantly powered under-dash switched circuit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nilepoc, Jul 17, 2016.
  1. Jul 17, 2016 at 5:13 PM
    nilepoc
    nilepoc [OP] Active Member
    Craig
    16 TRD OR AC
    TRD rims, spacer leveling
    Hey there, I will consider this to be my introduction to the forum. I purchased my Tacoma 5 days ago and love it. I cannot wait to bolt more crap to it. With that in mind I searched the forum for topics like this one. I found this thread https://www.tacomaworld.com/threads/always-on-12v-power-outlet-mod-3rd-gen.432620/#post-12477343 but did not feel that my soldering skills would be up to par for that job. Additionally it would place my constant power really far from the dash cam. What follows is my solution to the problem of an always on switchable circuit, location and wiring. I hope it is helpful.
    So today I decided to install my dash cam. I like for it to be constantly powered so that it may one day capture the face of anyone messing with my truck while parked.
    First order of business was to find a constantly powered fuse spot under the dash. Luckily there is one open fuse slot and it is constantly powered. It is in the bottom left of the sticker. And is the first slot from the front on the right as you reach under the dash.
    I wanted to also be able to switch this circuit off easily. In my old FJ I had the battery go dead when I was away for a trip to Ecuador. I had forgotten to unplug the dash cam circuit when I left. So this one has a switch in it which will be affixed to the left side of the fuse block. Note the black wire is ground and will be attached to the fuse block mounting nut.
    Toyota was nice enough to put a perfectly sized hole in the ODB bracket. So I put my 12v receptacle in it and secured it with a zip tie. Be sure to insulate your wire really well as there are many sharp corners in this area.
    I then ran the power wire up the A pillar under the weather stripping and headliner to the mirror area. Here is the rexing dash cam in its installed position.
    Here is an upskirt shot of the entire install under the dash.
    And just because here is my new truck.
    Btw while looking under the hood I found this.
    Anyone know what that white wire is on the headlight wire bundle?
    While we are at it. Anyone know what the spare plug in this photo goes to when in use? It is currently just stuffed into a keeper slot in the panel.
    Addendum -----> This is the wiring for a bed light according to this thread. https://www.tacomaworld.com/threads...-cab-cargo-light-switch.436440/#post-12743485
    I hope this helped someone out in the quest to provide power to the many electronics that can be added to the Tacoma.
  2. Jul 17, 2016 at 5:30 PM
    Tectonic
    Tectonic Well-Known Member
    James
    Tucson, AZ
    12 TRD Sport DCSB 4wd
    Bilstein 5100 all around OME 884 Wheelers 1.5" 3 leaf progressive aal 255/75r17 Hankook Dynapro ATM ARE camper shell Hella Sharptones (4)
    Welcome bud! Nice post. Is the white wire a ground? It appears to be bolted up like one
  3. Jul 17, 2016 at 5:32 PM
    nilepoc
    Craig
    16 TRD OR AC
    There is a ground in the photo, but I am referring to the bundle under the black bundle.
    Tectonic[QUOTED] likes this.
  4. Jul 17, 2016 at 5:42 PM
    double dee
    double dee Well-Known Member
    Arizona
    Nice. I plan to add a dash cam in the next couple weeks. Good to know what fuse slot I should use.
    shakerhood and nilepoc[OP] like this.
  5. Jul 17, 2016 at 6:56 PM
    aweddle14
    aweddle14 Well-Known Member
    Anthony
    Phoenix, AZ
    16 Quicksand DCSB SR5
    Nice Writup! Can you share which dash am you are running and how it's worked for you? I'm in AZ and out heat has killed many I've tried...
  6. Jul 17, 2016 at 7:02 PM
    nilepoc
    Craig
    16 TRD OR AC
    I have a Rexing V1
    https://www.amazon.com/Rexing-Dashb...id=1468807163&sr=8-2&keywords=rexing+dash+cam
    So far I have had no problems with it. I live in NM and while we do not have the heat you do, it may be a good one to try. I was previously using it in my FJ.
  7. Jul 17, 2016 at 11:12 PM
    Maximus
    Maximus Well-Known Member
    North Bay
    11 Tacoma TRD OR 4x4
    Icon Suspension with CDCV, SPC Light Racing UCAs, Wheeler's 3 Leaf AAL, Wheeler's Superbumps, sPod SE BAMF Sliders, All-Pro Skids, AFE Drop in filter, Magnaflow Exhaust, RCI Aluminum LCA Skids, BAMF Bed Brackets, 4X Innovations Rear Bumper, FX-R Retrofit Headlights with Philips 4300k, Custom Nestah Edition Firestik AM/FM Antenna, Famous Fab Hood brackets, FrontRunner SlimLine 2 Roof Rack, Mob Town Offroad tailgate reinforcement plate, Ram A pillar mount, Anti-Dark hood lights, Lots of LED lights,
    Nice write up. How visible is the Dash cam from outside the windshield?
  8. Jul 17, 2016 at 11:26 PM
    nilepoc
    Craig
    16 TRD OR AC
    Not that visible. Sorry for the crappy photo. It could be mounted even higher making it less visible. I decided on this position because the screen is fully blocked and will not blind me at night should it light up.
  9. Jul 17, 2016 at 11:44 PM
    Maximus
    North Bay
    Very stealthy. I bought a Rexing v1 on Prime Day for $80. I can't wait to install it.
  10. Jul 17, 2016 at 11:45 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    U.S.A.
    2023 RAV4 XLE Premium
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    I have a GoPro dash cam and have wanted to do this .... thanks for the DIY article.
  11. Jul 18, 2016 at 3:18 AM
    vinkon235
    vinkon235 Well-Known Member
    vince
    steubenville oh
    2016 white tacoma trdor access cab
    opt7 cree series fog lights busman aux relay box viair 450c oba opt7 fluxbeam led headlights
    Nice write up and welcome
  12. Jul 27, 2016 at 11:34 AM
    hopz
    hopz Member
    Alex
    2016 TRD Sport DCLB
    Thanks for the write up! I am planning on getting one of the Rexing v1 too and installing it in the same spot. The only difference is I want it to turn on and off with the truck. I travel a lot so my truck is turned off for long lengths of time.
    Would you happen to know the easiest way to wire it? It will be my first time hard wiring anything in a car/truck.
    Thanks!
  13. Jul 31, 2016 at 3:56 PM
    nilepoc
    Craig
    16 TRD OR AC
    You can use he exact same technique omitting the switch and using the add A circuit in another location. One that is cycled with the ignition. You wilol need to experiment to find one.
  14. Aug 26, 2016 at 10:20 AM
    Wavey88
    Wavey88 Well-Known Member
    Third Gen
    Used the same fuse location as OP for the constant power, too easy.. My setup is the Blackvue DR650 2CH front and rear camera with power magic pro.
    Tectonic likes this.
  15. Dec 13, 2016 at 2:35 PM
    Mr-Paul
    Mr-Paul Well-Known Member
    Paul
    2017 Qucksand Tacoma SR5 4x4 V6 Access-Cab
    Nice project. Thanks for the write-up.
  16. Feb 14, 2017 at 6:10 PM
    hightechcoonass
    hightechcoonass Living the dream
    Ritchie
    land of the swamps LA
    2017 SR5 4x4 super white
    TRD Offroad wheels and decal set.
    Nice find "AM1" fuse constant on. All of my trucks I add a SAE plug power port. Once I have a 12 VDC power plug installed, I use my SAE / USB adapter between my truck, motorcycle, RV, and my boat. I have a few of the sae / usb adapters... the battery tender one is the only one that ALWAYS work with my POS IPHONE.
    Remember... Always wire the positive to the covered probe (insulated from shorting to frame of truck).
    [​IMG] [​IMG]
    also cool as shit....
  17. Feb 23, 2017 at 9:52 AM
    DeanTacoma
    DeanTacoma Member
    2016 Tacoma Off-Road
    Been looking for these. Great Idea!
  18. Aug 30, 2017 at 4:24 AM
    Canadianguy91
    Canadianguy91 Well-Known Member
    Sean
    Halton Hills, Ontario, Canada
    2016 Limited
    Krown undercoating, Protect a plate, blindspot mirrors, Reese stainless steel towing ball, Bakflip MX4 tonneau cover, Tufskinz tailgate letter inserts, Console organiser, Tinted windows, LED interiors, Bed lights, Hood lights, Black Canadian flag decal (@bfeth), Oem bed mat, WeatherTech floor liners, Arctic Claw XSI tires, Recovery Shackle, Ultimate LED turn signals V3 @mesojdm, OEM TRD Off-Road tow hook, Bilstein 5100's with ARB's Old Man Emu 2887 coils, ICON progressive add a leaf, General Grabber ATX tires, Fuel ripper rims, Auxbeam F-16 H11 Led headlights, Borla S-type catback exhaust with black tip, custom powertray, vinyl badge inlays, (@rrentrop), Rear diff breather mod, Redarc trailer break controller https://m.youtube.com/watch?v=qqN7m1pc6AA
    looks good. how did you get your cover for the pannel back on?
  19. Aug 30, 2017 at 6:27 AM
    trdsupreme
    trdsupreme Well-Known Member
    2017 TRD OR DCLB Silver Sky
    it stays off unfortunately.
  20. Sep 26, 2018 at 2:00 PM
    Kpatt9
    Kpatt9 Well-Known Member
    Kade
    SLC, UT
    2013 DCSB
    Reviving an old thread but how long do you think you can go without starting the truck before you start to hurt the battery... 4/6 hrs?
