How-To: Custom Flush-Mount TRD Center Caps
Discussion in 'Wheels & Tires' started by BeePee, May 17, 2013.
  1. May 17, 2013 at 7:02 PM
    BeePee
    BeePee [OP] Well-Known Member
    Cody
    CA
    09 DCSB TRD Sport Pyrite Mica
    6" ProComp. Icon Coilovers. Alcan Leafs. Bronze BFDs. TRD Caps. BORA Spacers. Toyo. Magnaflow. Debadge. Viper. WeatherTech.
    There was interest in another thread about the custom centercaps I recently put together, so here is a quick "how-to" on my build process.
    I liked the look of the TRD snap in center caps. Unfortunately they were too small for my wheels. A little trial-and-error, some cutting and epoxy, and I've got a nice push-through cap that sits perfectly flush with the face of my wheel. Here's a look at the finished product:
    *Disclaimer! This is the process that worked for me, and my particular wheels. Being that wheels come in all different shapes, sizes, and center bores this might not work for you. If interested in attempting it, take some measurements beforehand. Also, being flushmount caps, they may not clear 4x4 hubs unless you are running spacers. That said, I encourage you to use this as a starting point and to modify the steps involved as needed. Though I can't guarantee your results haha...*
    Anyways, lets get started!
    Parts list:
    - Center caps for your wheels
    - TRD FJ SE wheel center caps (part# PTR18-35092)
    - 5 Minute Epoxy
    - MD V-flex Weatherstrip 1/16 x 3/8
    - Dremel w/ cutoff wheel
    - Masking tape
    - Washable marker
    - Razor blade
    - Rattle can primer
    - Rattle can clear coat/sealer
    Most of the stuff I already had in the garage. TRD caps were about $50 shipped. Epoxy and weatherstripping were another $15 or so.
    Step 1:
    Put a piece of tape around your existing center cap so you can mark where you're going to cut. Push the cap through your wheel, while holding it in place use a WASHABLE marker (don't use permanent for obvious reasons) to make a line around the entire cap. After this I used a regular black pen to make the edge of the line more visible. I then used a razor blade to cut the tape along this line...
    Step 2:
    With a crisp tape line on all 4 caps, it's time to cut. Using a vice and some scrap wood to hold the cap secure, a Dremel with metal cut off wheel worked well to make the cuts. I had to rotate the caps in the vice 3-4 times to cut all the way around, but it was still a pretty quick task. After cutting they will have rough edges, use a file to smooth them out and level any high spots. Then comes a quick hit with the primer to cover up any bare metal.
    Step 3:
    With the old caps cut to size, it's time to make the TRD caps fit inside. I used the thin weatherstripping around the perimeter of the TRD caps to get a snug fit. The weatherstripping has an adhesive side, use this to secure it to the TRD cap, a rubber band helps temporary hold it in place while you work on the others. Carefully push the TRD cap into the cut cap from the back side, it should fit snug. Work it into place so all the edges line up flush. Now is a good time to test fit your caps into your wheel so you can make any adjustments before gluing.
    Step 4:
    Doing one cap at a time, mix your 5 minute epoxy and apply liberally across the inside of the assembled cap. Make sure you have all the seams, and all the contact points completely covered in epoxy. You really can't over do it in this step. The epoxy is basically what holds everything together, so just keep that in mind. Let it dry.
    Step 5:
    Once the epoxy on the back dries, flip it over. There is a small gap between the two caps on the front side. This needs to be sealed up. If you have a steady hand with the epoxy, use that. I used some superglue with a fine tip so I could be very precise. It worked well and, the gap seemed to suck the glue right in. *Note: The face of the TRD caps somewhat reacted with the fumes from the superglue, at least I'm guessing. They became a little cloudy, but it came right off with some rubbing compound.
    Step 6:
    After everything is dry go ahead and spray it with a few coats of clear/sealer. Just for some added protection and weatherproofing. After it dries, and you're happy with the results, you are done!
    Here are some finished product pics:
    Again, this is the process that worked for me. After looking for custom center caps I came up empty, so decided to take a chance at making my own. I'm happy how they turned out! Everything fits perfect, my only concern is durability. I'm not sure how well they will hold up to the elements, but that remains to be seen.
    As for the specifics on my setup... The wheels are 18x9 FN Wheels BFDs, the black center caps are what they come with. I have a 4x4 but will be running wheel spacers so the flush-mount caps will clear just fine. Once I have my tires mounted I will update with final pictures of the caps/wheels installed on my truck.
    Lastly, as stated above, this might not work for your particular setup and wheels, but I hope it will at least inspire you to try something similar! :D
    I'll try to answer any questions the best I can.
    Cody
    Scotfree, JdMeF9SiR2, Fast1 and 12 others like this.
  2. May 17, 2013 at 7:03 PM
    BeePee
    Cody
    CA
    Installed.
    JdMeF9SiR2, BT17, Bagman and 14 others like this.
  3. May 17, 2013 at 7:05 PM
    AlphaEcho2k5
    AlphaEcho2k5 Well-Known Member
    Adam
    Hurlburt Field, FL
    '02 4Runner
    That looks great, nice job and thanks for sharing.
  4. May 17, 2013 at 7:08 PM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    nice job. Looks great
  5. May 17, 2013 at 7:58 PM
    Kavik
    Kavik Kavik
    Texas, DFW
    Not your everday 5 lug
    Lowered: 3 inch drop blocks (Beefed Taco),Satoshi Grill, Morimoto bi-xenon H1 Retrofitted headlights, Flowmaster exhaust, Blue LED interior and exterior, blue LED dome light, Anzo black LED taillights, Hifonics Brutus 1100w Mono Block, Bazooka 300w Amp, LED license plate lights. Lifited: Fat Bob's rear shocks, Fat Bob's 3" spacer and rear AAL, Nitto Terragrapplers, weldertaco wrap around rear tube bumper, TrailWorx Fab tube front bumper
    Awesome center cap!
  6. May 17, 2013 at 8:43 PM
    Xer0 SiN
    Xer0 SiN Well-Known Member
    Hilo, HI
    19 TRD SPORT TACOMA / 21 LIMITED RAV4
    this and that...
    wow. that looks out-fucking-standing!
    D.A.S. Taco likes this.
  7. May 17, 2013 at 9:02 PM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    Those are some nice looking wheels
  8. May 17, 2013 at 10:32 PM
    D1EHARD
    D1EHARD Got the Fever
    Bama
    2017 DCSB Silver TRD Offroad
    Very very nice. I commented just the other day about how nobody ever uses center caps with those wheels. Looks factory.
  9. May 17, 2013 at 10:37 PM
    05Aztacoma
    05Aztacoma Well-Known Member
    05 Tacoma 4x4
    Those look great!!!
  10. May 17, 2013 at 10:49 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Sick!! Might want to do this for my new rims
    Definitely subd
  11. May 18, 2013 at 9:12 AM
    Jeffsdeere
    Jeffsdeere Well-Known Member
    Jeff
    07 Tacoma DC4wd
    BAMF Sliders All Pro Rear Bumper 5100's @.85
    Looks good
  12. May 18, 2013 at 9:20 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  13. May 18, 2013 at 11:19 AM
    SalmonTaco
    SalmonTaco Well-Known Member
    Andrew
    Naches
    08 Silver TRD Sport
    Brute Force bumpers, TRD FauxLocks, 5100s & 885s, Falken Wildpeaks, SnugTop MVP Shell, Tuffy Bed Box, Console Vault, Fogs anytime, ImMrYo mirror bracket, Wet Okoles, aFe Pro Dry S, PowerStop Z36 pads & drilled/slotted rotors, more shit I can't remember
    Nice work. That is one clean looking setup. :thumbsup:
  14. May 19, 2013 at 11:12 AM
    lawless
    lawless the rent is too damn high
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    nice job, i'll be looking back on this thread later. i'm interested in the same wheels but need to make a few more truck payments first.
  15. May 19, 2013 at 11:28 AM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    that's awesome!
    good job Bee
  16. May 20, 2013 at 3:36 AM
    Plik
    Plik Ragin Cajun
    Houston
    '11 DCSB PreRunner TRD Sport
    Click my sig pic for build thread
    nice job OP... best looking center cap for these rims I've seen.
  17. May 20, 2013 at 11:38 AM
    BeePee
    Cody
    CA
    Thanks everyone! Hope this opens the doors for more people to try making their own caps.
    The F-sport caps look nice, what wheel are you going to put them on? Not sure about the rings, it might be difficult to get the exact size you need. I ended up buying multiple materials at Lowes, it just turned out the weatherstripping fit the best. They have a ton of different sizes, options and materials, I'd recommend just browsing your local hardware store if you need to improvise.
  18. May 21, 2013 at 7:14 PM
    Robo02cop
    Robo02cop Well-Known Member
    Island of Nunya
    2012 MGM DCSB SPORT
    TRD Intake, Avic D3 DVD Player, Toyota Bed Extender, & Tinted Windows.
    Nice BeePee!!! I was looking at those center caps when I bought my 12 and was wondering how I could make them fit in my Countersteer Offroads!!! Now u have solved that mystery for me!!! This project will be happening ASAP!!
  19. May 21, 2013 at 9:28 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    I colormatched my center caps. Pics in my gallery ;)
    Good job OP. I was thinking about machining some flush center caps at work, but your way looks good.
    ashlyw77 likes this.
  20. May 23, 2013 at 12:04 PM
    BeePee
    Cody
    CA
    Pics when you're done! :cool:
