How to cycle suspension to check for clearance?
Discussion in 'Long Travel Suspension' started by tacomio877, Jun 13, 2021.
  1. Jun 13, 2021 at 10:37 AM
    tacomio877
    tacomio877 [OP] Active Member
    Seth
    2019cavalryblueDCSBTRDOF
    stock
    +2 total chaos kit and 33's, I was really wanting to keep stock fenders with this setup but its looking like Im going to need to check for clearance at bump and see whats what. whats the best/safest way to go about it?
    CocaineAndCreatine likes this.
  2. Jun 13, 2021 at 10:39 AM
    Vegasstunts
    Vegasstunts Well-Known Member
    16 TRD sport
    All of them.
    Fronts, pull the springs off the shock. Rears, break down the leafs to a single leaf or 2.
  3. Jun 13, 2021 at 10:47 AM
    tacomio877
    Seth
    stock
    why not total coilover removal? jack under tire? seems sketchy, if there was a way to hold the brake so the tire couldnt roll and kick the jack out
  4. Jun 13, 2021 at 3:37 PM
    Vegasstunts
    16 TRD sport
    All of them.
    That would confirm tire fitment but not where you would need to bump your travel at to prevent shock bottoming
    2000prerunner23 likes this.
  5. Jun 28, 2021 at 9:01 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Stock bump stops / durobumps etc. will limit up travel before the shock so just pull the coilover and put your frame on jackstands. Use a jack to lift the lower or under the tire and crank your steering wheel full left and right to see where you rub.
  6. Jun 30, 2021 at 5:26 PM
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
    Not necessary. Only if the coil over is the correct size, and/ or shock mounts are set up correctly. Always cycle with the shock bolted up once to make sure.
    Vegasstunts likes this.
  7. Jun 30, 2021 at 5:40 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I did this when installing upper shock / coilover mounts but unless someone’s ditching stock coil buckets and / or bump stops, having a correctly spec’d coilover for a bolt on kit makes the body the limiting factor in up travel if you’ve got 33’s on up.
  8. Sep 23, 2021 at 7:13 AM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    :worthless:
    JustJon likes this.
  9. Sep 24, 2021 at 3:42 PM
    Happysmiley
    Happysmiley Well-Known Member
    Fabien
    Northern NV
    89 pickup 87 pickup 2016 4runner
    Truck needs to be safely on jack stands to the frame which ever side you are cycling.
    Then you cycle with a jack under the lower a-arm up front or under the axle out back, not under the tire.
    With springs removed or leaf pack broken down like already mentioned.
  10. Sep 24, 2021 at 3:45 PM
    Happysmiley
    Fabien
    Northern NV
    If you've never done it before and don't have all the right tools it will seem like a lot of work
    If you've been building trucks for years it's about as hard as making a piece of toast
    we all gotta start somewhere
    You could just pull the coilovers and bump stops and cylce metal to metal (uniball misalignments maxed out) to be on the safe side.
    If you are bottoming the truck out hard off road, jumping/whoops, the rubber body mounts can compress and everything can flex past where you think full bump is while cyclimg suspension on jack stands.
    I consider wood blocks as "tools" for jacking up suspension
    Deeahgee and Wishbone Runner like this.
