How to: Deleting ADD system
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PSU Taco85, Apr 14, 2016.
  1. Apr 21, 2018 at 2:52 AM
    #81
    Derk33
    Derk33 Well-Known Member
    Derek
    Pennylvania
    22 Army green TRD OR
    What is that copper wire in the main housing?
  2. Apr 21, 2018 at 8:00 AM
    #82
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Air line for the ARB locker.
    Derk33[QUOTED] likes this.
  3. Apr 23, 2018 at 12:45 PM
    #83
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    My ADD failed this weekend. But it failed in the engaged possition. 4wd still works. Debating doing this mod, replacing the ADD or just living with the blinking light.
  4. May 6, 2018 at 10:37 PM
    #84
    02tacoSR5
    02tacoSR5 Member
    Jonathan
    East Texas
    2013 DCLB 4x4
    Debadged, Wilson cell booster, CoverKing Ballistic seat covers.
    So will traction control still function normally with the ADD delete?
    How about with the ADD delete and fj tcase setup?
    Just want to make sure I've covered all basis before I jump in with my DD.
  5. May 7, 2018 at 2:47 AM
    #85
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Traction control works as it should.
  6. Jul 30, 2018 at 1:50 AM
    #86
    robbytaco
    robbytaco Well-Known Member
    Rob
    San Antonio
    06 DC TRD Sport
    Subbed for part numbers
  7. Jul 30, 2018 at 6:05 AM
    #87
    jross20
    jross20 Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    The axle broke? That's some shit steel damn
  8. Oct 27, 2018 at 7:25 PM
    #88
    6 gearT444E
    Deep South
    Herculiner Hootus
    actually took quite a bit to break that axle. Fast-forward to 5:10 and watch, I was in double low with F/R locked along with the passenger front wheel being "wedged" in between the rock
  9. Oct 28, 2018 at 6:31 AM
    #89
    jross20
    Georgia
    Even still... Time to get the mega forged one!
    :welder:
    6 gearT444E[QUOTED] likes this.
  10. Feb 6, 2019 at 10:50 AM
    #90
    RS874903
    RS874903 Well-Known Member
    Ohio
    4x4 Tacoma 4L V6 Pyrite Mica
    Hey ya’ll. For those of you that have done this, running into any issues? Spraying gear oil or leaking transfer case etc? I have parts sitting in the shopping cart right now and still deciding whether it’s a good idea to go through with it. Just trying to get a consensus from people as I keep going back and forth.
  11. Feb 6, 2019 at 11:03 AM
    #91
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Learned a lot that trip... you killed the front diff tube & I snapped the rear axle shaft.
    Good times. :laughing:
  12. Feb 6, 2019 at 11:32 AM
    #92
    bwawuz02
    bwawuz02 Well-Known Member
    RS874903[QUOTED] likes this.
  13. Feb 7, 2019 at 10:55 AM
    #93
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    If you have done the fj case swap, and do the add delete what happens with the electronics?
    With the Fj case you have to run a switch to engage the add and have 4x4 so the sticks work at the case. With the ADD gone does the computer just not know when it is in 4x4 because of sensors in the case?
  14. Feb 7, 2019 at 11:05 AM
    #94
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    There are two switches on the factory case that get reused on the FJ case. When you shift the FJ case, the shift rods engage these switches so your dash lights function. They also let the comp know you’re in 4WD and 4L, switching off traction control etc at the appropriate times.
    The 4WD ECU is no longer needed. Mine isn’t even in the truck any longer.
  15. Feb 7, 2019 at 2:44 PM
    #95
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Great to know! Thank you for the clarification. Want as much of the electronics gone.
  16. Feb 7, 2019 at 3:41 PM
    #96
    6 gearT444E
    Deep South
    Herculiner Hootus
    Next mod is EFI delete!
    tacoma16[QUOTED] likes this.
  17. Feb 7, 2019 at 4:34 PM
    #97
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    One thing at a time now.
  18. Feb 7, 2019 at 6:21 PM
    #98
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    Man, back when I had a 22re pick up I strongly considered a kit like this one! I think it's so much cooler than EFI.
    6 gearT444E likes this.
  19. Mar 31, 2019 at 12:04 PM
    #99
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Has anyone done this mod without the FJ case swap and had issues getting their 4wd to engage?
    I deleted the ADD on mine and now 4wd wont engage and the lights just flash on the dash. I was under the impression that the lights would blink, but that the tacoma t-case would still engage 4wd high and low..
    @05Taco4x4 Do you have any idea of what i would need to do to get 4wd functioning again until i can swap in my FJ case?
  20. Mar 31, 2019 at 12:16 PM
    #100
    6 gearT444E
    Deep South
    Herculiner Hootus
    Sounds like you'll be out of luck until you get the case swapped. Without the continuity of the ADD actuator limit switches, the 4wd ECU will not allow any shifting into 2wd or 4wd. There are two ways to fix this until you get your FJ case, I'd recommend the first one.
    1 - Install ADD actuator in a ziplock bag and plug it back into the connector
    2 - Remove tacoma electric actuator and move shift rail manually to shift into 4wd and 4lo.
    BassAckwards[QUOTED] likes this.
