How to disable door chime?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ppadilha, May 31, 2017.
  1. May 31, 2017 at 9:58 AM
    Ppadilha
    Ppadilha [OP] Member
    Phil
    2021 Sr5
    Hey guys! I recently bought a 2017 Tacoma limited and I love everything about it except for one major thing!!! The door chime is absolutely KILLING me. It's basically nails on a chalk board. I'm in and out of my truck all day for work and the consistent "door ajar" chirp is driving me crazy!! Please tell me there is a way to disable, destroy, burn or shoot this thing out of my life!! PLEASE!! Any input would be greatly appreciated!! Thanks so much! Sorry for the double post, wanted to reach as many people as possible and wasn't sure if a lot of seasoned Tacoma owners look at the "new owners" thread!
    paleh0rse likes this.
  2. May 31, 2017 at 9:59 AM
    rockguitar316
    rockguitar316 Well-Known Member
    Adam
    Dayton Ohio Area
    Now: 2016 WRX stage 2 377hp/350tq. Then: 2016 TRD Sport DCSB 6MT (don't kick me!)
    Dealership.
  3. May 31, 2017 at 10:01 AM
    16Tacos
    16Tacos Well-Known Member
    Zach
    Boston
    08 Access Cab 4x4 V6 SR5
    OME Nitrochargers w/886s & Dakars, ARB Deluxe Bull Bar w/Warn winch, RCI sliders with kick out, IFS & Mid skids, BFF Hi-clearance rear bumper, Brushed Copper 17" SCS Ray10s w/285-70 KO2s, Black OEM 16" steelies w/255-85 KM2s, Leer contractor cap w/Smittybilt overlander xl RTT, Off-Grid Engineering dual battery kit and bed power panel, Blue sea aux fuse block, Wyntner 60L fridge freezer, ARB dual compressor, Pioneer 720BT head unit, CB radio, @Matt_Gecko bed and engine bay lights, @TacomaTruckParts Dirt bike tie down bar, color matched OEM grill, A-Pillar phone mount mod, @Docloco rear seat molle panel
    I think TechStream should allow you to disable that, it lets you disable the seatbelt chimes. I think some people have had luck with the knock off versions on eBay/Amazon, but I've also heard stories of them infecting you with a virus.
  4. May 31, 2017 at 10:05 AM
    Aw9d
    Aw9d That one guy
    Please don't title your thread "Please Help". Around here that means you are stuck, broke down, something requiring people to come help you out.
    If it's like the second gen can take the gauge cluster out and there should be a little speaker on the back. Remove it. Someone would have to confirm that it's still located on the back of the gauge cluster on the 3rd gens. Second gens it is and I removed mine shortly after buying the truck because I can't stand the beeps.
    paleh0rse, tcBob, LivinOnEdge and 3 others like this.
  5. May 31, 2017 at 10:15 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    dunno if this works or not...
  6. May 31, 2017 at 10:36 AM
    Ppadilha
    Phil
    2021 Sr5
    Ok thanks guys I'll try and change the title thread too. I'll try removing the speaker
    Aw9d likes this.
  7. May 31, 2017 at 10:39 AM
    TejasTaco
    TejasTaco Grab a taco
    Give me a few minutes to finish lunch and I'll check it from the software side.
    tcBob likes this.
  8. May 31, 2017 at 10:40 AM
    Ppadilha
    Phil
    2021 Sr5
    Sweet thank you Tejas!!
  9. May 31, 2017 at 10:41 AM
    Paul123
    Paul123 Web-Wheeler
    Paul
    Reno
    2014 TRDOR pyrite mica, 3" lift 33's, 4.56’s
    There's a thread on here from yesterday about how to remove the speaker
  10. May 31, 2017 at 10:41 AM
    uhplifted
    uhplifted The Hopfather
    Brian
    Huntington Beach, CA
    16 DCLB OR
    There's a thread with instructions on how to remove the speaker, but it also takes off blinker noises as well - if that's a problem for you.
    Ppadilha[OP] and wilcam47 like this.
  11. May 31, 2017 at 10:43 AM
    wilcam47
    Will
    Bourbon state
    I hate the blinker noise as well
    Ppadilha[OP] likes this.
  12. May 31, 2017 at 10:43 AM
    Ppadilha
    Phil
    2021 Sr5
    No I can deal with that, it's just the door chime, is really irritating. I'll search for the thread
  13. May 31, 2017 at 10:45 AM
    Ppadilha
    Phil
    2021 Sr5
    Paul123 can you put the link up? Is it for the latest gen?
  14. May 31, 2017 at 10:45 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    it was posted here as well. someone did it recently.
    You can also just press the little button in the door jam to silence it if you just want it to shut up if you opened the door before turning off the truck.
    I'll be asking the dealer to disable it next time I'm in.
    Ppadilha[OP] and Aw9d[QUOTED] like this.
  15. May 31, 2017 at 10:47 AM
    Joe23
    https://www.tacomaworld.com/threads/diy-disable-door-ajar-chime-permanently.491166/
    I'd just be nervous this could screw up the cluster. and with members reporting needing a new cluster because of trip meter randomly reseting, I feel like this could void warranty in them doing so.
    Guess I'll need to look around for a dealer willing to do so, as the dealer I go to is usually a bunch of cunts over doing anything outside of regular maintenance
    Ppadilha[QUOTED][OP] and Paul123 like this.
  16. May 31, 2017 at 10:53 AM
    Ppadilha
    Phil
    2021 Sr5
    Thanks again for all the help guys! I'll try taping the door button down first and if not I'm pulling it out and the smashing the speaker!!!
    Paul123 likes this.
  17. May 31, 2017 at 10:54 AM
    Aw9d
    Aw9d That one guy
    Thanks for posting this. It's really not that hard to remove the speaker. I think the reason people mess up the cluster is they are using too much heat when removing the speaker or the twisting it is damaging something. If you take your time it won't hurt anything. I do feel your nervousness as when I did mine I looked up how much a new cluster was. Then I was nervous. Then I had a beer and then there was no speaker. :D
  18. May 31, 2017 at 11:34 AM
    TejasTaco
    I checked. I don't see a software setting via the OBD II interface.
  19. May 31, 2017 at 11:38 AM
    Wildcat80236
    Wildcat80236 Well-Known Member
    David
    Ocala, FL
    2017 Toyota Tacoma BBP Limited DCSB
    I turned mine off using Carista app and Veepeak Mini Bluetooth OBD II
  20. May 31, 2017 at 11:43 AM
    TejasTaco
    I just checked using that adaptor and app. I didn't see it on my 2017 OR. Remember exactly where the setting was? My adaptor is the Veepeak WIFI version with the iPhone app.
