How to: drop, clean, and reinstall the 2nd Gen transmission pan and filter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hook78, Jun 23, 2021.
  1. Jun 24, 2021 at 11:28 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Yeah, filter might imply a higher level of 'filtration' than what this provides haha. You can see in the pic its just a fine mesh screen. Meant to grab the larger particles that might cause damage, not the ultra fine stuff
    Hook78[OP] likes this.
  2. Jun 24, 2021 at 11:35 AM
    Tacoche
    Tacoche Well-Known Member
    2008 trd sport
    3rd gen trd sport suspension
    Do you think it really worth the extra time/money to remove the pan? I mean, if oil look clean, i dont think the mesh can clog.
  3. Jun 24, 2021 at 11:40 AM
    Hook78
    Hook78 [OP] Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    My personal opinion is that the magnets and the screen do their job. So is this “necessary”? Probably not. But it can’t hurt, and especially if your fluid was really dark and dirty I say why not take the extra step? I’m trying to extend the life of this vehicle and its components as far as I reasonably can.
    wi_taco likes this.
  4. Jun 24, 2021 at 12:06 PM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    You torque to 21 and you will likely be replacing a pan like me. Seriously OP - change that to 15. Lots of people will reference this.
  5. Jun 24, 2021 at 12:27 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    I absolutely will if someone can get me a reference. I’m all for anecdotals but how can it be that everyone knows the value is wrong but Toyota has never corrected it? I will however add a note to that spec referencing the posts you and someone else made regarding this.
    CaptQuinn and Biscuits like this.
  6. Jun 24, 2021 at 2:08 PM
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    x2
    I torqued to 21 ft lbs the 1st time I changed the transmission fluid. 2nd time around discovered I had stripped it and had to replace the pan too. Went by feel 2nd time around and didn't use a torque wrench.
  7. Jun 24, 2021 at 3:14 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Original post edited to add reference to this info.
    2WD and JAGCanada[QUOTED] like this.
  8. Jun 24, 2021 at 4:12 PM
    Florida_Taco
    Florida_Taco Active Member
    Justin
    Gulf Coast
    2011 MGM DCSB
    Good write up. Been planning on doing this
  9. Jun 25, 2021 at 7:48 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    FWIW, a new filter from RockAuto is about $11 and comes with gaskets.
    Suggest to replace it rather than cleaning it. Its only $11 and you need to remove it to clean.......
    Otherwise, nice write up.
    I was quoted $650 for this service at Toytoa......
    Hook78[OP], Biscuits and wi_taco like this.
  10. Jun 25, 2021 at 10:01 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    If you post that P/N I’ll edit it into the original post as an option. I personally prefer to go OEM if at all possible, but many are perfectly comfortable with aftermarket. The OEM filter was absurdly expensive.
    TheDevilYouLove likes this.
  11. Jun 25, 2021 at 1:28 PM
    Knute
    I used the WIX 58136.
    Sorry the cost has risen to about $25. Still significantly less expensive than $650
  12. Jun 25, 2021 at 1:30 PM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
  13. Jun 25, 2021 at 1:35 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Is it a filter or a metal screen? Why would you replace a metal screen?
    SR-71A likes this.
  14. Jun 25, 2021 at 1:37 PM
    TheDevilYouLove
    Marylandistan
    It’s easier to replace it than to clean it.
  15. Jun 25, 2021 at 1:38 PM
    #35
    Knute
    Why???
    Because its a PITA to clean and you can't access all of it to clean. Plus when you are done, how do you know its clean?. Also the risk of damaging it.......
    Its a small inexpensive part that a major component depends on it performing. For $25 not worth gambling a $4000 transmission.
    Just ain't worth the trouble.
  16. Jun 25, 2021 at 1:59 PM
    #36
    Sharpish
    Brian
    I just figured you have to remove it to replace it, (if it appears dirty in the first place) so why wouldn’t you wash it down with brake cleaner and put it back in? I don’t know though, I’ve never removed the pan, just had fluid exchanges done.
  17. Jun 25, 2021 at 3:35 PM
    #37
    Hook78
    Eastern NC
    2015 DCSB TRD OR
  18. Jun 25, 2021 at 3:42 PM
    #38
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    You’re not really going to be able to tell how much debris is on the screen without removing it and pouring out the excess fluid inside.
    As for the debate on clean or replace, if something is in good condition and can be cleaned up good as new, I’d rather keep it than replace it. The filter isn’t a consumable so to me, inspect, clean and replace is fine. But, just a personal preference.
    SR-71A likes this.
  19. Jun 25, 2021 at 6:29 PM
    #39
    jkuniverse
    jkuniverse Well-Known Member
    Arlington TX
    2013 Limited DCSB 4x4 Super White
    I replaced the filter/strainer with the genuine Toyota part at 3rd drain & fill. A small price to pay since I probably don’t need to replace it for another 100k.
  20. Jul 1, 2021 at 5:17 AM
    #40
    PA38flyer
    PA38flyer Member
    2010 Tacoma
    Was just quoted $72 for the strainer at the stealership. But they had ATF WS for $9.95 a quart, beating some of the Amazonians.
    SR-71A likes this.
