how to equip this to tow a trailer?
Discussion in 'Towing' started by donlogan, Jul 11, 2015.
  1. Jul 11, 2015 at 10:43 AM
    donlogan
    donlogan [OP] Well-Known Member
    I am going to be purchasing a motorcycle. I plan on renting a motorcycle trailer from UHaul and towing it with my 95 Tacoma, extended cab, RWD, 2.4 liter. I've no no experience with towing. I'm trying to figure out what I will need in order to hook up the trailer.
    I tried getting one of this ball hitch mounts and putting in the hole pictured but it wouldn't go all the way through to the other end in order to screw it in place.
    Please advise.
  2. Jul 11, 2015 at 10:46 AM
    trx125
    trx125 Well-Known Member
    I would suggest a bolt on receiver hitch.
  3. Jul 11, 2015 at 10:55 AM
    Large
    Large Red
  4. Jul 11, 2015 at 12:37 PM
    donlogan
    I assume there is a place underneath the bumper where the receiver hitch can be attached to? I will go look now.
  5. Jul 11, 2015 at 5:22 PM
    trx125
    Yes, to the frame!
  6. Jul 18, 2015 at 10:40 PM
    N128CG
    N128CG Well-Known Member
    2017 Tacoma TRD OR
    Stock
  7. Jul 18, 2015 at 10:45 PM
    Adamw1988
    Adamw1988 Well-Known Member
    Adam
    West Tennessee
    2015 Trd sport
    I have a hitch for sale off my 15 Tacoma. I replaced my bumper and have one.
  8. Jul 30, 2015 at 11:34 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    You can get tow balls in a long shank version: http://www.etrailer.com/Balls/Hidden-Hitch/63849.html
    Make sure you check what size ball the trailer you will be using has. There are 4 common US sizes. Most likely it will be a 2" ball.
    You won't find the long shaft tow balls for sale locally, they are an uncommon item. If you are hauling a lightweight motorcycle trailer a short distance only, I would say this is acceptable, but like the others said, I really suggest you get a true receiver hitch installed.
