How to: Front shock/spring removal
Discussion in 'Suspension' started by chris4x4, Mar 28, 2009.
  1. Mar 28, 2009 at 5:38 PM
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Removing the front shocks/springs on the second gen Tacoma is a pretty easy task. You will need a small assortment of basic hand tools.
    Hammer
    Metric sockets (1/4" & 3/8"): 17mm, 19mm, 14mm
    3/8" ratchet wrench
    1/4" ratchet wrench
    14mm ratcheting open/box wrench
    19mm open wrench
    Needle nose pliers.
    Torque for the 3 top nuts is: 47 ft-lbs
    Lower shock bolt/nut: 61 ft-lbs
    Sway bar nut: 52 ft-lbs
    First, jack up the front of the truck and remove both front tires:
    Then, remove the 17mm swaybar end link:
    Then, remove the 19mm castle nut holding the upper ball joint to the spindle. You will need to use the needle nose pliers to remove the retaining wire. Once this is removed, wire or zip tie the spindle so as to not let it pull or put tension on the brake lines:
    Then, you want to remove the 3 14mm nuts on the top plate. DO NOT REMOVE THE CENTER NUT.
    Then, remove the 19mm lower shock mount bolt, and nut. You may need to tap this bolt out, once the nut is removed:
    Then, Remove the shock/spring assembly:
    Reinstall the lift or coilover of your choice in the reverse order.
    I accidentaly deleted the pics, so until I can get new ones use these links:
  2. Mar 28, 2009 at 5:45 PM
    brianr
    brianr go shit in your hat
    2010 4x4
    BUILT, not bought...
    badass buddy!
    good write up.
    having a shindig w/o me though...thats harsh.
  3. Mar 28, 2009 at 5:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Sorry, Buddy. I thought you were working? :( You would have enjoyed it. Matt almost had to stop me from beating a "Tech" at Pep boys....maybe He'll chime in and tell the story. :D
    gregzz likes this.
  4. Mar 28, 2009 at 5:49 PM
    tacoma08MZ
    tacoma08MZ Well-Known Member
    Levi
    Pittsburgh, PA
    2008 Access Cab 4x4
    tinted head/tail lights-blacked out badges-3 inch tuff country lift 33 inch nittos-black steelies custom spare bed mount-hilift-weathertechs-kenwood dnx5120 dvdnav headunit-remote start-painted grille surround-fog lights-grillcraft black mesh grille
    Wow, thats way easier than i thought it would be! Ill be doin this by myself when i throw out the spacer lift, thanks chris!
  5. Mar 28, 2009 at 5:49 PM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    Damn Brian I thought that was your truck for a minute. thought you got some new toys:D
  6. Mar 28, 2009 at 5:49 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Looking good! Good job guys!!!:cheers:
  7. Mar 28, 2009 at 5:50 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I wanna hear to tech beating story!!
    Nice Write up Chris-What I figured it would be to get the job done...Nice to see someone else do it first tho!!
    gregzz likes this.
  8. Mar 28, 2009 at 6:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well, We took the stock shocks/springs to Pep Boys to have them swap the new OME 885 springs and Bilstien 5100 shocks. We dropped them off, and left to go assemble Matts new TC UCA's. We needed a different size grease zerk for one of the arms, so we headed back to Pep Boys. We got the parts, hung out for a bit, then, while we were on aisle 9a, my phone rings, it was Pep Boys telling me the shocks were finished. We stroll over to the counter, and the dude says, "Here ya go!" with a big grin on his face. The Top Plates were on crooked, and Im looking at them and notice, that they assembled them without the bushings or washers!!! The service dude, says "Oh...sorry about that, I'll go get it fixed"....I told him I want to go back there and show the dude how to build them....he started to mumble something, but I was already walking back there. So I see this fat ass trying to work the spring compressor, and he asked "whats wrong with them?"....I about LOST IT! I told him "They need to have the bushings installed, washeres, and the spring is installed wrong". The manager was right there, and he looked at the tech and said "You should have known better! How many of these have you done?". Well, I showed both of them how to do it. Matts Top Plate was gouged as the top nut was installed without a bushing or washer, and it was gouging the Top Plate. Idiots. I was pissed.
    gregzz and SandyTaco4x4 like this.
  9. Mar 28, 2009 at 6:33 PM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    So if you had an aftermarket setup that was a complete shock/spring assembly like ToyTecs Ultimate Kit where you didn't need to "build" the shock/spring.....It would just slide right back in there, correct?
  10. Mar 28, 2009 at 6:35 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    If you mean- You buy a completely assembled coilover then...yes. Just take the old one out and put the new one in.
    That's pretty sad Chris- I'd be pissed. I'm glad that I'll get to help with mine when the time comes...
  11. Mar 28, 2009 at 8:16 PM
    brianr
    2010 4x4
    haha, we need to have a cigar meet soon.
    sorry Joe, no new toys for me. I'm looking at new tires right now though. Maybe wheels if I find a good deal.
  12. Mar 28, 2009 at 9:02 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Hey chris, is it really just that striaght forward to put on the 5100's? I know you need an alignment
  13. Mar 28, 2009 at 9:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its just that easy. Take the springs and shocks to a place to have them installed, if you dont have a spring compressor. If you take it some place, make sure the reinstall everything propperly.
  14. Mar 29, 2009 at 2:32 AM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    Instead of unbolting the ball joint why not just remove the top control arm. Its easier that way which is the way I do it on the 5 lug tacomas when installing a drop kit.
  15. Mar 29, 2009 at 4:58 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    That's a great write up, I was wondering how easy that was, looks like I will add my new coilovers myself............
  16. Mar 29, 2009 at 5:41 AM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    Looks like I'm late to the party.
    Pep Boys sucks.
    Chris is awesome.
  17. Mar 29, 2009 at 5:57 AM
    TicTacOma
    Columbia,SC
    ^^ You can still bring the chips and dip.....
  18. Mar 29, 2009 at 6:13 AM
    Packman73
    2007 TRD Off Road
    Well, ok.... but what am I to do with all these hookers then...? Um, nevermind.
  19. Mar 29, 2009 at 6:15 AM
    brianr
    2010 4x4
    damn, thats where they are all are...you are hording them over there near 7th St.
  20. Mar 29, 2009 at 6:18 AM
    Packman73
    2007 TRD Off Road
    7th St hookers...mmmmm.
