How to: Front shock/spring removal
Discussion in 'Suspension' started by chris4x4, Mar 28, 2009.
  1. Mar 5, 2010 at 9:26 AM
    #181
    Stillfly199
    Stillfly199 ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    I dunno, gonna get back out in a min and have at it, just baffled because the driver side just poped right out. I'll figure something out.
  2. Mar 5, 2010 at 9:30 AM
    #182
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Spray it with some WD40, or some such. Take the BFH and beat on the spindle and UCA. I'm out of ideas. GL
  3. Mar 5, 2010 at 9:36 AM
    #183
    Stillfly199
    J.D.
    2010 FJ Cruiser
    Haha, thats what Im thinking. Gonna go down here in a little bit haha
  4. Mar 5, 2010 at 12:18 PM
    #184
    virgilus11
    virgilus11 Well-Known Member
    kearny, nj
    09 sr5
    TRD supercharger,EMU 884 springs, 90000 shocks, air bags rear and TSB with EMU shocks, grillcraft mesh, Relentless front bumper,Armology rear bumper, byxenon hid's retro ,undercover lid with bike rack on top, Kenwood dnx9140,TRD cover seats
    That bumper,,,,,,,,,,, Hmmmm,, drooling.
  5. Mar 16, 2010 at 7:49 PM
    #185
    pokeng
    pokeng Married With Children
    North of Austin/West of Nashville
    2009 DC TRD Off Road 4x4
    Foldacover G4 Elite, Deflapped, TRD exhaust, Webasto Hollandia sunroof, Katzkin leather seats, Dynolock, Sockmonkey decals, oem bed extender, all-weather mats and bed mat
    Good info. How much time should one plan for doing the fronts only? Hoping to get this done one evening after work on my DD.
  6. Mar 16, 2010 at 7:59 PM
    #186
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    give yourself 2 to 3 hours to do it.
  7. Mar 16, 2010 at 8:04 PM
    #187
    pokeng
    Gracias, Chris. I'll finally be installing the 884s you recommended months ago. :D
  8. Mar 16, 2010 at 8:08 PM
    #188
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Sweet! Take pics :)
  9. Mar 20, 2010 at 1:45 PM
    #189
    Anthony
    Anthony San Antonio Detailer :)
    Houston - Spring/Tomball area
    06 prerunner access cab 2.7L M5
    Nfabs Afe Pro Dry UWS linex'd toolbox
    Doing the fronts right now. Screwed up the passenger tie rod, I must have damaged the threads somewhat cause whent he nut goes so far it grabs and the whole thing turns with the bolt :(
    Going to get a replacment later when the wife gets home to give me a ride lol
  10. Mar 20, 2010 at 2:44 PM
    #190
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    There is a cut out in the center of the bolt, so you can use a 5.. hex wrench to hold it still while you tighten the nut with an open/box wrench.
  11. Mar 20, 2010 at 4:26 PM
    #191
    Anthony
    yeah was looking at that. i could see where maybe at one time it had a shape but its pretty much rounded out or just filled with crud. try using a wire brush and some brake cleaner to see if thatd help but no luck there.
    and no one stocks this part... theres a dealership that claims has sunday hours parts department hopefully they have one there.
  12. Mar 20, 2010 at 6:09 PM
    #192
    Anthony
    ok, well with some visegrips i managed to tighten it up afterall. anyhow, mine is a base model and i bought some used 5100s & trd off road springs that were already assembled, i noticed i gained about 3/4-1" lift even though these are set at 0 lift but over bumps im getting a metal squeaking sound now. :confused:
    thers a 1/4" metal spacer that i installed underneath the upper mount on the drivers side to accomodate the lean. another thing, i noticed when its sitting on its own weight, the first couple coils from the top seem to be awfully close together at least from my opinion, is that normal? i know the OR springs are "progressive" but it was just something i noticed.
    it rides great, i love how it its definately more stiff but not like bone jarring, more like how a heavier truck rides but the squeaks bother me.
  13. Mar 20, 2010 at 7:58 PM
    #193
    redraider
    redraider Well-Known Member
    Eric
    San Antonio,TX
    the squeeks are probably from your sway bar, you need to get a sway bar relocator from toytec, I had the same thing happen to me and I took it back to where I had my tires installed cause I thought it was the calipers rubbing on my new wheels, but it was the sway bar rubbing on the coil, easy fix too only took about 30 min. to put on
  14. Mar 20, 2010 at 8:14 PM
    #194
    Anthony
    why would the swaybar rub the coil?
  15. Mar 20, 2010 at 8:16 PM
    #195
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The sprongs from the TRD Off Road are progressive. The top coils will be close to touching.
  16. Mar 21, 2010 at 11:27 AM
    #196
    redraider
    Eric
    San Antonio,TX
    dunno, but thats what was happening to mine, I think the relocators move the sway bar forward a 1/2" in. or so, the squeek usually happened when the spring was compressed after I hit a bump not when I drove straight on the road
  17. Mar 21, 2010 at 12:04 PM
    #197
    Anthony
    i took a look under there and can see they are pretty close just sitting, and where as any movement in the suspension they would rub a little. will have to look into the relocators now.
  18. Mar 21, 2010 at 9:05 PM
    #198
    redraider
    Eric
    San Antonio,TX
    replied to your pm
  19. Mar 30, 2010 at 12:40 PM
    #199
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    Pics are gone on first post
  20. Mar 30, 2010 at 1:31 PM
    #200
    jmed99
    jmed99 Well-Known Member
    SC
    09 DC PreRunner TRD OR
    Yeah...how can I get the pics in the first post? Thanksl!
