How to: Front shock/spring removal
Discussion in 'Suspension' started by chris4x4, Mar 28, 2009.
  1. Sep 15, 2010 at 7:09 PM
    #261
    snorola
    snorola Well-Known Member
    Brett
    Canmore Alberta
    06 4x4 Dbl Cab
    SAW 2.0 Coilovers Eibach 14" 650lb springs Camburg UCA's All pro expo springs OME rear shocks All pro front bumper All pro IFS skid All pro sliders SCS f5 matt black rims Lightforce blitz 240's
    i ended up taking my UCA's out to get my old shocks out/ coil overs in
    good practice for replacing my uca's soon I guess
  2. Sep 20, 2010 at 5:29 PM
    #262
    larryde09
    larryde09 Well-Known Member
    Larry
    Boston, MA
    2019 TRD Sport, White Double Cab "Yeti"
    Current: DR750S-2CH Dash Cam, USB Fast Charger in stock blank, Hondo Garage phone mount Previous: 2006 Black 2.7L 5-spd SR5 4x4 Access Cab - K&N Cold Air Intake, Modified Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars, DIY Bed Lights, DIY Ground Lights, DIY Tailgate Electrical Box, Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    (hopefully the emoticons will cheer me up)
    So I started changing my struts today and things were going smoothly...got the sway bar end links unbolted, replaced bad end link, and loosened all the strut mounting bolts.:thumbsup:
    Then, the first road block: one of the welded nuts inside the frame for the sway bar mount broke. I could see if from a small hole in the frame, but was going to have to get creative to get it out of there. :confused: (possibly drilling a larger hole to get it out, then replace it with nut and lock washer...I can't weld and didn't have a sawzal to cut the bolt...any other ideas?)
    So I decided to continue on the passenger side where the sway bar moved enough to get the strut out. I finally broke loose the castle nut on the tie rod end and used my puller tool to pry the end from the steering knuckle. And then......the damn castle nut wouldn't come off the bolt!!!! No matter what I did I could not get the nut off, it just kept spinning the ball joint.:goingcrazy: There is no allen key to hold it still and I didn't want to damage the threads using a vice grip. After trying other things, It looks like I was spinning on the threads and now the bolt is jacked up...and I think I compromised the grease boot when I was looking at ways to get it off. :crapstorm: Did I miss something? Haynes manual said to simply loosen the castle nut, pry the joint off the mount, then continue to remove the nut. I shouldn't have to damage the tie rod end just to get it off.
    So now it's sitting at Midas where they'll fix the stabalizer bar mounting nut, remove/replace the tie rod end, and change the struts. The rear shocks were super easy, but now I'm a little discouraged after the fronts.
    gregzz likes this.
  3. Sep 21, 2010 at 12:52 PM
    #263
    VolFan57
    VolFan57 Well-Known Member
    TENNESSEE
    2016 TRD OR 4x4 - MGM - traded. 2018 TRD Sport BRM 6MT
    Don't tell me this.....I'm about to get started on this myself in 2 hours when I get off work. I've been debating tackling this myself for the last week, and finally got the nerve to try it.
    Sorry about your troubles - i'm sure i'll have a story to tell also.
  4. Sep 21, 2010 at 1:46 PM
    #264
    larryde09
    Larry
    Boston, MA
    Good Luck!! Some people did it by removing the control arm, maybe that's an approach for you. If it weren't for the tie rod end, I would have been ok. Mine's a 2006, so maybe your 2010 isn't as rusted. I think that sway bar bracket is the only thing I didn't PB Blast the day before, so maybe that's why the welded nut broke.
    I'm off to pick it up from Midas soon. Even after all this, I still saved money and installed better components! Not a total loss.
  5. Sep 21, 2010 at 7:42 PM
    #265
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    Dude, it sounds like you are facing some of the same issues I had...I also had the nut on the inside of the frame break free, and I had to have a mobile welder come weld it for me through the small hole you speak of...cost $140. For the castle nut spinning you may have to put pressure on the junction by way of a c-clamp maybe?! I had to use one to put the unit back together, and it was a pain, but worked. I did the rear AAL's first, and it was easy in comparison...just took time because I was cautious as I've never done it. I got it all buttoned up, and now I have one of the adjusters for the alignment siezed up, so the fun never ends over here. At any rate when all is done I'm sure it'll be way better than stock. Already rides awesome minus the align being off.
  6. Sep 21, 2010 at 9:03 PM
    #266
    larryde09
    Larry
    Boston, MA
    Update: Midas was able to work there magic and removed the nut through the small hole in the frame without any cutting/drilling. They replaced the nut with a locking type one (with flanges that catch the metal), so I'll just have to be careful to reposition with magnets it in the future should I ever need to remove the sway bar again.
    As for the tie rod ends: I asked what they did to get them off and they said they were really stuck on there and needed a lot of heat and banging. Well, I didn't have my torch with me at my friends and I was too frusturated at that point anyway, so better luck next time.
    I'm going to pull the wheels off tomorrow and take a look at the work they did and verify torques. This particular Midas has impressed once again, now I just have to see the work for myself.
    gregzz likes this.
  7. Sep 22, 2010 at 5:08 AM
    #267
    VolFan57
    TENNESSEE
    Well the install went better than i thougt b/c my uncle ended up helping me with it - actually I was the one helping since he grew impatient and took over the job! Your right if mine wasn't brand new, then it would have been a real pain getting some of the bolts off.
    All worth it in the end though, very happy with the new setup.
  8. Sep 23, 2010 at 3:19 AM
    #268
    Krewblink
    Krewblink Well-Known Member
    Danny
    Long Beach
    05 toyo Prerunner
    Exhaust,Seat Covers, Intake
    where did all the pictures go???
  9. Sep 23, 2010 at 4:43 AM
    #269
    larryde09
    Larry
    Boston, MA
    I think some other pictures were posted somewhere on page 8
  10. Sep 24, 2010 at 12:27 PM
    #270
    larryde09
    Larry
    Boston, MA
    Ok, so Midas did a good job of fixing my mistakes (see a few posts above), so I pulled the wheels off to torque everything and check their work. In the mean time, I took some pics for reference since my procedure was to remove the stabalizer bar and tie rod ends instead or the control arm.
    Although there are mixed reviews of Rancho's, I took a shot on RS5000's. I can't afford Billstein's and I don't offroad enough to need a lift. Besides, I didn't want to compromise my mpg and ride quality as well as wear out my ball joints and U joints faster. However, I did want a slight upgrade and there is a rebate on Tenneco products.
    I started with the rear shocks, but that is not the point of this thread, so I'll just put up some pics. Since the rears are shocks (not struts), you can remove them without jacking up the truck or even removing the tire. I learned the hard way that there is a flat space on the shock bolt to put a vice grip. This keeps the shock from spinning while you loosen the nut. Once it's too high for the nut to keep coming off, I put the vice grip underneath the frame mount and held the shaft from the bottom side.
    This pic is meant to show the order that the mounting hardware goes on. From bottom to top: washer/cup, rubber bushing, frame mount, rubber bushing, washer/cup, nut. Note that this shock has a welded on nut for a wrench to hold it stable while the top nut is tightened. Then use vice grips on the top just like when your removing it.
    Torque the bolts and the rears are done, took my about 1.5 hours:
    Now to the fronts
    As previously mentioned, I took the sway bar and tie rod end removal route. Here's the sway bar end link.
    First, unbolt the sway bar end link from the spindle. Once you break the bolt loose, you'll have to keep the ball joint from spinning. There is a slot in the end of the bolt for an allen wrench to hold the bolt while the nut is loosened.
    Here it is removed:
    Then remove the sway bar from the frame via the 2 brackets on the front frame area under the skid plate.
    Next, on to the tie rod end. Remove the cotter pin from the castle nut. Break loose the castle nut but keep it on the bolt. Use a puller, lifter or hamemr fork to break the rod end from the steering knuckle. Once loose, remove the castle nut. (Note: this is where I had trouble...I couldn't get the nut to come off and there's no way to keep the ball joint bolt from spinning. In my attempt to remove it, I screwed up the threads and ruptured the boot, so off to Midas I went to remove/replace it...continue at your own risk ;))
    Next, remove the strut/coil assembly as describe in other parts of this thread. Do not remove the strut bolt and mount unless you have a spring compressor or else you could lose a limb, or worse! Most shops will swap out your struts for you for about $20-$50, which is much cheaper and safer than risking it yourself.
    Here it is all put back together.
    I think the Rancho's get a bad name, but I trust my custom car parts dealer and he swears by them. If nothing else, I'll be the guinne pig :) and let you know how they are. So far, after about a week's worth of driving, they are great. I'll be going on a road trip next week, so that'll be a good highway test. The next step is the test of time....
    gregzz likes this.
  11. Sep 25, 2010 at 11:48 AM
    #271
    cweeks1934
    cweeks1934 Active Member
    clarence
    South Carolina
    2010 SR5 Prerunner
    When installing front shocks on a 2010 6 lug , do you remove the tie rod end ,,non TRD
    I am installing 5100s and with TSB read springs done .. thanks
  12. Sep 25, 2010 at 12:16 PM
    #272
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You shouldnt have to.
  13. Sep 28, 2010 at 11:46 PM
    #273
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
  14. Sep 29, 2010 at 4:54 PM
    #274
    larryde09
    Larry
    Boston, MA
    Before I started, no one on TW knew if I had to or not, but the haynes manual did, so that's why I went that route. Removing the control arm seemed much more intrusive. Unfortunetely things went shouth before I had a chance to get the struts out without removing the tie rod end, so I can't say for sure.
  15. Oct 1, 2010 at 9:25 PM
    #275
    larryde09
    Larry
    Boston, MA
    Those are great pics...wish I saw those before I got started. Eitherway, my tie rod end castle nut was no where near the good shape yours is in...I probably still would have had trouble removing it. And I didn't plan for a buddy's helping had to lower the control arm. Great info for the next guy...
  16. Oct 7, 2010 at 2:52 PM
    #276
    mikeyreolegio
    mikeyreolegio Member
    Michael
    Corona
    97 Tacoma LX
    helpd alot! THANKS!
  17. Oct 7, 2010 at 11:09 PM
    #277
    chad68
    chad68 Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
    The only question I have about this is the ball joint and the sway bar pivot Gizmo that attach to the spindle.
    If I am loosing or tightening those 2 nuts, Will either joint slip and spin freely and if so, how would I would I prevent them from spinning, while removing or tightening those 2 nuts? The sway bar I could just vise grip it I suppose but don't have that option with the UCA joint.
    If I could find a pic of how the ball joint is attached to the UCA and how the pivot ball is attached to the sway bar hanger rod, I could answer my own question. Either way I'm doing it myself. I refuse top let 4 wheel parts scracth the crap out of everything and charge me 150 for it LOL.
  18. Oct 7, 2010 at 11:19 PM
    #278
    chad68
    Chad
    Never mind found the answer for the sway link at least.
    I got it now!!.
    Both bolts have a notch at the bottom for an allen key to keep them from spinning.
    Only thing I'm going to try different is in regards to breaking the ball mount bolt loose from the spindle hole, once that nut is removed.
    To me it makes more sense to smack the very outside edge of the upper arm than smacking the bolt. My reasoning is that I'm assuming the top side of the assembly is attached to the upper arm with pressed in splines, since I can't find any pics of it. So instead of taking that chance that the splines would break loose before the bolt clears the spindle hole, I'm going to smack on the ouside edge of the upper arm. Same effect, without the risk of poping the assembly out of the upper arm.
    Let the cursing and tool throwing begin!
  19. Oct 8, 2010 at 8:00 AM
    #279
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You dont want to smack the outside of the upper arm, as that can damage the ball joint. Hit the top side of the spindle. The ball joint isnt "splined", but a taper fit.
  20. Oct 8, 2010 at 9:20 PM
    #280
    chad68
    Chad
    Is there a picture floating around of the joint removed from the upper arm?
