How to: Front shock/spring removal
Discussion in 'Suspension' started by chris4x4, Mar 28, 2009.
  1. Oct 8, 2010 at 9:24 PM
    #281
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Maybe Im missing what your saying.....I was thinking you were talking about the ball joint to spindle attachment point.
  2. Oct 8, 2010 at 11:54 PM
    #282
    chad68
    chad68 Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
    Was trying to figure how the top/upper half of the ball joint is attached to the upper control arm. I was thinking if it was a pressfit that if you smacked the bottom of the bolt to free it up from the spindle hole, that it could dislodge it from the upper arm.
  3. Oct 9, 2010 at 4:54 AM
    #283
    cweeks1934
    cweeks1934 Active Member
    clarence
    South Carolina
    2010 SR5 Prerunner
    You do not have to remove the ball joints ,,Just un do the tire rod end and sway bar ,, that is what I did ,,less work
  4. Oct 9, 2010 at 6:37 AM
    #284
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It wont disloge from the UCA.
    I never said the ball joints had to be removed :confused:
  5. Oct 9, 2010 at 6:32 PM
    #285
    chad68
    Chad
    Undoing the tie rod sounds like I could be in deep doo doo if I put that back wrong LOL.
  6. Oct 9, 2010 at 7:27 PM
    #286
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You shouldnt have to disconnect the tie rod. Just the sway bar.
  7. Oct 9, 2010 at 10:05 PM
    #287
    spamy
    spamy Truck guy
    NorCal
    2017 Tacoma Sport 4x4
  8. Oct 20, 2010 at 12:01 AM
    #288
    tacopromatt
    tacopromatt Matt's Pro Taco (SOLD)
    Austin, TX
    2017 Cement Tacoma TRD Pro AT
    I bought my 07 4x4 DC used w/ a RevTek 3" spacer kit w/ rear blocks.
    I replace the rear w/ AAL a while back and finally got around to ordering 5100's for the front.
    Here's where I get confused. I removed the spacer (2.5" black spacer) and the 1/4" ring which come in the kit. I also noticed that there was no rubber "isolator" between the spring and the mounting plate.
    I just now realized this but a couple weeks ago I reinstalled the 5100's at 2.5" without a rubber isolator. I then got some rubbing on the driver's side fender which I trimmed (just a little). This obviously meant the geometry had changed a bit... truck looked a tiny bit lower. 3" vs. 2.5".
    I got the truck aligned and then got new tires right after since I needed them (lot more tread since old ones were work out... 285/17/70 BF AT's). Got the truck realigned for free when tires went on.
    I drove home to find out that I was getting major rubbing on the fender trip and on the cab mounts with the new tires, which I never had before. I went ahead and did the cab mount chop since I had been meaning to do it anyway. Not sure if the rubbing was due only to new tires or new shocks/tires.
    All in all my issues are that I don't see a rubber "isolator" and I seem to be riding a little bit lower. Almost 23" hub to fender.
    Should I get 1/4" spacer ring to bump it back up to 3" or not worry about it? Should I worry about not having a rubber isolator? I see installs with them and some without. The Hanes manual doesn't show it at all...
    Sorry for the long post... thoughts?
  9. Nov 21, 2010 at 11:41 PM
    #289
    jmdaniel
    jmdaniel Has A Well Known Member
    Jeff
    Leander, TX
    2018 Tundra SR5 CrewMax, 1977 FJ40 Landcruiser
    Probably a dumb q, but here goes... I have the OME 3" lift and TC UCAs, and am going to attempt the install today. The question is on sequence. Is it:
    1. Pull old shock/coilover
    2. Pull old UCA
    3. Install new UCA
    4. Install new shock/coilover
    :confused:
  10. Nov 22, 2010 at 6:20 AM
    #290
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats how I do it .
  11. Nov 22, 2010 at 6:22 AM
    #291
    jmdaniel
    Jeff
    Leander, TX
    Thanks, Chris. I am in the process of killing a few trees here, printing out the how-tos you guys have posted. I appreciate the help!
  12. Dec 29, 2010 at 4:44 PM
    #292
    fnoori
    fnoori Member
    Los Angeles
    2011 Tacoma 2.7L
    Thanks this is very helpful. Looks like I'll need a spring compressor to remove the spring/shock assembly before I swap the shocks, right?
  13. Dec 30, 2010 at 8:18 AM
    #293
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    So I get that just adding spacers can damage things if you bottom out the LCA. Other than than, the same stresses on the ball joints and CV joints apply when doing the bilstein 5100 mod. as with a spacer mod. correct? Also why is a transfer case spacer kit to lower the case and reduce the angles on the CV joints a bad idea? I ask you because I trust your opinion on these matters. thanx
  14. Dec 30, 2010 at 8:49 AM
    #294
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes, the 5100's preload the spring just like a pre load spacer does, but the 5100's are valved for the higher spring rate, which gives a little better ride.
  15. Dec 30, 2010 at 12:50 PM
    #295
    Leggo
    Newton,Ma.
    thanx, and the transfer case shims?
  16. Dec 30, 2010 at 2:51 PM
    #296
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont think I have heard of Transfer case shims....
  17. Dec 30, 2010 at 4:41 PM
    #297
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They were accidentaly deleted.
  18. Dec 31, 2010 at 11:02 AM
    #298
    Leggo
    Newton,Ma.
    tranfer case "spacers" to bring the case down and reduce the cv joint angle that was increased when lifting? I just think of spacers and shims as the same thing.
  19. Jan 6, 2011 at 3:41 PM
    #299
    chugchug
    chugchug Well-Known Member
    Will
    Frederick MD
    2012 Toyota Tundra
    Well Chris your just going have to come to MD help me do mine and we can replace your pictures
  20. Jan 6, 2011 at 4:45 PM
    #300
    gov875
    gov875 WahooTaco
    Pacific Beach, CA
    TRD Sport DCLB
    Wet Okole's (front & rear), Weathertech Floormats (front & rear), cheap tailgate theft mod, extra d-rings, low profile toolbox (flat black), Thule Roof Rack (58" load bars), Thule Ski/Snowboard Roof Rack, Blacked Out Badges, Fishing Bobber Trailer Ball Cover, AVIC-X930BT w/ XM & steering controls, 5100s All Around (front set at .85), Eibach Coils, Rear TSB, rear AAL, LR UCAs, Toytec Diff. Drop, Mudflap Delete, Tailgate Reinforcement, Spidertrax (all 4), 285 Nittos, Rear Diff Breather Extension, TRD Exhaust, Powered Rear Sliding Window, DeeZee Bedmat, rear-view anytime mod, trailer bracket relocate, fog light anytime mod, redline hood struts, Satoshi with Homertaco Custom TRD Mesh, Hella 500s behind the grill, Brighter Reverse Lights
    if you're coming to MD to help him you may as well help me since i'm in MD too... just sayin
