How to: Front shock/spring removal
Discussion in 'Suspension' started by chris4x4, Mar 28, 2009.
  1. Apr 11, 2011 at 12:53 PM
    #321
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I have to agree
  2. Apr 11, 2011 at 12:55 PM
    #322
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    :eek:
    :eek:
    :pout:
  3. Apr 11, 2011 at 1:52 PM
    #323
    gov875
    gov875 WahooTaco
    Pacific Beach, CA
    TRD Sport DCLB
    Wet Okole's (front & rear), Weathertech Floormats (front & rear), cheap tailgate theft mod, extra d-rings, low profile toolbox (flat black), Thule Roof Rack (58" load bars), Thule Ski/Snowboard Roof Rack, Blacked Out Badges, Fishing Bobber Trailer Ball Cover, AVIC-X930BT w/ XM & steering controls, 5100s All Around (front set at .85), Eibach Coils, Rear TSB, rear AAL, LR UCAs, Toytec Diff. Drop, Mudflap Delete, Tailgate Reinforcement, Spidertrax (all 4), 285 Nittos, Rear Diff Breather Extension, TRD Exhaust, Powered Rear Sliding Window, DeeZee Bedmat, rear-view anytime mod, trailer bracket relocate, fog light anytime mod, redline hood struts, Satoshi with Homertaco Custom TRD Mesh, Hella 500s behind the grill, Brighter Reverse Lights
    agree until you help me do my install in a couple months in MD... yes i'm still harpin on that one.
  4. Apr 11, 2011 at 3:04 PM
    #324
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Alright, But if Im banned....You have no way to get ahold of me. :cool:
  5. Apr 11, 2011 at 3:08 PM
    #325
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    I do:cool::cool:
    BTW if you're in MD, your ass is coming to help me first:cool::cool::cool:
  6. Apr 11, 2011 at 3:12 PM
    #326
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Actually....I belive he called Deebs. :cool:
  7. Apr 11, 2011 at 3:15 PM
    #327
    rex99
    TArdCOMAWORLD
    Proton Cruiser
    This is my care face >>>>> :cool:
  8. Apr 11, 2011 at 3:15 PM
    #328
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Mine too. :cool:
  9. Apr 11, 2011 at 3:16 PM
    #329
    rex99
    TArdCOMAWORLD
    Proton Cruiser
    :cool:
  10. Apr 27, 2011 at 2:22 PM
    #330
    thebottomline
    thebottomline Well-Known Member
    Pac NW
    11 sport
    very disappointed to see the pics deleted......
    Dammit internet, you let me down!!!!
  11. Apr 27, 2011 at 2:43 PM
    #331
    DocCisco
    DocCisco Well-Known Member
    David
    Utah County, UT
    LB TRD Sport 4x4
    Subbed for the great pictures in the original post. ;) And because I want to do this some day...
  12. Apr 28, 2011 at 8:24 AM
    #332
    gov875
    gov875 WahooTaco
    Pacific Beach, CA
    TRD Sport DCLB
    There's probably enough Chris to go around in MD... if not, like he said, got deebs :p
  13. May 14, 2011 at 7:36 PM
    #333
    monkey wrench
    monkey wrench Well-Known Member
    sean
    somerset, ca
    stock 4x4
    new stereo, rear leaf tsb, front 5100s @ .75. weather tecs and wet okoles.
    I just installed some 5100s with stock coils on my 2011 ac 4x4. I set them to .85 to level out the truck after the tsb to the rear was done.
    I just wanted to say thanks for all the info in this thread. it made the job very easy. 4 hours total including clean up.
    here's an after shot. 1.5" of rake.
  14. May 28, 2011 at 9:09 PM
    #334
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    is this way really that simple? all he did was loosen the cam bolts on the lca and the knuckle bolts.
    wouldn't you still have to disconnect the ball joint on the uca and sway bar and shit?
  15. May 28, 2011 at 9:52 PM
    #335
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats the easiest way to do it if you have the truck on a lift.
  16. Jun 28, 2011 at 5:40 PM
    #336
    Kernel
    Kernel Well-Known Member
    Ohio
    09 TRD Off Road 6sp Manual
    5100's all 4 corners, front at .85 with Eibach Coils, Rear TSB w/AAL, TRD Catback Exhaust, AFE Pro Dry S, Duratracs, redline hood struts, maglight mod, weathertechs
    What does that LCA cam bolt get torqued to? I didn't see them say on the vid. Going to try this method Sat. Seems simpler than how I did this last time.
  17. Jun 29, 2011 at 6:55 AM
    #337
    zschneider956
    zschneider956 New Member
    Zach
    Baton Rouge
    05 TRD offroad
    New to the sight and this thread has been a huge help!
    I just finished replacing my stock bilsteins with the adjustable 5100s and my ride has improved dramatically.
    Unfortunately I had to set them at the lowest setting because I wasnt able to get either UCA bolt to release, and I didnt have the clearance to adjust the strut any higher...I tried hiting it out with a hammer and a piece of wood, working it with a padded pry bar from the top, and using a C clamp....and every combination of the 3.
    Does anyone have any suggestions as to how I can get the UCA bolt to release?
    It seems like it is just stuck up there for good, and I really would like to get an extra 1.5 in in the front.
  18. Jun 29, 2011 at 6:59 AM
    #338
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    Yeah they are usually pretty tough to get out. Just soak it in some PB blaster and take a hammer to it. It will eventually some out.
  19. Jun 29, 2011 at 7:01 AM
    #339
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    Right with an 05 yours has been together for 6 years, it is going to take some hammer blows to pop off. As I remember right I used a rubber mallet.
  20. Jun 29, 2011 at 7:02 AM
    #340
    rmb_crew
    If you have one use a dead blow hammer.
