How to: Front shock/spring removal
Discussion in 'Suspension' started by chris4x4, Mar 28, 2009.
  1. Feb 9, 2012 at 9:46 PM
    #401
    nobody4343
    nobody4343 Well-Known Member
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    hid headlights, black spyder jdm headlight housings, black jdm led spyder taillights, full led bulb swap, hid foglights, 3 inch pro comp lift, black out emblems, two 4 inch hid lights mounted behind the satoshi, wade vent visors, black westin nerf bars, black stubby antenna, k and n cold air intake, flowmaster delta 50 dual exhaust custom black tips, color matched satoshi grill with custom emblem
    ^ hmm gnna try that first then will it be harder to shove back in there sinc it's gnna be a larger shock and coil
  2. Feb 9, 2012 at 10:05 PM
    #402
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Yeah I get that, as long as your not over 3" (which of course you wont be 'cause you'd have a drop bracket involved) My 5100's set at top is just under 3" & the assembly will go up same way with just a little effort..
  3. Feb 10, 2012 at 5:56 AM
    #403
    nobody4343
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    Ok I'll try to shimmy em out first then gnna start installing when I get of work today
  4. Feb 13, 2012 at 5:19 AM
    #404
    Gregoryk
    Gregoryk Well-Known Member
    Greg
    tri cities, TN
    05 SR5 4x4
    bandsaw, Impact wrench, PB blaster made the job easier. 22deg weather was a royal pain to work with. Dealing with shocks that have been on the truck for 136,000 miles and 6 years in NE PA weather, spring for new hardware (rubber and washers) on the upper shock mounting area. I re used mine, but would of been so much easier if I did not have to salvage the old hardware.
  5. May 1, 2012 at 7:51 PM
    #405
    JTaco386
    JTaco386 Well-Known Member
    JT
    San Antonio, TX
    13 DCSB TRD Sport 4x4
    The photos on the first page are not loading on my computer, it states "photo no longer available" can these be reposted? I'll be doing my install soon and this seems like a great reference
  6. May 1, 2012 at 7:58 PM
    #406
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    They were accidentally deleted, and I cant get them back. Other members have posted pics in the thread, so you might have to use those.
  7. May 1, 2012 at 11:07 PM
    #407
    JTaco386
    JT
    San Antonio, TX
    Ok, thanks!
  8. May 28, 2012 at 5:47 PM
    #408
    Gene563
    Gene563 Well-Known Member
    Eugene
    Lanoka Harbor, NJ
    08 Double Cab, LB, TRD Sport
    TRD catback exhaust, Undercover hard tonneau, Vent visors, Husky liners, customized seat covers, front license plate bracket, rear suspension TSB, Eibach springs w 5100s@0, & General Grabber AT2 (265.70.17).
    Subscribed.
  9. Aug 26, 2012 at 4:49 PM
    #409
    TheWeatherman
    TheWeatherman Well-Known Member
    Northern Colorado, CO
    2022 TRD Pro
    Is a tie rod end puller needed to remove the tie end bar?
    The shocks should then just slide in not prying or anything?
  10. Aug 26, 2012 at 8:51 PM
    #410
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    No tie rod end pullers necessary. Disconnect the sway bar. The lower ball joint is a two-piece connected to the lower control arm with two bolts- removing them will lower the lower control arm enough to take out the shock/spring assembly. You will not have to remove the ball joint. Use a hydraulic jack to lower it down.
  11. Aug 26, 2012 at 9:04 PM
    #411
    Chuy
    Lakeside, CA
    Silver Taco
    Did everything go OK? For the benefit of others...the two bolts are on the ball joint that connect to the LCA. The ball joint is actually a two-part piece that separates. Kinda ingenious - this way you don't mess with removing the ball joint.
  12. Sep 21, 2012 at 4:08 PM
    #412
    1stTacoma
    1stTacoma Well-Known Member
    Rich
    Reno, Nevada
    '13 4x4 TRD OR
  13. Sep 24, 2012 at 6:01 PM
    #413
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    I agree, just did an install of OME 885 + Nitrocharger shock assembly. I did not need to remove the sway bar or take off the steering linkage. Just needed to raise the front of the truck up to provide 26" of clearance between the ground and the sway bar so the shock assembly could slide out once the LCA swings out of the way.
    Details: Loosened all the bolts first, three on the top of the strut, bottom shock mount to LCA bolt, LCA bolts at the frame (mark your current camber adj position) and the two bolts holding the LCA to the spindle.
    A 24" breaker bar, and WD-40 came in handy for this.
    Remove the bottom shock mount bolt, the LCA bolts at the spindle, push the LCA out of the way, and then remove the three nuts at the top of the strut. Spring & shock assembly slide out. Assembly is the reverse; use locktite on the bottom LCA bolts. Use antiseize compound on the remaining bolts and torque to spec. Torque the bottom shock mount bolt once there is weight on the assembly, when the truck is back on the ground. Three hours with no rush start to finish, by a non-mechanic.
  14. Jan 30, 2013 at 4:05 PM
    #414
    xyourlocaldjx
    xyourlocaldjx Well-Known Member
    you sir... are a life saver! after 30 minutes of hammering the shizzle out of the threaded part and searching for another 30 minutes... i read your post... two whacks and bam! it came right off. I yelled out loud "YESSS".
    my dog gave me a weird look. anyways. thanks!
    spoke too soon. the other side wont budge. I've whacked the living hell out of it and no cigar.
  15. Feb 16, 2013 at 10:12 PM
    #415
    phatso
    phatso Well-Known Member
    Eastern Washington
    2017 Cement Pro
    Kit came in today...rear is installed...
    here is what I have for the front...
    Am I missing anything?
    Will I be using anything from the original assembly?
    Edit: I think I missed this...
    NEW: We now offer Assembly with new top mounts and bushings for $100.00! Choose from options below.
    Am I screwed and have to order this...or can I use the old assembly...or can I get this from Napa or O'Reillys?
  16. Feb 16, 2013 at 10:52 PM
    #416
    Boost JuNkY
    Boost JuNkY Well-Known Member
    Billy
    Vancouver, BC
    2003 TACOMA DC OFF ROAD
    35'S ON 3s
    ^re use the oem top hats, bushings and spring isolator. You'd need a HD wall mounted spring compressor. I bought a portable clamshell style. Didnt work very well. Scratched the hell outta my eibachs before.
  17. Feb 16, 2013 at 11:01 PM
    #417
    phatso
    Eastern Washington
    2017 Cement Pro
  18. Feb 16, 2013 at 11:09 PM
    #418
    phatso
    Eastern Washington
    2017 Cement Pro
    Thanks to Chris4x4 and Boost JuNkY I now know I can use the original assembly...
    but how tight do I need to tighten the center bolt?
  19. Feb 17, 2013 at 7:28 AM
    #419
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    New shocks should have a hole in the top of the shaft that accepts a 5mm allen wrench, or it should be notched for a 5mm open wrench.
  20. Feb 17, 2013 at 8:27 AM
    #420
    Boost JuNkY
    Billy
    Vancouver, BC
    35'S ON 3s
    Nope, that bolt will bow on ya and possibly break. I had those that i used to use for honda civics and it got bent fairly easy on my tacoma.
    http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?R=BK_8271055_0006537861
    ^I have this type and it works, except the arms are too fat and will scratch the hell outta your coils. I grinded down the arms to make em fit. Ive only used it once ever. I just take the springs and use my shops compressor.
    This got me thinking about safety, I dont even compress the struts to release the spring tension, I just wedge the coilover against a wall and my impact gun wedge in by my heavy tires and let it rip. So far, no injuries but no way its safe. :D
