How to: Front shock/spring removal
Discussion in 'Suspension' started by chris4x4, Mar 28, 2009.
  1. Jun 9, 2014 at 2:07 PM
    #481
    AaronK13
    AaronK13 Well-Known Member
    Aaron
    Nebraska
    13 TRD Off-Road
    I have read ALL 25 pages of this and I just want to ask a few questions. I got the rear done just fine, but the front is where I had issues. I got the sway bar moved just fine, but the UCA is giving me one hell of a time. I tried hammering directly on the threaded pin and no budge. I read on page 9 i think, you need to hit the side of it with a hammer, right on the flat part. (orange arrow) Is that like a sweet spot that releases it? Kinda like tapping the 57 logo on an old kethup bottle? lol
    I also tried shoving a pry bar between UCA and spindle. (red arrow), but that didnt work either.
    If I cant get it, can I just disconenct the tie rod bar with a tie rod puller and that will give me enough room?
    Or, my dad that about removing the 2 bolts that hold in the LCA to the frame and having that swing open. I see that being an issue getting it back together.
  2. Jun 14, 2014 at 10:44 AM
    #482
    double_b
    double_b Well-Known Member
    Red Lion, PA
    '14 DCab Tacoma TRD Off Road
    Sorry, I just saw your reply to this thread. Not sure if you did your install yet but you are correct. You do not need to worry about spring pressure since you will be removing it while it is still assembled. Remove the 3 nuts around the top and remove the bottom shock bolt and it stays all assembled, no fear of the spring launching at you. lol
  3. Jul 6, 2014 at 9:56 AM
    #483
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Bump for some help here. Would also like to know
  4. Jul 6, 2014 at 12:14 PM
    #484
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Correct. the most dangerous part of this method is to ensure your truck is stable on the jack stands, as you have to get the truck up high to get enough clearance to drop the coilover out the bottom. Do not need to remove/loosen sway bar or disconnect steering.
  5. Jul 7, 2014 at 6:50 PM
    #485
    MTopp
    05 SR5 4x4
    I just did my lift today and this part was absolutely the biggest pain ever. I hammered in the spot you show, pried where you did and I finally took a piece of hard wood and put it directly onto the threaded part and hammered it. One side popped easy the other, not so much
  6. Aug 30, 2014 at 11:01 AM
    #486
    REEFDUP
    REEFDUP Well-Known Member
    Ron
    Gulf Shores,ALABAMA
    04 TACOMA 4DR 4WD V6 AUTO
    Pro Comp,Rock Stars/ BFG Rugged Trail
    I bought the new bushing kit when I bought my coils/struts, I've seen the diagram of the order that they go on a 2nd gen. but with the 1st gen . you're supposed to use both rubber bushings. Which bushing goes where? They're two different ones but cant find out if smaller one goes above top plate or the larger one goes above top plate.
  7. Aug 30, 2014 at 12:15 PM
    #487
    MTopp
    05 SR5 4x4
    Not sure, give me to around 5 and I have a very important update that will be very helpful.
  8. Aug 30, 2014 at 6:07 PM
    #488
    MTopp
    05 SR5 4x4
  9. Aug 30, 2014 at 6:40 PM
    #489
    MTopp
    05 SR5 4x4
  10. Aug 30, 2014 at 8:59 PM
    #490
    REEFDUP
    Ron
    Gulf Shores,ALABAMA
    Anyone?
  11. Aug 30, 2014 at 9:01 PM
    #491
    MTopp
    05 SR5 4x4
    Hmm, I'll try looking
  12. Aug 30, 2014 at 9:09 PM
    #492
    MTopp
    05 SR5 4x4
  13. Aug 30, 2014 at 9:11 PM
    #493
    MTopp
    05 SR5 4x4
    Well, that didn't help, but good for other use for you, I'll keep digging
  14. Aug 30, 2014 at 9:15 PM
    #494
    MTopp
    05 SR5 4x4
  15. Sep 23, 2014 at 8:49 PM
    #495
    MateoTorgy
    MateoTorgy Well-Known Member
    Mateo
    Minnesota
    2014 TRD OR AC 6 Cyl
    Unbelievable. This guy makes it seem so easy. Chris 2016.
  16. Sep 23, 2014 at 9:03 PM
    #496
    skygear
    skygear                    
    Lol math...
  17. Jan 24, 2015 at 6:47 PM
    #497
    TucTaco520
    TucTaco520 Well-Known Member
    Phil
    It's a dry heat
    11 Hooptie
    OME 90000s+887s, LR UCAs. AllPro Expos + 5100. KM Fab hybrid sliders w/kickout. KM Fab bed rack. 48" hi-lift. 16" FJ Trail Team wheels. 285/75/16 Hankook Dynapro ATMs. Magnaflow cat-back. K&N filter. TRD short-throw shifter. Murdered out via plasti-derp front grille and rear bumper. LED interior. De-badged tailgate. Rock lights (7). G2V 3x2 ditch lights.
    Just installed my front 5100s last night/today. What a marathon. I initially was trying to do the disassembly via jacking up the lca and unscrewing the top nut of the strut instead of the 3 surrounding it. I couldn't get a tight enough hold on the top part to unscrew the nut for the life of me. So I said screw it and took the whole assembly out. I was barely able to take it all out without disconnecting the lca from the lower ball joint assembly or disconnecting the steering tie rod end. I knew it would be hell trying to get the 5100 in there after swapping the coils over, especially cause I went for the biggest lift. So $50 later, I'm back trying to get these suckers in there. I honestly have no idea how anyone gets the tie rod ends disconnected from the rotor assembly!!!! I banged on the part that should drop the bolt right, bought a ball joint separator, banged on the castle nut while it was still on the bolt but noo. So the only other thing I thought to do was disconnect the two bolts on the underside of the rotor assembly that freed up the lca. I had to loosen the 2 bolts that connects the lca to the frame to free it up completely. The cam on the very back bolt got flipped over and I thought that was bad news, but the shop flipped it back over and the alignment seems legit.
    Here's my before numbers:
    Left caster: 2.1
    Right caster: .8
    Left camber: 1.0
    Right camber: .9
    Left toe: -.05
    Right toe: -.6 (I have minimal knowledge of how to truly interpret these readings but that seems like a huge difference.
    And the afters:
    Left caster: 1.6
    Right caster: 1
    Left camber: 0
    Right camber: -.4
    Left toe: .05
    Right toe: 0
    2 things I would like to know por favór:
    -How do these numbers look?
    -Do I need to get another alignment after adding a wheelers 1.5 aal, taking the overload out, and swapping for the rear 5100s?
    Appreciate the feedback!!
  18. Jan 24, 2015 at 8:10 PM
    #498
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Camber should match each other. Caster is low, but that can be corrected with new UCA's.
  19. Jan 24, 2015 at 8:52 PM
    #499
    TucTaco520
    Phil
    It's a dry heat
    11 Hooptie
    Thank you. Do I need an alignment after lifting the rear 1.5"?
    Brillo likes this.
  20. Jan 24, 2015 at 9:02 PM
    #500
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It cant hurt.
