How to: Front shock/spring removal
Discussion in 'Suspension' started by chris4x4, Mar 28, 2009.
  1. Jan 24, 2015 at 9:59 PM
    #501
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    No alignment needed when dealing with the rear suspension...
  2. Mar 5, 2015 at 9:38 PM
    #502
    grubburg
    grubburg Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    anybody have a link to the .pdf files? the links don't work.
  3. Mar 6, 2015 at 6:31 AM
    #503
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Pictures for anyone who stumbles upon the thread. Page 8.
    Dean724 and iK0NiK like this.
  4. Mar 6, 2015 at 3:12 PM
    #504
    300AACTaco
    300AACTaco Well-Known Member
    Black '15 DCSB TRD Off Road 4x4
    ARB Old Man Emu 90000s and 60091s OME 886s, Trim Packer, Icon Tubular Uniball UCAs, CMC, Invisible Sway Bar, Dakar Rear Leaf Packs, Timbren Rear Bumpstops, All Pro U-bolt flip up kit, Method Race Wheels NV 16X8 4.5BS, Cooper ST Maxx LT285/75/16, DEPO Black Tail Lights, Weathertech Floormats, Cascadia Vehicle Tents Mt. Shasta in Earth Tone Green, Custom Green Tree Fabrication Bed Rack, N-Fab Spare Tire Bed Mount
    :eek:The pics and both links to them are gone
    Edit: Never mind I found them
  5. Mar 6, 2015 at 5:57 PM
    #505
    MTopp
    05 SR5 4x4
    See my quote. The OPs pics are no longer available
  6. May 26, 2015 at 12:55 PM
    #506
    neverstuck
    neverstuck Well-Known Member
    Vancouver Island
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    A vid I saw for Toytec lift instructions showed some 'dude' dropping the assembled coil pack straight down without touching the sway bar, tie rod or nothing. https://www.youtube.com/watch?v=w58_1Ugk4KY&spfreload=10
    I am going to try that method but am curious why its not more popular. Just drop the LCA straight down hanging from the cam bolts and pull the shock/coil straight down. To do this, Im curious if I will have to back off the cam bolts. The mechanic in the video did not but I have read that you need to for them to swing that far down. Anyone have experience with that?
    El Tano likes this.
  7. May 26, 2015 at 1:09 PM
    #507
    TucTaco520
    TucTaco520 Well-Known Member
    Phil
    It's a dry heat
    11 Hooptie
    OME 90000s+887s, LR UCAs. AllPro Expos + 5100. KM Fab hybrid sliders w/kickout. KM Fab bed rack. 48" hi-lift. 16" FJ Trail Team wheels. 285/75/16 Hankook Dynapro ATMs. Magnaflow cat-back. K&N filter. TRD short-throw shifter. Murdered out via plasti-derp front grille and rear bumper. LED interior. De-badged tailgate. Rock lights (7). G2V 3x2 ditch lights.
    Yes, I loosened the cam bolts to the LCA to get the assembly out. One side was harder than the other-don't be afraid to give it some muscle. If possible, keep the cams pointing in the same general direction. There's two notches that keep them situated a certain way and it's harder to realign if they get spun around and what not.
    VE7OSR likes this.
  8. May 26, 2015 at 1:19 PM
    #508
    neverstuck
    Vancouver Island
    13 DCLB sport
    Thanks. My other concern I guess, is how high you have to lift it to be able to pull the assembly out the bottom. Using a floor jack and some 6 ton stands I'm hoping I can get everything high enough to clear them. I think that might be the reason people pull them out sideways rather than through the bottom.
  9. May 26, 2015 at 2:24 PM
    #509
    TucTaco520
    Phil
    It's a dry heat
    11 Hooptie
    The only jack stands I have are small ones that I used to use for my Subaru. You'll get it high enough, and the LCA doesn't need to be totally vertical to slide the assembly out.
    neverstuck[QUOTED] likes this.
  10. Sep 9, 2015 at 3:28 AM
    #510
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    All I need to do is lower the driver side spring enough to put a 1/4in spacer on it. Looks like the above method of just lowering the LCA would be best for that.
    Agree or disagree?
    EDIT:
    That was easy. Just took out the two bolts on the LCA ball joint and removed the sway bar brackets for more room.
  11. Oct 24, 2015 at 7:15 AM
    #511
    connor016
    connor016 Well-Known Member
    Goleta, CA
    2013 Tacoma TRD Off-Road Double Cab
    Just did this yesterday following the youtube video on post 507. I removed spacers and put on bilstein 5100s at 1.75. Didn't have to remove sway bar brackets or anything but did have to loosen the LCA bolts for it to swing down. Also I tried renting a strut compressor from Orielys auto parts and the ends that grab the coils are too large to fit between the coils when compressed so went to a shop and paid 25 each to swap them out. Was definitely worth going that route.
  12. Oct 29, 2015 at 1:34 PM
    #512
    sandyTrd87
    sandyTrd87 Well-Known Member
    Socal
    Bilstien 5100's x4 Dobinson 448 springs, rear 2inch AAL
    Did anyone get these pictures to get back up?
  13. Nov 8, 2015 at 3:21 PM
    #513
    joedirt
    joedirt Hallow
    Ploeśti
    2005 Tacoma
    Look up on YouTube for a video of removing the struts without a spring compressor. Worked great for me.
  14. Jan 22, 2016 at 3:16 AM
    #514
    smcgill
    smcgill Well-Known Member
    Sean
    South Easton Mass. not enough time in Cocagne NB
    Camry and Ram 1500 with a "HEMI "
    What is the ft-lbs for the upper ball joint nut?
  15. Jan 22, 2016 at 6:42 AM
    #515
    smcgill
    Sean
  16. Feb 25, 2016 at 3:16 PM
    #516
    pdx_climber
    pdx_climber Member
    Jeremy
    2007 Taco Access Cab V6 4X4
    Ive seen both answers so I figure I'll ask again :) Replacing the front struts with 5100's. Do I need to replace the 'isolator'/hardware as per something like toytec kit or can I reuse the original. 130K on the 07 4x4 Taco and planning for another 200K or so. No lift or heavy off-road use.
    I also read these are a pain to get out of the support assy.
    Any reason to or not to replace the whole setup (something like this http://www.amazon.com/KYB-SM5640-Insulator-Bushing-Washer/dp/B00C7S0KA8)
    http://toyteclifts.3dcartstores.com/Front-shock-replacement-bushingwasher-kit_p_35.html
    And per this image, in the toytec kit would I sandwich the cushion b/w the two retainers, and the blue circle is the black rubber washer, correct?
  17. Apr 13, 2016 at 9:19 AM
    #517
    TheTacoma
    TheTacoma Well-Known Member
    Birmingham, AL
    2017 DCSB, TRD OR 4x4, Quicksand. SOS Bolt-on Sliders. 285x75r16. Kings
    How could I see the pics in the original right up?
  18. Apr 25, 2016 at 3:18 PM
    #518
    bmgreene
    bmgreene Well-Known Member
    Brian
    L.A. Westside
    2010 PreRunner V6 SR5/OR
    Alcan Leaf Packs, OME884 Coils, 5100 shocks, U.S. Offroad Winch Mount w/Winch, Trail Gear Rear H/C Bumper, Prinsu Cabrack, DIY custom in-bed storage/sleeping deck, Sway bar delete, hidden "snorkel" intake mod, In-dash CB, Bestop Supertop, Undercover Swingbox, hood lifters, assorted lights and front spotting camera
    Has anyone installing Bilstien 5100s had issues with the lower rubber bushing fitting into the installation location on the suspension?
    I just did my rear end yesterday (new leaf packs and 5100 shocks), and one of the most frustrating parts was getting the bottom ends of the shocks into their mount points and lining up to install the bolts, the rubber on them was about 1/32 inch wider than the gap it's supposed to fit into and required a bit of hammering to get in into place, then a lot of prying/jockeying to get the bolt holes lined up well enough to get the bolts in. Just wondering if I'm in for more of the same in the near future.
  19. Apr 25, 2016 at 3:27 PM
    #519
    TucTaco520
    Phil
    It's a dry heat
    11 Hooptie
    Yep, you're not alone. I remember mine being a PITA for about 15 minutes a side. Used a thick screwdriver and mallet to finally get the bolt thru.
    sandyTrd87 and bmgreene[QUOTED] like this.
  20. Apr 25, 2016 at 10:46 PM
    #520
    NotRed
    NotRed Well-Known Member
    Jimbow
    Tennessee
    what he said - rubber mallet and prybar with spit :rolleyes:
