How to: Front shock/spring removal
Discussion in 'Suspension' started by chris4x4, Mar 28, 2009.
  1. Feb 7, 2018 at 8:14 PM
    #561
    Dhannah
    Dhannah 2017 Tacoma OR DCSB
    Daniel
    North Carolina
    '17 DCSB OR TRD 4x4
    Under Construction
    I guess there's not another one of these thread's? The pictures aren't on here?
  2. Feb 10, 2018 at 7:45 AM
    #562
    lo2hi
    lo2hi Well-Known Member
    Chiro
    Portland, Oregon
    2006 Impulse Red Tacoma 4.0L 6-Speed 4WD
    265/75R16 Falken Wildpeaks AT3W & KMC Enduros AFE air intake Bilstein 5100 & Eibach Springs & Ironman4x4 performance leaf Magnaflow 12866 muffler
    Pics on Page 8. I used that and a couple YouTube Videos.
    You just use your fingernails to remove the snap ring. I think you can use the video above too, in order to install those spacers. So you won't need the tool at all.
    I installed new billies and eibach springs on mine.
  3. Feb 10, 2018 at 11:55 AM
    #563
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    Thank you
    lo2hi[QUOTED] likes this.
  4. Mar 29, 2018 at 3:04 PM
    #564
    jafrisi
    jafrisi Well-Known Member
    Tucson, AZ
    14 Superwhite DCSB TRD OR
    Toytec bilstein 5100 lift w AAL. 2.5 front and 1.5 rear. KMC turbine wheels 4.5 bs, BFG KM3s 285/75/16
    Another helpful write up, Chris! When I did mine I struggled to get the coil assembly in or out. You may have to pry down that LCA and move the UCA around to slide that coil into place. We found that lifting the UCA (by hand) up and prying the LCA down (prybar) was the best bet for clearance. As you move the control arms around you should get the clearance needed to easily slide the coils into place.
  5. Mar 29, 2018 at 6:06 PM
    #565
    Reddog72
    Reddog72 Member
    Justin
    2008 Tacoma Quad Cab TRD 4x4
    Great write up. Would love to set the pics too. Link no workie...
  6. Mar 29, 2018 at 11:24 PM
    #566
    lo2hi
    Chiro
    Portland, Oregon
    page 8 #154
    I had to use this way for the driver side, since the top bolt stripped. I used the no spring compressor method for the passenger side. Video is on youtube.
  7. May 3, 2018 at 8:33 AM
    #567
    White Shadow
    White Shadow Well-Known Member
    San Diego
    05 PreRunner
    Stock as it gets
    I'm a bit confused now.... I've been running a 3" spacer with 285 tires for years. Now it's time to replace my struts and shocks all around. I bought Billies 5100's from ORW and they told me I won't need to use the spacer anymore if I set the Billies at 2.5"
    Question..... Am I going to loose 1/2" and possible rub if I don't use the spacer?
    My plan was to set the Billies at 0" and keep using the 3" spacer. I also don't do any off-road, mostly street and highway driving. Thanks!
  8. May 3, 2018 at 9:27 AM
    #568
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    If you really wanted to you could use the spacer and set the billies at zero. I suggest spending a lil more money and getting a lift coil and a 1/4" spacer on the drivers side and 1/8" spacer on the passenger side to get a full 3". Or cancel your order put some oem struts on with the spacer.
  9. May 3, 2018 at 9:42 AM
    #569
    White Shadow
    San Diego
    05 PreRunner
    Stock as it gets
    Thanks for the quick reply.
    I already have the struts/shocks and been sitting in my garage for two/three weeks and was planing on install them this weekend.
    So you're saying I will not get the same height with just the Billies?
    I can install them at zero and add the spacer until I get the lift coils and 1/8" - 1/4" spacers
  10. May 3, 2018 at 10:04 AM
    #570
    TacoTRD78
    Stuart,fl
    If you install them at zero with the spacers it should put you at close to 3" however the 5100 is designed to be adjustable and if you wanted just the strut with a spacer you could have gone a cheaper route.Do a pre measure from center of hub to bottom of fender than do a post measure you should be very close.
  11. May 3, 2018 at 9:18 PM
    #571
    White Shadow
    San Diego
    05 PreRunner
    Stock as it gets
    I don't want the spacers anymore and that's the reason I went with Billies 5100 but I can't go lower than the height I currently have with the spacers because I'll rub unless setting the Billies to the highest 2.5" setting will keep it the same height, then I'll toss the spacers. Should I do a search here to see if anyone is running 5100's at the highest set with 285 tires?
  12. May 3, 2018 at 10:40 PM
    #572
    El Tano
    Pasadena. CA
    10 Tacoma TRD sport
    I used to have spacers and because eeeeeeverybody said that they are crap so 2 years or so ago I decided to install billies, remove the spacers and set the billies at their highest point. I didn’t like the ride since day one, but since everything was new I wasn’t going to spend the money to go back. 2 months ago it came the time to replace my tires and I decided to get 285’s. They rub going fast into a driveway and when turning in reverse and mud guards have to go. I want to install the spacers again to see if it helps until I have time to do a CMC but I’ve been so fricking busy that I couldn’t do it yet.
    Also please note that an alignment may help. No idea how much caster I have.
  13. Jun 25, 2018 at 4:41 PM
    #573
    Skierrichy
    Skierrichy MadRad
    Richard
    Willington
    2011 TRD
    To many, but never done
    @chris4x4 hey I'm looking to do mine and wondering if you have those pics still. I can't see anything on the links either.
  14. Jun 25, 2018 at 4:43 PM
    #574
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    No, photobucket lost my pictures.
  15. Jun 25, 2018 at 4:44 PM
    #575
    Skierrichy
    Skierrichy MadRad
    Richard
    Willington
    2011 TRD
    Bummer I liked your directions though thanks
    chris4x4[QUOTED][OP] likes this.
  16. Jun 25, 2018 at 7:10 PM
    #576
    MrBrose
    MrBrose New Member
    Ambrose
    2005 Tacoma
    Skierrichy likes this.
  17. Oct 19, 2018 at 3:43 PM
    #577
    81shark
    81shark Well-Known Member
    It's all fun until the lower shock bolt "welds" itself to the bushing sleeve
    PzTank likes this.
  18. Oct 24, 2018 at 11:11 AM
    #578
    dualstroke
    dualstroke Well-Known Member
    2017 OR AC
    Excellent write up. Thanks for the info n pics
  19. Dec 26, 2018 at 9:04 AM
    #579
    Orangebikes
    Orangebikes New Member
    Is this process on the same on the 3rd Gen's?
  20. Dec 26, 2018 at 9:34 AM
    #580
    dozer711
    dozer711 Well-Known Member
    Upstate, NY
    '19 SSM Limited, '09 DCSB MGM OR
    Yes
