How to: Front shock/spring removal
Discussion in 'Suspension' started by chris4x4, Mar 28, 2009.
  1. Jul 26, 2009 at 6:49 PM
    #101
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You fly me there, and I'll weld them up for ya! Hell.....I'll even supply my own drinks! :D
  2. Jul 26, 2009 at 10:00 PM
    #102
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    got it all apart fine, the new OME stuff is sitting in my garage awaiting my local auto shop to open in the morning so they can take it to them to break down the factory struts and assemble the new stuff. Then its back to the garage to reassemble everything into the truck. Cant wait to see how it rides without the stock shocks and spacer lift on it. :)
  3. Jul 27, 2009 at 6:03 AM
    #103
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Make sure they re use the stock washers off the front shocks. THere is 3 of them. they go on the OME shocks the same way.
  4. Jul 27, 2009 at 10:49 PM
    #104
    RelentlessFab
    Eric
    Sparks, NV
    What an amazing transformation. So much smoother with the new OME shocks and coils. And I picked up about 3/4" of lift on the front, even with the bumper and stuff. Really happy with how it turned out for not spending even more on a set of coilovers.
  5. Jul 28, 2009 at 6:00 AM
    #105
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  6. Jul 30, 2009 at 5:25 PM
    #106
    bjamison01
    bjamison01 Member
    Brent
    Sacramento, CA
    09 Taco DC 4x4 Sport
    Icon C/Os, TC UCAs, Rear Billie 5100's, Toytec AAL, Shim, Moto Metal 955's (machined), Nitto TGs 285/70/17.
    looks like the photos are no longer available on the first page. Any chance they can be restored? Thanks in advance.
  7. Jul 30, 2009 at 8:36 PM
    #107
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Interesting...I'll have to find them.
  8. Jul 30, 2009 at 8:38 PM
    #108
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    CRAP! I accidentally deleted them ! :( I'll see what i can do about getting some more.
  9. Aug 2, 2009 at 4:46 PM
    #109
    BlueTaco
    BlueTaco Well-Known Member
    Long Beach, CA
    08 Tacoma Speedwayblue
    Question: Had a hell of a time getting the castle nut back on the ball joint, had to use a pair of pliars to hold it in place, while doing so, accidentally squeezed a bunch of grease out of the joint, anything I should do, or should it be fine?
  10. Aug 2, 2009 at 4:48 PM
    #110
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Depends on how much grease....If it was less than a table spoon, you should be fine.
  11. Aug 2, 2009 at 5:52 PM
    #111
    BlueTaco
    Long Beach, CA
    alright, i dont think it was more than that, thanks chris
  12. Aug 2, 2009 at 6:10 PM
    #112
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  13. Aug 5, 2009 at 7:28 PM
    #113
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    With basically limited mechanical ability I'm stuck having trouble getting the OME 885s in. ITs like right there and according to some previous posts I can just stand on the rotor? I tried forcing it down, the brake line bolt is lose so it has flex, but I coundn't get the damn bottom of the shock to seat in that cup that the bolt goes through...check out the pics am I doing anything wrong? Yeah I know I have to regrease the top ball joint, and put the boot back on.
    Is the spring facing the right way? Thanks in advance
  14. Aug 5, 2009 at 7:31 PM
    #114
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    I left my uca on and used my stock bottle jack between the fender well and uca. I cranked it and it pushed the lca down
    gregzz likes this.
  15. Aug 5, 2009 at 8:09 PM
    #115
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Everything looks to be in line. You try what JDkeller is saying, Or loosen the lower control arm bolts to free up some extra movement.
  16. Aug 5, 2009 at 9:12 PM
    #116
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    Chris, if you want to get pictures back in this, I'll give you a call when I get to redoing mine and we'll snap some shots :)
  17. Aug 6, 2009 at 5:55 AM
    #117
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
    Chris, so your suggesting taking out these two bolts and once the shock is in I can use a bottle jack to get everything together right?
  18. Aug 6, 2009 at 6:14 AM
    #118
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Sounds good. Its too dam hot to take mine off again.
    NO! The 2 bolts Im talking about ar the ones that attache the spindle to the lower control arm.
  19. Aug 6, 2009 at 11:50 AM
    #119
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
    Ok gotcha, hopefully last question on this pic is the lower coil end facing the right way?
  20. Aug 6, 2009 at 11:53 AM
    #120
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Looks correct.
