How to: Front shock/spring removal
Discussion in 'Suspension' started by chris4x4, Mar 28, 2009.
  1. Aug 9, 2009 at 9:41 PM
    #121
    docuw
    docuw Active Member
    SLC, UT
    09 Tacoma DBL TRD Offroad
    3" Lift: Front - OME 885 Springs with N140S, Toytec 1/2" Spacer; Rear - TSB Leafs with Toytec TSB AAL and OME N182S. Total Chaos UCA's, Access Tonnaeu Cover, Dynolock Tailgate Lock, Polished Aluminum Bull Bar, Bed Mat.
    Chris - The photobucket pics seem to be gone... any way to get them back? I'm doing my lift this weekend. Thanks!
    hoverlover likes this.
  2. Aug 10, 2009 at 5:53 AM
    #122
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I accidentally deleted the pics. I'll have to get some time and take more. Sorry buddy.
  3. Aug 10, 2009 at 3:56 PM
    #123
    redraider
    redraider Well-Known Member
    Eric
    San Antonio,TX
    BOO this man, :laugh:
  4. Aug 20, 2009 at 10:19 PM
    #124
    VolNut
    VolNut Well-Known Member
    Rick
    TN
    Pics back would be awesome when you get a chance. Just ordered my 5100s for the front and waiting on my TSB for the rear. Thanks!
  5. Aug 21, 2009 at 6:22 AM
    #125
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Links to the FSM attached.
  6. Aug 25, 2009 at 12:12 AM
    #126
    chad68
    chad68 Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
    Is it totally neccisary to lift both front wheels off the ground at the same time or could you do one side at a time using 1 jack stand?
  7. Aug 25, 2009 at 9:17 AM
    #127
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    It's not necessary to have both wheels off the ground but it would make the installation quicker doing both side at a time rather than just one side.
  8. Sep 12, 2009 at 7:40 AM
    #128
    virgilus11
    virgilus11 Well-Known Member
    kearny, nj
    09 sr5
    TRD supercharger,EMU 884 springs, 90000 shocks, air bags rear and TSB with EMU shocks, grillcraft mesh, Relentless front bumper,Armology rear bumper, byxenon hid's retro ,undercover lid with bike rack on top, Kenwood dnx9140,TRD cover seats
    He is right but I think that you have to remove (loosen up both the bolts on the end links) sway bar before you can work one side at a time. Remember the function of the sway bar ???. I believe that you have to loosen up completely anyway if you install Icon' or other coils over in order to install the spacers. It is really not complicated at all. Just follow Cris instruction. I watched them help a lots of guy's here on the forum and they are VERY good.
  9. Sep 12, 2009 at 7:46 AM
    #129
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Correct. Lifting both sides just makes it more easy. :)
  10. Sep 12, 2009 at 3:20 PM
    #130
    chad68
    Chad
    Guess I should stop trying to be cheap and invest in two jack stands instead of one ha. I need to rotate my tires this weekend or next anyway.
  11. Sep 17, 2009 at 7:59 PM
    #131
    tim920
    tim920 Never seen Forest Gump
    Tim
    Boston, MA
    2005 4Runner Limited V6
    27K worth of mods on your 350Z but won't spend nearly $30 for another jack? :D
  12. Sep 27, 2009 at 4:54 PM
    #132
    Optimus2009
    Optimus2009 Well-Known Member
    '09 DC 4x4 OR
    Bilstein 5100s x 4, Fabtech 1.5" AAL, Pioneer DMH-W4660NEX, SiriusXM, Console Vault
    Is there a trick to removing the front stabilizer bar? I am assuming removing the engine under cover sub assembly allows you to do so, but I am not sure what the entire sub assembly consists of? Is it just the thin metal pan looking think or is there more?
  13. Sep 27, 2009 at 4:56 PM
    #133
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Just remove the front skid plate, and there are 2 brackets. One on each side. I think they are 10mm bolts. Remove them, and the sway bar will come free.
  14. Sep 27, 2009 at 5:00 PM
    #134
    Optimus2009
    '09 DC 4x4 OR
    I saw those and removed them, but do to the shape of the stabilizer bar it is not coming out easily. Does removing the link assembly from the stabilizer bar make it any easier?
  15. Sep 27, 2009 at 5:01 PM
    #135
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It needs to be disconected from the spindles....It should come right out. If its not, you missed something.
  16. Sep 27, 2009 at 5:10 PM
    #136
    Optimus2009
    '09 DC 4x4 OR
    it just took some manipulation to get it out of the way. thanks for the help, I am afraid this will probably not be the last question. I am trying to take as many pics as possible though, so maybe me can repopulate the missing ones.
  17. Sep 27, 2009 at 5:12 PM
    #137
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    I'll take new Pictures for this thread next weekend :)
  18. Sep 27, 2009 at 5:13 PM
    #138
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Cool! Pleasae be detailed as you can. Dont get drunk halfway thru, and post a shit load of empties.
  19. Sep 27, 2009 at 5:14 PM
    #139
    TacoNut
    Adam
    Denver, Co
    :eek:
  20. Sep 29, 2009 at 5:37 AM
    #140
    Optimus2009
    '09 DC 4x4 OR
    The 5100s are on all four corners now. I can't thank all of you that contributed to this thread enough. I haven't gone back through all the pics yet, but I do want to get them up soon. I have some lessons learned of my own and I will consolidate those. To anyone out there considering the same project, read the entire thread first. Many of the posts saved me some time and heartache and others I should have heeded a little more. For me, the task was daunting at first, but I had a blast and I feel as though I have a more intimate relationship with my truck (like getting to third base). I encourage others to do the same, with the prior research of course. Thanks again guys.
