How To: How I Cleaned Rust Out Of A Paint Chip
Discussion in 'Detailing' started by jeremy_283, Feb 11, 2012.
  1. Feb 11, 2012 at 11:43 AM
    jeremy_283
    jeremy_283 [OP] Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    This is the best way I could figure out to clean out a rusted paint chip.
    Supplies Needed:
    Fine Pick
    Dowels
    Hot Glue Gun
    Fine Sand Paper
    Masking Tape
    Something To Cut Dowels With (snips for me)
    MicroFiber Cloth
    WD-40
    Scissors
    Steps:
    1. Tape off around rust
    2. Cut dowel
    3. Cut piece of circular sandpaper
    4. Add dab of glue to end of dowel
    5. Put sand paper on end of dowel, DO NOT PRESS FIRMLY... I felt the glue would contour to the the body and chip somewhat
    6. Start using the dowel and sandpaper on the chip in either a circular or cross hatch pattern
    7. You can also use your finger with sandpaper on it
    8. Whatever the sandpaper doesn't get around the edged just scrape it with the pick.
    9. Pull tape off
    10. WD-40 the area and wipe it down with the micro fiber cloth real good to get any rust you may have left
    11. DONE
    Note: I really feel I could have prolly just done most of this using just the pick but this was also my first attempt. It turned out pretty good though an the sand paper smoothed out the edge the chipped paint created.
    For now I am covering up the chip with some electrical tape until the weather gets a little warmer then I will apply the touch up paint.
