How to install a Old Man Emu Lift on Tacoma Video
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Low Range Off-Road, Mar 27, 2017.
  1. Apr 3, 2017 at 8:38 AM
    LiquidDragon
    LiquidDragon Well-Known Member
    Michael
    Williamsburg, Va but now in the Philippines
    2021 Toyota Hilux Conquest 4x2
    none yet
    I will be doing this install when I get back home in June. thanks for the video
    James at Lowrange likes this.
  2. Apr 3, 2017 at 10:01 AM
    James at Lowrange
    James at Lowrange Well-Known Member
    200 miles from Moab
    No problem let us know if you have any questions.
  3. Apr 3, 2017 at 10:11 AM
    goose443
    goose443 Well-Known Member
    Austin
    Texas
    2016 Tacoma TRD Off Road 4x4
    How does this lift compare to other ones such as the toytec boss? which is about the same price except it has adjustable coil overs
  4. Apr 3, 2017 at 10:21 AM
    Horger12
    Horger12 Well-Known Member
    Albuquerque, NM
    2017 Barcelona Red OR-DCSB
    5100s, Toytec AAL, Falken Wildpeaks, CaliRaised Ditch Pods, BAMF Sliders and Bed Bars
    I will definitely be doing this in the future.
  5. Apr 3, 2017 at 10:35 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    I believe the toytec boss is repackaged, nicer version of the 5100 bilstein shock hence the adjustable perches. I've heard good and bad things about the OME kit. Some people swear by it, others say they get a lot of clunking noises up front.
    My initial choice was the OME kit, but wound up spending some more coin to get the Icon stage 1 kit since they're rebuildable.
    goose443[QUOTED] likes this.
  6. Apr 3, 2017 at 11:21 AM
    goose443
    Austin
    Texas
    How're you liking the icon kit?? It isn't that much more expensive either
    rlx02[QUOTED] likes this.
  7. Apr 3, 2017 at 11:25 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    I love it. It's a big change going from the stock OR suspension since its a digressive vs progressive shock. It's a lot firmer at slower speeds almost like the TRD Sport. It handles MUCH better onroad...hardly any body roll or dive. Also, it eats up big bumps like nothing. It doesn't have that "plush" cadillac feel as the original OR suspension or any other progressive shocks but this is better if you do slow technical trails and want better on-road performance. I do tight technical trails out in the NW and didn't need remote reservoirs but wanted a little step up from OMEs after reading up on suspension. I also added their progressive AAL.
    The OMEs, Fox, Kings, etc are better for a softer on-road ride, and better dampening on fast trails out in the desert.
  8. Apr 5, 2017 at 10:10 AM
    easbaysav
    easbaysav Well-Known Member
    Eddie
    Central Valley, CA
    2019 TRD Off Road AC Cement
    Awesome post!
    Glad I found this last minute before installing my Bilstein 6112's the other day. I seen vids and how-to's for the 2nd gen which would've worked, but I thought this was the easiest way. Steps are pretty much the same as the vids showing how to replace the struts without a spring compressor, but I originally didn't want to loosen the alignment cam nuts. I marked the cams and they didn't even move out place so that made it easier.
  9. Apr 5, 2017 at 11:06 AM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    'bout ready to install my Icons on the Pro. I guess is the same procedure.
  10. Apr 5, 2017 at 1:08 PM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    Similar, but you don't need to disconnect the LCA or remove the tie rod as per instructions.
  11. Apr 5, 2017 at 2:59 PM
    Pportera
    Pportera Well-Known Member
    3rd gen.
    Disconnecting the sway bar mounts and lower ball joint bolts make the coil-over slide in like butter. I also find a 2x4x3 also comes in handy for prying that lower arm for just the 1/16 of an inch to start the bolts.
    Paul631 and James at Lowrange like this.
  12. Apr 5, 2017 at 3:29 PM
    Danactive
    Danactive Instagram: xxdanactivexx
    Dan
    Upstate New York
    2016 MGM TRD Sport 4x4 DCSB
    Check Out My Build Thread :)
    This will be perfect when I get back in a few months for my Dakar install... you guys just got my business! I'll contact you guys when It gets closer to my deployment ending and ill be ordering up some parts!
  13. Apr 6, 2017 at 11:36 AM
    easbaysav
    Eddie
    Central Valley, CA
    Forgot to ask this in my other post.
    Somebody on here posted the 2nd gen torque specs from Techstream or service manual and all the specs in the video were the same except for the alignment cam. In the vid, torque says 135 ft lbs, but the 2nd gen spec states 135 Nm or 100 ft lbs. Did it change for the 3rd gen?
  14. Apr 7, 2017 at 5:38 PM
    Sna
    Sna Well-Known Member
    Alberta
    ‘15 trd sport 6MT dcsb, mostly stock?
    Great install videos!!
    @Low Range Off-Road - I have some questions regarding the Dakars in the rear- will the OME u-bolts (black ones as seen) still be long enough if the D29XL AAL is installed into the leaf pack? Further to that, some recommend shims under the leafs, I'm assuming this was not done because there were no vibrations?
    Pportera likes this.
  15. Apr 7, 2017 at 6:05 PM
    #35
    Kwe1982
    Kwe1982 Well-Known Member
    Wisconsin
    Gone - Just a couple Tundras and a Sequoia
    Thanks for posting this, hopefully I'll be installing mine this summer.
  16. Apr 13, 2017 at 8:49 PM
    #36
    Pportera
    3rd gen.
    This^^
  17. Apr 13, 2017 at 8:51 PM
    #37
    Duggernaut
    Duggernaut New Member
    17 trd off road access cab
    Hey there! I'm very interested in this OME lift and I was wondering if 295/75r16 tires would fit? 33.4" x 11.6".
    Yay, first post
  18. Apr 13, 2017 at 8:56 PM
    #38
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Only with trimming. Lift alone will not fit tires.
  19. Apr 19, 2017 at 2:45 PM
    #39
    James at Lowrange
    200 miles from Moab
    Awesome we will look forward to hearing from you!
    Danactive[QUOTED] likes this.
  20. Apr 19, 2017 at 2:46 PM
    #40
    James at Lowrange
    200 miles from Moab
    Perfect you will love it.
