How to: Install Airflow snorkel and keep your TRD Intake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fosk, Mar 9, 2017.
  1. Mar 9, 2017 at 4:42 PM
    Fosk
    Fosk [OP] Well-Known Member
    Andrew
    Huntington Beach, CA
    Since I couldn't find any definitive solution and no one could/would offer one. Here is how I did it:
    Follow lemons guide for particulars on general install. I will cover only specifics to the TRD Intake and how I mated the snorkel to it.
    lemons's guide can be found HERE.
    First: Buy you one of THESE in 3.75" to 4". The 4" end will go to the TRD Intake, the 3.75" end will go to the pipe supplied with your snorkel.
    The elbow will go through the intake hole as so, with the 4" end inside the engine bay. I recommend removing your intake for this as I have....
    This is the 3.75" end on the other side waiting for the snorkel pipe:
    When it comes time to piece your pipe and fittings together to connect your snorkel to your intake, you are going to have to either modify the supplied Airflow elbow or purchase a 3.75" diameter pipe.
    I chose to modify the supplied elbow:
    One of the supplied elbows will connect to the snorkel housing and the other end to the hose. You then use your modified elbow or new pipe to connect the hose to the silicone elbow that is connected to your intake: (sorry, dark cell phone image)
    and that's it.
  2. Mar 9, 2017 at 9:27 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    good to know :thumbsup:
  3. Mar 10, 2017 at 4:35 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Why do guys need a snorkel ?
  4. Mar 10, 2017 at 5:26 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    I don't, just is good to know
  5. Mar 11, 2017 at 11:22 AM
    lynlan1819
    Tacoma
    Lifted
    I have heard some Tacoma owners are into drug smuggling,they drive down too Mexico and then use their snorkeled trucks too come back just off the coast with only the top half of the truck showing and the dope in the back.
