How To Install Optima Battery?
Discussion in '1st Gen. Tacomas (1995-2004)' started by O-Dubs, Mar 6, 2010.
  1. Mar 6, 2010 at 8:17 AM
    O-Dubs
    O-Dubs [OP] Well-Known Member
    Hi, i just got a optima yellow top and it wont fit in, whats the best way to make it fit, but longer cables, the negative as inches of slack and will fit on whatever side it ends up but the positive cable is way too short, i've searched on here and i guess they just dont fit without modification but i cant seem to find out what exactly the mods to make it fit were, any helps and maybe some pix would be greatly appreciated.
  2. Mar 6, 2010 at 8:27 AM
    ilovetacos
    ilovetacos Well-Known Member
    Gavin
    Sacramento/Woodland
    2006 TRD Sport 4x4 DC
    Sold!
    What model # did you get?
    I just installed a D34/78 and the terminal posts are reversed. I used the sideposts for the factory wires and am using the top posts for my amp. I did have to buy a 15" ground wire for the factory ground but the postive wires stretched without a problem.
    For mounting I used the factory tie down but also had to use the supplied plastic spacer from Optima but I just ordered this battery tray.
    But maybe it's different for 1st gens???
  3. Mar 6, 2010 at 8:28 AM
    TRDKenE
    TRDKenE DAMN GOOD DEAL!!
    Kenny
    Richmond, Virginia
    '10 D-CAB OFF-ROAD 4X4
    TRD CAI, GrillCraft.
    Suscribed:popcorn:
  4. Mar 6, 2010 at 8:31 AM
    SACTOWN
    SACTOWN ???????????????????????
    Greg
    '18 ZR2, 04 Rubicon, &19 lx570
  5. Mar 6, 2010 at 8:31 AM
    O-Dubs
    i've got the yellow top for the first gen, i dont know the number though, the terminals are reversed on mine as well but the negative cable has atleast 5 inches of slack but the positive cable is no where close, how easy is replacing the positive cable?
  6. Mar 6, 2010 at 8:33 AM
    ilovetacos
    Gavin
    Sacramento/Woodland
    Sold!
    I am not sure how easy it will be to replace the postive cable but you can always extend it. You just got to make sure you extend the correct way with the correct gauge of wire.
  7. Mar 6, 2010 at 8:35 AM
    O-Dubs
    my bad thats what i meant to say, how do you do that, is it something you buy or cut up myself and add some wire?
  8. Mar 6, 2010 at 8:53 AM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    I put a Red Top 34R in my Tacoma. The 34R has the terminals reversed and the cables reach the posts just fine. The Yellow Top D35 looks like it has the posts in the correct position for the Yota's.
    D34
    D35
  9. Mar 6, 2010 at 9:00 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    I put a red top 34R in my sons 02.
    No problem just used the spacers to fit it to the stock hold down.
  10. Mar 6, 2010 at 5:59 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    the red top 34 fits perfect in the first gens...
    for the yellow top, its supposed to be the D35... not sure why the positive cable isn't reaching...
  11. Mar 6, 2010 at 6:04 PM
    619Tacoma
    619Tacoma Baja bound
    Call me Rocco
    San Diego, CA
    07 PreRunner SR5, Sport, 4dr
    - Billstein 5100's all around with OME 885 coil springs. - K&N Air Filter - HID Headlights & Fogs - Kenwood Stereo & Infinity Speakers - CB Radio, - Fog On Anytime mod - Anti Tailgate theft mod. More comming...
    x2... I've been wanting to know this for a while.
  12. Mar 6, 2010 at 7:58 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    The Red Top **34R** (reversed posts) is the model that fits up on 1995.5 - 2004 Tacos 'as is'. The Red Top model 34 won't, because its posts are in the opposite positions from the OEM setup.
    Group 35 batteries also have their posts in the opposite orientation to the OEM setup.
