How To Install SumoSprings
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OffsetPlayer2, Aug 25, 2016.
  1. Mar 21, 2017 at 8:00 PM
    #61
    9TRDTCO
    9TRDTCO Well-Known Member
    Thanks for sharing, I have a 1inch block, wonder if I need the spacers. I'd like to close up the space for contact as well. Mind sharing how much you paid?
    IronPeak likes this.
  2. Mar 21, 2017 at 9:40 PM
    #62
    skatebass1958
    skatebass1958 Member
    09 Tacoma SR5 Speedway Blue
    SHHHHHHH
    So it looks like there is no difference between the 610-40 and 610-47 other than the capacity and ride quality (maybe). Both kits will work for tacomas. I'm I correct ?
  3. Mar 21, 2017 at 10:00 PM
    #63
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Both kits work for the tacoma but the 47 is intended for tundras
  4. Mar 21, 2017 at 10:38 PM
    #64
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Firestones can be deflated to 5psi and are adjustable upwards for more support as needed. Sumo springs are not adjustable so they're always stiff and will harshen the ride in the ass end.
  5. Mar 21, 2017 at 10:40 PM
    #65
    IronPeak
    AuggieX
    Back to Back
    The 610-40 sumo's are really soft, I got my hands on a set they are significantly softer than say Wheelers superbumps. I was able to compress the spring around 25% with just my hands. Kinda like a stiff nerf football.
  6. Mar 21, 2017 at 10:46 PM
    #66
    IronPeak
    AuggieX
    Back to Back
    Oh you haven't met @smitty99 ? No, he doesn't have a set.
    arnette64 likes this.
  7. Mar 21, 2017 at 11:03 PM
    #67
    IronPeak
    AuggieX
    Back to Back
    Oh so you have first hand experience with both. Thank you for your input, this information is useful. Sometimes people decide to go out of their way to comment on something they have never used or even seen in person. Usually these people have a negative bent to their posts. Actually almost all the time. Thanks again.
    :bananadead::bananadead::bananadead:
    otis24 likes this.
  8. Mar 22, 2017 at 1:38 AM
    #68
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    Pretty certain I have the tundra sumos, or the 47s. They're black in color unlike the blue I see most people running. Bought mine used so Im not certain.
    They're not any stiffer than I remember stock being.
  9. Mar 22, 2017 at 6:00 AM
    #69
    smitty99
    Scottsdale
    Yes had them on 2003 tacoma and they stiffened the rear end.
  10. Mar 22, 2017 at 6:06 AM
    #70
    smitty99
    Scottsdale
    Oh look here's another guy who had the same experience. https://www.tacomaworld.com/threads/lift-with-sumosprings.444699/#post-12991547
    And another https://www.tacomaworld.com/threads/2016-sport-ride.451183/#post-13237309
    :bananadead:
  11. Mar 22, 2017 at 4:52 PM
    #71
    insocova
    insocova Well-Known Member
    I forgot to add, when I talked with the engineer at SumoSprings, he was surprised that people with stock Tacoma's were reporting added lift in the rear. He told me that they aren't really intended to make contact without a load but should have a small gap which closes up and loads the spring when hauling or towing. He said the unloaded contact would not hurt anything in the long run but could tighten up the ride. I bought the spacers so my gap would be smaller but I don't expect them to make contact all the time.
    cctk2 and Marcmtb1 like this.
  12. Mar 22, 2017 at 4:54 PM
    #72
    smitty99
    Scottsdale
    The ones I ran did add a very slight lift IIRC.
  13. Mar 24, 2017 at 6:53 AM
    #73
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    Strange. Did he say anything about them trying to fix the problem?
    cctk2 likes this.
  14. Mar 24, 2017 at 7:10 AM
    #74
    cctk2
    cctk2 GLACIERBIRD
    Chip
    NorCal and Alaska
    '68 FJ40, '16 TRD AC OR A/T WHITE
    Accessories: SnugTop Rebel canopy AVS Window Rain Deflectors TACOMA 6' Bed Mat Weathertech Mud Guards (4) Scanguage (re-installed from the '02) Tekonsha Voyager Brake controller (Chalet A frame pop-up.) Vinyl letter insets for tailgate. Garmin CS60 GPS mounting. Other misc décor in the form of decals.
    Many thanks for an intelligent entry.
  15. Mar 24, 2017 at 11:16 AM
    #75
    Mudchomp
    Mudchomp Member
    Dixon, CA
    Thinking about adding these to my 2017 DCLB OR. Question: will these help with the driver's side lean? Right now, the damn truck leans a little on the driver's side (taco lean) , and if I can kill two birds with one stone by installing these to help with load hauling and to fix the leaning, cool.
  16. Mar 24, 2017 at 11:48 AM
    #76
    smitty99
    Scottsdale
    No
  17. Mar 29, 2017 at 9:32 AM
    #77
    cctk2
    cctk2 GLACIERBIRD
    Chip
    NorCal and Alaska
    This 'LEAN" I keep hearing about..... it is more promoted by the front end, the rear end, or both?
  18. Mar 29, 2017 at 9:35 AM
    #78
    smitty99
    Scottsdale
    Front lift (1/4" adjustment on drivers side) fixes it. For instance on new 3rd gen 6112s installation instructions call for staggering the clips on the valve body to be one notch higher on drivers side. 2nd gen 6112s called for a 1/4" spacer to be installed on the setup to adjust for it.
    It is promoted by battery, gas tank, etc, weight distribution based on design of the vehicle (Where these items are located)
  19. Mar 29, 2017 at 9:35 AM
    #79
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    The lean is caused by battery,and gas tank.All on drivers side.
  20. Mar 29, 2017 at 9:41 AM
    #80
    cctk2
    cctk2 GLACIERBIRD
    Chip
    NorCal and Alaska
    Maybe I don't experience it cuz I've got so much. Gas that is. Though I keep the dog kennel, tools, and tire chains on the right side.
