How to Install Toytec 1/4" spacer...
Discussion in 'Suspension' started by blktaco58, Oct 23, 2012.
  1. Oct 23, 2012 at 4:07 PM
    blktaco58
    blktaco58 [OP] Well-Known Member
    Hawaii
    2012 Tacoma 4wd V6 AC
    884X springs, 1.5" AAL, 16 x 8 MT Sidebitters, 265/75/16 Duratracs, BHLM, Painted Front Valence, Wet Okoles, USA SPEC ipod,
    did some searching around and couldn't find a write up...
    Im looking to install the toytec top plate 1/4" spacer which do not require longer studs...
    Anyone have instructions or pics of the install process....
    Never done this install before, but from what I gather:
    -jack up truck
    -unbolt bottom of shock/strut
    -lower the strut enough to pop the toytec top plate spacer in and revolt shock...
    am I missing something- do you have to disconnect sway bar or compress the springs.....???
    thanks
  2. Oct 24, 2012 at 11:20 AM
    blktaco58
    Hawaii
    thanks-
    anyone else who did this got any pointers or pics....
  3. Oct 25, 2012 at 11:45 AM
    blktaco58
    Hawaii
    Bump- i know there is some super knowledgeable guys on this forum
  4. Feb 4, 2014 at 9:18 PM
    Wingman4
    Wingman4 Well-Known Member
    Raleigh, NC
    2013 TRD Sport 4x4, 3" Pro Comp, 285/70/17
    Pro Comp 3" Coil Lift with Wheeler's .5" and .25" Lift Enhancers ARB Bull Bar, XRC 8 Dick Cepek DC-1 17x9 BFG AT KO LT285/70R17E Flowmaster Super 44 Undercover Tonneau
    Did you ever do this install? Attempting myself tomorrow and would prefer not die with a coil spring flying out at my face. Not really planning on going out like that.
  5. Feb 8, 2014 at 9:10 PM
    oh crap its him
    oh crap its him Well-Known Member
    Shannon
    Utah
    09 TRD OR
    OME 884, Bilstein 5100, LR UCA, bunch of other crap...
    i installed the 1/2" spacer which required longer studs, and now my truck rides like shit. Lesson learned and can't wait to get my lift. But then again my suspension is pretty much shot at this point.
    To answer your question, you don't remove the nut at the top if you aren't installing longer studs. Just pull the shock out, slide the spacer over the bolts on the top hat, and bolt back in place. May need an alignment though.
  6. Feb 9, 2014 at 9:03 AM
    Wingman4
    Raleigh, NC
    Thanks! What lift are you going with?
  7. Feb 9, 2014 at 11:29 AM
    oh crap its him
    Shannon
    Utah
    09 TRD OR
    I'm going with OME and LS UCA's. Keep in mind though that my suspension has close to 80k on it so it was sagging a bit lol. Adding the spacer was just a temporary fix until I had money for the lift.
