How to - Installing new Speakers in your 3rd Gen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SomethingNew71, Jul 4, 2018.
  1. Sep 5, 2018 at 4:09 PM
    #41
    Zrouge1
    Zrouge1 Well-Known Member
    Sold
    I went JBL GT series in the doors, the kicker tweeters in the corners. Sounds great using same volume as I did with stock.
    Lateralus01 likes this.
  2. Sep 7, 2018 at 9:58 AM
    #42
    SomethingNew71
    SomethingNew71 [OP] Well-Known Member
    Cole
    2021 Army Green Tacoma TRD Sport, 1960 Mini Cooper
    I think if you are happy with the volume the current unit can provide and the goal is more range you are going to be extremely happy with this upgrade. After the upgrade when I used to turn up to 49-50 now I only need 38-45. The sound is much more complete, most noticeable in the lows from my perspective.
    Lateralus01[QUOTED] likes this.
  3. Sep 7, 2018 at 11:17 AM
    #43
    Lateralus01
    Lateralus01 Well-Known Member
    2018 Cement Tacoma TRD OR DCSB 4x4
    Thanks Something. Thats exactly the response I was hoping to get.
    rene_weenie likes this.
  4. Sep 7, 2018 at 11:33 AM
    #44
    TRDandGlocks
    TRDandGlocks Well-Known Member
    Angel
    2021 TRD Off Road DCSB 4x4 Manual
    I just saw your post and impulse bought both front and rear speakers and the tweeters lol
    Edit: I been wanting to for a while, just needed that little push lol
  5. Sep 7, 2018 at 1:24 PM
    #45
    pillsburydoughboy
    pillsburydoughboy Well-Known Member
    ‘18 TRD OR DC MT
    Thank you for this post. I was nervous about taking off my door panels before putting an order through Crutchfield, since you can’t preview the included instructions.
  6. Sep 7, 2018 at 1:27 PM
    #46
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    Taking the door off is easy, hardest part is deciding how to install the speaker mounting adapter to the speaker so it fits the door mounting holes.
  7. Sep 7, 2018 at 2:33 PM
    #47
    TRDandGlocks
    Angel
    Would it not work if you mount the adapter to the door mounting holes first and then the speaker to the adapter? Or does the adapter and the speaker have to be connected before putting in the door?
  8. Sep 7, 2018 at 2:36 PM
    #48
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    I spent about an hour doing both.
  9. Sep 7, 2018 at 2:59 PM
    #49
    TRDandGlocks
    Angel
    Good to know, I will be doing mine soon.
  10. Sep 13, 2018 at 9:18 AM
    #50
    TRDandGlocks
    Angel
    I’m doing this today and I feel like the speaker doesn’t fit in the adapter or is that just me?
    Help lol
  11. Sep 13, 2018 at 9:30 AM
    #51
    Bchico14
    Bchico14 Member
    Brandon
    2016 Tacoma TRD OR DCSB
    I double layered my doors, and did the back wall and it’s noticeable, but not by much. Adding it to the stock speakers won’t do much because the point of the deadener is to add weight to your thinner pieces of metal to reduce vibration caused by heavy bass from aftermarket speakers.
  12. Sep 13, 2018 at 9:30 AM
    #52
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I think I had to drill a hole or two in those plastic adapters too.
  13. Sep 13, 2018 at 9:33 AM
    #53
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Yep so did I once I decided how to put the adapter on the speaker
    shakerhood[QUOTED] likes this.
  14. Sep 13, 2018 at 9:34 AM
    #54
    TRDandGlocks
    Angel
    Y’all got any close up pics of the fronts? Please?
  15. Sep 13, 2018 at 9:42 AM
    #55
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    1st post of the thread shows the speaker mounted, showing the screws slightly misaligned to the adapter, I think 3 of the 4 fit with drilling a 4th hole.
    I told you it took me an hour trying to decide how to mount the speakers to the adapter, now you know why. :D
  16. Sep 13, 2018 at 11:50 AM
    #56
    Deacon Blues
    Deacon Blues Well-Known Member
    Colorado
    2017 SR5
  17. Sep 13, 2018 at 11:52 AM
    #57
    Deacon Blues
    Colorado
    2017 SR5
    Oh and get ready to do the same pseudo customizing on the rears, they don't fit anything out of the box either.
  18. Sep 13, 2018 at 2:11 PM
    #58
    TRDandGlocks
    Angel
    I figured it out, thanks to everyone and the support
  19. Sep 13, 2018 at 3:46 PM
    #59
    boulderoffroader
    boulderoffroader Well-Known Member
    Colorado
    2018 TRD Pro
    Very helpful post. Today I installed the Kicker tweeters, front and back Kicker speakers, and Noico sound deadening using this writeup, the OEM video and one other post that escapes me right now.
    Thanks to TW members for making it so easy. The sound is an enormous improvement over stock, all for under 300.
    jss1975snow, shakerhood and dlo13 like this.
  20. Sep 16, 2018 at 1:44 PM
    #60
    jdr3366
    jdr3366 Well-Known Member
    I installed the tweeters and front door speakers this weekend on my 17TRDSport 4 door. Here's what I discovered. Hope this is helpful.
    It took lots longer than anticipated.
    Tweeters are pretty easy to install. It can be done without removing the A panel cover and disconnecting the battery, at least in my experience. It's easier to replace the speaker grille when the A pillar cover is already in place. Again, my experience.
    The front door speakers were not difficult to install but time consuming. It was not necessary to remove the green and white metal balls from the door handle. I just slipped the silver handle through the interior door slot. That saved me from trying to remember where the green and silver balls attach.
    I covered as much of the metal door with the sound deadening material as I could reach. I concentrated on the metal in back of the openings of the metal interior part of the door. I also added material around the edge of the plastic grill. Plastic interior, of course.
    I did not throw out the plastic that covers the door. Rather, I pulled it away so I could reach through the openings. Then I replaced it against the black sticky stuff, and then put deadening over the openings that the fiber material covers.
    The biggest challenges??? The frame to hold the speakers is a pain to position and screw in. I had to make a new hole in the frame. Careful not to puncture the speaker.
    The wires slide into metal connector at the speaker end nicely. The biggest problem was that the wire to use for the replacement speakers had just 2 bear wires at the other end. My solution was to push the wires into the original white plastic harness, tape it up, and now it works just fine.
    I was concerned about polarity, but there was nothing in the instructions or on the speaker clips to help me figure this out. So, I took a chance. For the front door, the negative wire from the speakers inserts into the harness opening that is next to the smooth edge of the harness. Sound is good.
    Took lots longer than I expected. Best not to rush.
    Nchatman82 likes this.
