How to lift a TRD PRO (a bit) w/ stock suspension
Discussion in '3rd Gen. Tacomas (2016-2023)' started by xGRIMEYx, Nov 5, 2018.
  1. Feb 18, 2019 at 11:57 AM
    #141
    protacodan
    protacodan Well-Known Member
    GILROY Ca.
    2017 Tacoma TRD PRO
    285/75/16 KM3’s. Cali Raised rock sliders Revtek 427AP lift kit Victory 4x4 Strike bumpers Warn VR8S winch
    i put my 285/75/16 KM3's on 2 months before the Revtek 427AP lift no rub even wheel'n.
    CJH9980[QUOTED] likes this.
  2. Feb 19, 2019 at 8:53 AM
    #142
    DansSr5
    DansSr5 Well-Known Member
    2016 Sr5 double cab silver 4x4
    P265/75/16 Destination AT stock wheels 12v socket bed pocket install diy Truck bed beer bottle opener No drill hidden/uv5r ham radio installed GoPro hero 5 session Center console organizer and top tray Front air dam delete Sidestep delete Add factory mudguards Recovery/equipment: Everything fits behind or under the seat Tool roll up bag Battery terminal cleaner Electrical grease for terminals Digital multimeter Alternator tester 4 gauge jumper cables Breaker bar with 19&21mm sockets Viair compressor Tire deflator Tire repair kit Tarp Hitch with d-ring Standard hitch 1 1/8 to 1 1/2 open ended hitch wrench Rope Ratcheting tie downs Tire gauge Cellphone charger wall/socket adaptors Gloves Recovery strap Crowbar Mighty might fishing pole Small tackle box First aid kit Michelin road atlas (4) 1 liter water bottles in rear doors 1 empty grey plastic ammo can (not sure what to put in it yet).
    I used these on my SR5 for a 1.5" lift up front. They work just fine! You will need a cutoff wheel for the studs to make them flush and fit.
    Pretty cool to find out these work on a PRO. They make the install SUPER EASY!
  3. Feb 19, 2019 at 6:07 PM
    #143
    ssmith0480
    ssmith0480 Well-Known Member
    Shaun
    Ringgold, GA
    2019 TRD Offroad
    Extended travel Kings, 650 coils Tundra Kings rear Icon AAL with 1/2” shim & Firestone airbags Total Chaos UCA’s ARB onboard air VTX Stinger 17x9 -25 offset Yokohama g003 MT 295/70/17’s RCI roof rack and bed rack TRD Pro skid TRD Pro tail lights R4T high clearance exhaust CBI Baja bumper Smittybilt xrc 9500 winch Dobinsons snorkel, Syklone precleaner Caliraised ditch lights, rigid covers 5.29 gears CVT Mt. Washington RTT Body Armor sliders ECGS bushing
    Yeah I had to cut the studs to sit level with the spacers. I figure these will be fine until I get some ADS/Fox/King coilovers later on. They seem to be working great so far. I always loved the Pro’s but I thought they just sat a little too low for my taste.
    Btw I just wanted to clarify that I didn’t come in here to shit on the Revtek spacers. But some people might not like the way they ride so I just wanted to share what I did.
    DRob likes this.
  4. Feb 24, 2019 at 1:22 AM
    #144
    ssmith0480
    Shaun
    Ringgold, GA
    2019 TRD Offroad
    Hey what did you do in the rear? I still have the single 1.5” add a leaf from the Revtek kit but was considering swapping it out for a 3 leaf progressive add a leaf. How’s the front setup...still working good for you?
  5. Feb 24, 2019 at 7:48 AM
    #145
    treimche
    treimche Well-Known Member
    Fargo, ND
    I actually have air bags in the rear. I put them in for leveling the truck while towing last year, so for the time being, they're pumped up enough to keep the truck level with the front. I have some blocks to install back there, but waiting until spring time. That will take some stress off of the air bags.
    For the front, it's good. It feels a little bit stiffer than stock, which it really shouldn't, but it does. Then again that could just be the fact that I put my aftermarket wheels and tires on that are 10 ply. I have some rubbing issues to take care of. Once in a while when turning the wheel I'm getting a small clunk, so I wonder if the stock upper ball joint isn't quite up to the task of this much lift. Considering getting some some aftermarket UCAs.
  6. Feb 28, 2019 at 1:21 PM
    #146
    Jes
    Jes Well-Known Member
    Knoxville
    2017 Taco TRD Pro Cement
  7. Feb 28, 2019 at 7:15 PM
    #147
    protacodan
    GILROY Ca.
    2017 Tacoma TRD PRO
  8. Mar 1, 2019 at 6:00 PM
    #148
    Jes
    Knoxville
    Others in this thread are using generic spacers on Pros. I guess I can always return it...
  9. Mar 1, 2019 at 6:04 PM
    #149
    509 buckeye
    509 buckeye Active Member
    Phil
    Eastern, WA
    2018 PRO
    I guess you'll be the genie pig on those ones! Never know till you try.
    protacodan likes this.
  10. Mar 1, 2019 at 7:09 PM
    #150
    Jes
    Knoxville
    Well the supreme spacers are on the way. I will update next week.
    2017TRDpro likes this.
  11. Mar 1, 2019 at 7:16 PM
    #151
    Rockoma5
    Rockoma5 Well-Known Member
    St Louis
    2019 TRD Sport Lifted
    See my signature and posts regarding lift
  12. Mar 2, 2019 at 9:58 AM
    #152
    D.A.R.
    D.A.R. Well-Known Member
    2015 TACOMA TRD PRO
    Are you wanting to level the truck or keep the same factory rake?
  13. Mar 6, 2019 at 10:31 AM
    #153
    Jes
    Knoxville
    I installed the supreme 2.5 strut spacer on the front with sway bar spacers. On the rear is Scitoo 2” block kit. Everything fit fine. Getting new Falkens now. :spending::burnrubber:
  14. Mar 6, 2019 at 1:10 PM
    #154
    protacodan
    GILROY Ca.
    2017 Tacoma TRD PRO
    Well now we all know that Revtek isn’t the only kit out there thanks keep us updated
  15. Mar 11, 2019 at 8:02 AM
    #155
    Jes
    Knoxville
    Supreme kit installed and looks good. Now it looks like I need the ECGS bushing...
  16. Mar 11, 2019 at 8:18 AM
    #156
    Grangis904
    Grangis904 Well-Known Member
    Jacksonville, FL
    2018 White TRD Pro
    I noticed that your front driver side wheel looks a little pigeon toed, Will the bushing help with that? I’m wanting to lift my truck a small amount but was curious if my wheels are gonna do the same thing.
  17. Mar 11, 2019 at 8:59 AM
    #157
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Are you talking about the positive camber? You'll need an upper control arm that can adjust your camber to fix that. I have SPC UCAs and have my camber set to about 0'.
  18. Mar 11, 2019 at 9:11 AM
    #158
    treimche
    Fargo, ND
    You have to get an alignment done after installing a lift. The alignment will straighten out the wheels and steering again. The bushing has no impact on alignment at all. It is located inside the front differential, not the suspension.
  19. Mar 11, 2019 at 10:00 AM
    #159
    Grangis904
    Jacksonville, FL
    2018 White TRD Pro
    10/4 appreciate the feedback guys!
  20. Mar 12, 2019 at 11:09 AM
    #160
    Jes
    Knoxville
    The photo is a little deceiving. I am on a slope. The truck has already been re-aligned in this photo. It drives great. It has slightly more body roll in the corners because the CG is raised.
    I went with the 2.5" lift in the front hoping to avoid the ECGS bushing. I can feel a slight growl in the front but it is not noticeable above 50mph. 4X4 makes it go away.
    I would guess a 1.5-2" might avoid it.
