how to lube the release fork?
Discussion in '1st Gen. Tacomas (1995-2004)' started by NC Tacoma, Oct 10, 2010.
  1. Oct 10, 2010 at 6:50 AM
    NC Tacoma
    NC Tacoma [OP] Well-Known Member
    Marty
    Wadesboro NC
    4X4 TRD Sport
    Could someone tell me how this is done?
  2. Oct 10, 2010 at 6:57 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Use your spray lubricant of choice and spray into the housing where the release fork meets the slave cylinder. There's a rubber boot there that you can pull off or back so you can spray inside. Try to spray to the center where you think the release fork to be.
