How to paint an emblem
Discussion in 'Detailing' started by Fenrisulfr, Mar 12, 2011.
  1. Mar 12, 2011 at 3:10 AM
    Fenrisulfr
    Fenrisulfr [OP] Well-Known Member
    SW-VA
    Tundra w/ TRD 5,7L V8 4x4
    The new emblem came; if I understand correctly, I should do the following to paint it:
    1. sand with a 100-fine sandpaper
    2. clean with something (I had vinegar in mind)
    3. apply primer, wait 24 hours
    4. apply paint
    Is this the correct procedure? Thanks for the correction or confirmation.
    Here is a picture:
  2. Mar 12, 2011 at 12:57 PM
    Dadic 78
    Dadic 78 Well-Known Member
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    You're on the right track...
    100 grit paper will be too aggressive. It will leave sand-scratches. I'm assuming you're using spray can primers, etc?
    Sand it with some 5-600 grit paper, or even use a 3M scotch brite pad (red pad). Scuff the crap out of it. To clean it, you want a cleaner that will dissolve oils, so even dish-soap will work if you don't have any industrial cleaners (parts cleaner/acetone) on hand.
    Once clean, then sand it.
    Clean it again
    Spray primer on it. (THIN COATS) -- Several thin coats of rattle-can primer
    Rattle can primer dries FAST. you can apply 3-4 coats in under an hour. It'll be ready to sand shortly thereafter. No waiting 24 hours.
    Once dry, scuff it again with your 3M pad lightly
    Apply paint (again, LIGHT coats) 2-3 of them
    Clear if required.
    Done.
  3. Mar 12, 2011 at 1:11 PM
    TTGuy711
    TTGuy711 Well-Known Member
    Jake
    Charlottesville
    17 AC TRD Sport
    Why do you have to sand again after priming it? I'm waiting on my emblem to get here and want to paint it.
  4. Mar 12, 2011 at 1:14 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    i used a 360 grit Sand paper when I did my interior plastics.
  5. Mar 12, 2011 at 1:18 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    to my understanding, when u apply primer, it fills in deeper scratches.. when u lightly sand after primer it smoothens out the surface giving it a more 'flat' surface for your paint to stick on.
  6. Mar 12, 2011 at 1:30 PM
    Dadic 78
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    For better adhesion.
    If you spray directly on top of primer, you won't get as good adhesion when compared to sanding primer, then spraying. Plus, primer is very thick, and it can fish-eye, and look uneven. Sand it smooth, paint, and know your paint will stick, and look good.
  7. Mar 12, 2011 at 1:33 PM
    AsianAnts
    AnT
  8. Mar 13, 2011 at 7:59 AM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    A good cleaner to use for all painting projects is denatured alcohol. Soak a clean paper towel with it and wipe the surface off just before painting. It will evaporate in about 1 minute.
    You can find it in the paint department at just about any hardware store or home improvements center.
    It also works really well for removing adhesives let behind by decals, badges, etc.
