How to quiet (dead quiet) a moderately lifted 02' 4wd advice needed.
Discussion in '1st Gen. Tacomas (1995-2004)' started by bodhi armor, Jul 3, 2016.
  1. Jul 3, 2016 at 12:39 PM
    bodhi armor
    bodhi armor [OP] 02’ Dbl Cab- "The Luck Dragon"
    Joshua
    East TX
    2002 4x4 Dbl Cab Jade Green
    My 02' SR5 4wd 4 door Tacoma at 201,000 miles makes a fair amount of noise when driving over road imperfections. Ive figured out how to silence my squeeky ass AAl but not my front end.
    Up front i originally used poly spacers for lift, BIG mistake,
    It made a shit load of noise, banging, clunking, and popping.
    I replaced my ball joints, chucked the spacers in a dumpster, and replaced the struts w/ Rancho "quick lift" set at 1.75".
    After that it was much better but some clunking, and popping remained. Ive asked my mechanic twice to figure out where its coming from and he has told me "that is the peril of lifted trucks and theres no way to avoid it". I simply do not believe that, I feel like he just doesnt want to take the time to track it down.
    What do yall think ans what would you recommend?
  2. Jul 3, 2016 at 12:43 PM
    curtis998x2
    curtis998x2 Curtis
    Curtis
    Utah
    2018 Toyota Tacoma TRD Off Road
  3. Jul 3, 2016 at 12:55 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
  4. Jul 3, 2016 at 2:03 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Ear Plugs !!
  5. Jul 3, 2016 at 2:13 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Most known front end knocks are caused by the swaybar links and steering rack bushings. At 200k id bet the steering rack bushings are shot even if they aren't the cause of noise. Its possible control arm bushings are gone to but id check those first.
    DustStorm4x4 and FirstGen Jer like this.
  6. Jul 4, 2016 at 7:25 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    I had a popping noise every time I turned and it progressively got worse and I also had extra play where you could move the wheels back and forth with your hands while the truck was up in the air so I got 2 new CV axles, 2 new front wheel bearings and a rack &and pinion. I had replaced the rack bushings 2 or 3 years ago and that didn't stop the popping noise. But now all the noise is gone and it's been about 6 months or so. I'm very happy with making the decision to replace all that.
  7. Jul 4, 2016 at 7:27 AM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    Oh yeah, I also have 247,000 miles on the truck. It had the original rack and front bearings but since I have a 3" lift it definitely didn't have the original CV axles. Although I have Camburg UCA's since I'm running a 3" lift.
  8. Jul 4, 2016 at 9:23 AM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    It could be there steering column making the clunking as well.
    There are many write-ups here about the repair. Basically, the shaft needs a spot weld to eliminate that noise where the two slide over one another.
    Good luck.
  9. Jul 4, 2016 at 9:30 AM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    Take off your sway bar and see if the noise goes away. If it does, you need new sway bar links. I need to do this too lol
  10. Jul 5, 2016 at 8:22 PM
    slobmonster
    slobmonster Active Member
    California
    00 Tacoma XCab 4WD
    How did you fix your rear squeak?
  11. Jul 6, 2016 at 12:26 PM
    bodhi armor
    Joshua
    East TX
    When i installed my aal i had to remove the plastic piece in the spring alignment clamp to fit the extra leaf.
    So i cut a bicycle innertube into strips, took off the clamps, then put the pieces of innertube between the alignment clamp and leaf springs.
    Worked like a charm
  12. Jul 7, 2016 at 12:21 PM
    bodhi armor
    Joshua
    East TX
  13. Jul 7, 2016 at 12:26 PM
    CodeSeven
    Serge.
    Coachella Valley
    high difficulty. without proper experience, you would NEED specialized tools to do some of them. or a hell of a lot of patience.
  14. Jul 7, 2016 at 12:28 PM
    bodhi armor
    Joshua
    East TX
    Good to know..
    Tools i have (or can aquire), but patience in in fairly short supply.
    Thanks for the info.
  15. Jul 7, 2016 at 12:54 PM
    devinzz1
    devin
    2023 aclb trd or mt
    Can be done with a torch, bottle jack, nice big balljoint press. That being said it can be a pain in the dick getting the old stuff out.
  16. Aug 14, 2016 at 3:19 PM
    bodhi armor
    Joshua
    East TX
  17. Aug 14, 2016 at 3:55 PM
    CodeSeven
    Serge.
    Coachella Valley
    a lot. they will have to disassemble all of your chassis steering and suspension bushings just to replace them with this. that's a lot of work. youre probably looking at over 600 in labor alone.
  18. Aug 15, 2016 at 8:17 AM
    bodhi armor
    Joshua
    East TX
    Thats about what i figured.
    Im still debating whether or not i want to "build up" my 02' 4 door 4wd w/ 200,000 mi, or sell it and buy a 2nd gen w/ low miles.
    If I decide to pull the trigger on a bushing kit, what kind of ride quality difference should i expect?
  19. Aug 15, 2016 at 6:45 PM
    CodeSeven
    Serge.
    Coachella Valley
    dont go 2nd gen. youll regret it.
    ride quality? more responsive. not so loose and tired. wont sway as much. possibly better handling even.
  20. Aug 15, 2016 at 8:44 PM
    NateGB
    NateGB Well-Known Member
    Nate
    Los Angeles, CA
    04 Tacoma
    Icons, uniball upper arms, ome leafs, bilstein 5100
    With 201,000 there could be lots of things popping and clicking. Like others have said, I'd start with removing the sway bar since that is free and pretty easy. If that doesn't do it. I'd just start working through parts. With that many miles most of the suspension parts have hit their lifespan anyway. Have you replaced anything before on the truck, suspension wise? (Aside from the lift). I know you mentioned ball joints. Upper and lower? Oem or aftermarket? Tie rods? Rack bushings as others mentioned. Lower control arm bushings, or the entire arm, is probably due. May also be wise to just get under the truck and look for anything loose. Then jack it up and start trying to move the tires and other parts to find anything loose. Good luck. There's always the "just drive it til it breaks" approach, too...
