How To Remove CV Axle+Replace Front Wheel Bearing 2nd Gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KenpachiZaraki, Nov 22, 2011.
  1. Aug 15, 2015 at 12:22 PM
    #301
    wtmorgan1
    wtmorgan1 Well-Known Member
    Finally finished. Took me way longer then I care to admit, but man that smooth quite ride is so worth it. Two tips: pick up the puller attachment that goes with slide hammer. I first tried using one of my own pullers and it didn't have the right angle to lock down on the CV. I finally did exactly what OP did and got CV out in 5 mins. Putting CV back in... This thread was saying to rethread axle nut and hammer CV back in straight. The CV would just compress and absorb the energy. Finally stuck a 24 in crow bar into one of the notches on CV and started popping it towards diff. It went in with very little effort.
    Crom and KenpachiZaraki[OP] like this.
  2. Aug 24, 2015 at 6:49 PM
    #302
    KenpachiZaraki
    KenpachiZaraki [OP] Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Glad my method helped! I've been wondering how others have put the CV back in. Good method to know.
    To all, I'm sorry I've been neglecting this thread, but I hope to update the Original post to have to keep you (ya'll) from hunting through all the pages to find part numbers etc.. I'd like to personally thank @nj636 for popping his head in here and there to answer questions anyone might have. He's got more experience in this area I'm betting. I was just fortunate enough to have the time, help, and location to take pictures and provide that one thing that guy did on TW to change CV axels out.
    I'm more than happy to answer any questions you shoot at me. I'm on TacomaWorld, I know stuff!
    Thanks guys!
  3. Aug 24, 2015 at 8:36 PM
    #303
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    this is my method as well. Sometimes it goes in nice, other times it sucks. I've noticed the retainer ring sometimes plays a role - I lube it and position it either where the notch is upwards or downwards (I forget - you think I'd have written it down by now)
  4. Aug 27, 2015 at 5:09 AM
    #304
    NF2001Yota
    NF2001Yota Well-Known Member
    2001 4 door 4x4 toyota tacoma
    Thanks for all of the general knowledge on this thread.
    Does anyone have any insight on converting a 2nd generation to a straight axle. Pro's & Con's?
    I have a 2001 with a broken side axle. I pulled it off last night and just looking at the front axle im curious how it would ride with a straight axle?
    Im a Newby here, THanks for any insight in advance.
  5. Aug 27, 2015 at 5:55 AM
    #305
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Go check out the SAS (Solid Axle Swap) section of the forum. A plethora of info and knowledgable members there.
  6. Aug 28, 2015 at 12:23 PM
    #306
    808KBD
    808KBD New Member
    Kauai, Hawaii
    2005 Tacoma 4x4
    About how long did this take you?
  7. Aug 29, 2015 at 2:36 PM
    #307
    Ziggy
    Ziggy Active Member
    Central Coast
    '08 TRD Sport DCSB
    Totally frustrated at this point. I was ABSOLUTELY convinced that I had bad bearings. Tore everything apart, put new bearings and seals in...the noise is still there.
    A "squeeeeeeeeeeeeee" that persists at speed, whether or not the engine is running, and doesn't go away until the tires are dead stopped. It vaguely reminds me of the squeal that a belt makes when it needs replaced, but not exactly. Helpful, I know.
    The good news is that I did actually need new bearings, so not all is lost, but I'm now pretty confused as to what the real problem is.
  8. Aug 29, 2015 at 2:36 PM
    #308
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    Wheel bearing?
  9. Aug 29, 2015 at 2:38 PM
    #309
    Ziggy
    Ziggy Active Member
    Central Coast
    '08 TRD Sport DCSB
    That's what I just replaced this morning...the entire assembly.
  10. Aug 29, 2015 at 2:39 PM
    #310
    dakotasyota
    Dakota
    Ellensburg, WA
    Oh I thought you were talking about the CV needle bearing :facepalm:
    In other news my new question is: Cv needle bearing? Does it go away when you put it in 4 high?
  11. Aug 29, 2015 at 6:20 PM
    #311
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    ^ Description doesn't match the needle bearing at all. The description sounds like a perfect match to the brake pad wear indicators hitting the rotor. Or maybe a bent heat shield around the rotors.
  12. Aug 29, 2015 at 6:52 PM
    #312
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    A ball joint fork worked great on my sisters Matrix for both removal and install. Don't know if it will work for the Tacos, but thought I throw that out for consideration. Not to slide into the axle but to grab that notch.
  13. Aug 29, 2015 at 11:03 PM
    #313
    KenpachiZaraki
    Alex •﹏•
    Lubbock
    Idler pulleys.Could have a bad bearing as well. I know mine went out the first time I went through mud. They're not protected so they fail easily.
  14. Aug 30, 2015 at 10:40 AM
    #314
    Ziggy
    Ziggy Active Member
    Central Coast
    '08 TRD Sport DCSB
    Here's a video... I think the sounds translated pretty well despite the wind and road noise. Notice how it doesn't really change a whole lot with engine revving or speed.
    https://drive.google.com/file/d/0BzE4o0TK_bWwbFlMR2VnVk54cjA/view?usp=sharing
    Would that be something that kept moving even with the engine turned off?
    It stays consistent in both 4H and 4L.
  15. Aug 30, 2015 at 11:27 AM
    #315
    Chuy
    Lakeside, CA
    Silver Taco
    I couldn't distinguish noise in video. Post the time noise first comes in.
    Thinking out loud about things that make noises with engine off: wheel bearings (you changed the front; did you look at the rears?); u-joints; carrier bearing (do SB's have one?); F/R brake rotor/pads/shoes (pads mentioned by 05Moose); differential; and finally, an odd aerodynamic sound.
  16. Aug 30, 2015 at 11:38 AM
    #316
    Ziggy
    Ziggy Active Member
    Central Coast
    '08 TRD Sport DCSB
    I didn't look at the rears...everyone that's heard it in my truck agrees it's coming from the front, I haven't looked at anything in the back to be honest.
    I can hear it distinctly at about :12, then again clearly at :25-:30 when I come to a stop. Finally, ~:44 to the end, I was driving next a curb that really amplified it. I guess it's all I can hear since it's been driving me crazy...apologies if you can't hear it, I was hoping it would trigger a "hey, I know that sound!" from someone.
  17. Aug 30, 2015 at 5:26 PM
    #317
    TRDoffroadfarmtruck
    TRDoffroadfarmtruck New Member
    2009 Grey TRD offroad double cab
    So I just bought my 09 offroad with 126000. The truck has no lift on it. I drove it home and thought man these tires are loud!! They were wore out anyway so I go and get brand new tires. That didn't fix it. I started listening closer and could easily tell it wasn't the tires. So I come to Tacomaworld to try to diagnose my problem. I thought I had it narrowed down to the needle bearing issue in this thread when I read all about it. So the next day I put my truck in 4wd thinking that the noise would go away but it didn't. My question is this: Can this be my problem even though the noise doesn't go away when it's in 4wd? Has this ever been documented? I do have quite a bit more play in my driver's side CV than the passenger. Any and all help would be greatly appreciated.
    Thanks
  18. Aug 31, 2015 at 10:55 PM
    #318
    Chuy
    Lakeside, CA
    Silver Taco
    My old ears cannot readily distinguish the myriad sounds. You may want to start a new thread to get more attention to the problem.
    I did notice your alignment appears to be off. At :51+ when it appears you are driving straight down the road, your steering wheel is quite off center. Have you noticed any abnormal tire wear? If one tire is not pointing strait, that could generate a unique sound, as if you are dragging something if I recall from experience. Good luck.
  19. Sep 1, 2015 at 12:07 PM
    #319
    Ziggy
    Ziggy Active Member
    Central Coast
    '08 TRD Sport DCSB
    Thanks for the feedback. The part of the video you mentioned was actually going around a gentle corner, it just looked straight. Brand new tires (less than 500 miles) and alignment, so that should be all good.
    I've checked the U-joints and rear brakes, nothing seemed obnoxiously out of place. I'm still considering the carrier bearing as a suspect, but have run out of free time to futz with it. It's going in to the dealer today for diagnosis, then maybe a driveway fix if it's within my abilities.
  20. Sep 1, 2015 at 8:24 PM
    #320
    TRDoffroadfarmtruck
    No one out there has an opinion about my problem? I am going to go ahead and change both hub/bearing assembly and see if that fixes it since when I put it in 4wd nothing changes.
    Thanks
