How To Remove CV Axle+Replace Front Wheel Bearing 2nd Gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KenpachiZaraki, Nov 22, 2011.
  1. Jan 27, 2012 at 5:22 PM
    #41
    rsincavage85
    rsincavage85 Well-Known Member
    Rick
    Plains Twp. Pa.
    Super White SR5
    Left wheel bearing was bad. Truck is quiet as a dream. Except for the rumble of AT tires.
  2. Jan 28, 2012 at 10:36 AM
    #42
    tacos4life
    tacos4life Active Member
    DEE
    Victoria B.C.
    06 6 spd 4x4 trd crew cab shrt box
    6'' fabtech lift 20'' eagle alloys 33x12.5/20 toyo m/t's hid halo headlights billet grill 7'' alpine gps stereo 10"" alpine drop down dvd CAI intake
    thx for the write up i know its old but it was the most helpful one on this site because the pictures ,i jus did both my wheel bearings myself and got a alignment from toyota,trucks pretty damn smooth now/drives strait and i saved myself just under a $1000 by buying parts from autoshops and wrenching myself thx again!
  3. Feb 5, 2012 at 9:19 AM
    #43
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    Op
    Thanks for the write up
    I had to change a front wheel bearing and this came in handy
    :cheers:
  4. Feb 10, 2012 at 9:54 PM
    #44
    KenpachiZaraki
    KenpachiZaraki [OP] Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Thanks!! Glad it helped! I pretty much jumped in this after doing some research on ncttora using the pdf manual and I think a few pics on toyotanation, but I needed more pics MOAR!!!! :D so I decided to do this write up to help out my fellow tacomaworldians :D TW FTMFW!!
  5. Feb 19, 2012 at 11:59 AM
    #45
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    sub'd,
    my bearings are bad...both of em...
  6. Mar 1, 2012 at 10:42 AM
    #46
    nuckinfuts
    nuckinfuts NyQuil on the rocks.
    Pacific NW
    '06 AC TRD Off-Road
    DT Long Tube Headers, Empire O2 simulator, catback, Shrockworks Sliders, Old Man Emu 3" lift with 885 coils (with 1/2" top plate spacer and Dakar Leaf packs), Hi-lift mounted in bed with 4XRAC mounts, WT floor liners, other stuffs
    Just replaced the passenger side wheel bearing yesterday - this was a good refresher course. Thanks!
    Edit: This one lasted for 115,500 miles
  7. Mar 18, 2012 at 6:37 PM
    #47
    Taqoma
    Taqoma Well-Known Member
    Brennan
    Los Angeles
    2011 TRD Off-Road
    TRD Supercharger, TRD CAI, Camburg LT, Fox 2.5x8 coilovers, Fox 2.0 bumps, Deaver e30 leafs, Fox 3.0x18 triples, Avid sliders, Yaesu 2900R, Pro Comp 7089 16x8, DDM 55w HID Hella 500FF, DDM 35w HID headlights, Magnaflow 11255 muffler, PLX DM-100 OBDII, Autometer Ultra-Lite II Boost gauge, Flex Pod gauge mount, LSK tube bumper, McNeil fenders, Fiberwerx bedsides, 285/75/16 Toyo MT's
    subbing
  8. Mar 19, 2012 at 12:23 PM
    #48
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  9. Mar 25, 2012 at 12:03 AM
    #49
    Rich Beauregard
    Rich Beauregard Well-Known Member
    Rich
    New London, CT
    17 Taco 4x4 SR5 Access Cab White
    Just a few ideas:
    1. If your rotor will not come off easy: Look at the rotor, you will see two threaded holes between the studs. ( one on each side of the center), you can thread two bolts into those holes and just tighten them evenly to remove the rotor.
    2. If the hub will not come out easy: As you remove the (4) 17mm bolts, put a small piece of metal (I used another wrench) between the bolt you are removing and the backside of a stud. This will allow you to use the bolts to push the hub out for you.
    3. If the axle bolt is tight: You should loosen the axle bolt before removing the caliper. You can side a screwdriver into the slots on the rotor to keep the rotor/axle from spinning while you loosen the bolt. The screwdriver will push against the caliper.
    These are ideas I used to remove my bearings/axles. These may not be excepted practices by all, but I found the info helpful.
    Normantaco likes this.
  10. Mar 25, 2012 at 10:20 AM
    #50
    tacos4life
    DEE
    Victoria B.C.
    And does anybody know the exact torque specs of cv nut when u have to put it back on? I jus tightened mine up but was told if i did it to tight i will be shortening the bearings life by because there will be friction against hub and bearing
  11. Mar 25, 2012 at 10:29 AM
    #51
    tacos4life
    DEE
    Victoria B.C.
    Internet says 173ft/lbs correct me if im wrong
  12. Mar 25, 2012 at 10:34 AM
    #52
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    yes 173 is correct
  13. Mar 25, 2012 at 11:53 AM
    #53
    nobody4343
    nobody4343 Well-Known Member
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    hid headlights, black spyder jdm headlight housings, black jdm led spyder taillights, full led bulb swap, hid foglights, 3 inch pro comp lift, black out emblems, two 4 inch hid lights mounted behind the satoshi, wade vent visors, black westin nerf bars, black stubby antenna, k and n cold air intake, flowmaster delta 50 dual exhaust custom black tips, color matched satoshi grill with custom emblem
    Alex do you need to remove the hub assembly of you just gnna do the cv
  14. Mar 25, 2012 at 11:58 AM
    #54
    GotLift37
    GotLift37 Bangers Runner
    North East AL
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion WMW roof rack
    no sure dont.
  15. Mar 25, 2012 at 3:36 PM
    #55
    KenpachiZaraki
    Alex •﹏•
    Lubbock
    No Jon, but you do have to wheel after you get the job done to "TEST" it out :laugh:
  16. Mar 25, 2012 at 3:39 PM
    #56
    nobody4343
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    I need to replace both axles first
  17. Apr 3, 2012 at 9:13 PM
    #57
    KenpachiZaraki
    Alex •﹏•
    Lubbock
    ordered the replacement for the needle bearing through eastcoastgearsupply so when that comes in, i'll do the other side (driver) and i'll post up pics afterwards and add to the thread. hope it all comes in handy
  18. Apr 5, 2012 at 8:22 PM
    #58
    07ricerocket
    07ricerocket Member
    north carolina
    tacoma sliver streak
    funny how much it looks like my 88 when I changed and greased the bearings... Mud and water is bad on um... Toyota didn't need to change much cause it holds up.. cool pics bro liked um
  19. Apr 7, 2012 at 9:53 PM
    #59
    BigBro
    BigBro Husband & Daddy ;)
    Carson
    Atlantic Beach, FL
    2005, PreRunner, SR5, Crew Cab, Radiant Red
    Anytime Fog light mod, Rack Mounted OffRoad Lights, Rear Mounted Bed/Reverse Lights, Painted Hood Cover, Painted Lower Front Bumper, Replaced Rear Bumper from chrome to black.
    Sooo..... I've got an '05 with 114k miles. I've been told I need to replace my bearings in both front wheels. Been told I might need to replace the hubs as well, but the dealership said they wouldnt be able to tell me till they got it apart. If its just the bearings I need replaced they said it would be $909.67 if the hubs need replacing as well, add $180 for each side....
    They are crazy! I have 2 friends that have never done a hub / betting replacement on a Toyota, but feel they know enough for the 3 of us to get it done.
    I need to know before I start and get it half way apart what all am I going to need tools wise, and while im in there should I go ahead and replace anything else??
  20. Apr 7, 2012 at 11:16 PM
    #60
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    35 mm socket, probably an impact, pliers, screw drivers, press and some sort of plates to press the hub from the bearing, torque wrench, basic socket set.
