How To Remove CV Axle+Replace Front Wheel Bearing 2nd Gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KenpachiZaraki, Nov 22, 2011.
  1. Jun 5, 2012 at 8:46 PM
    #81
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Not sure yet. Gonna wheel my truck this weekend and find out. I'm leaning toward CV axle.
    :notsure:
  2. Jun 14, 2012 at 2:07 PM
    #82
    Skadumz
    Skadumz Well-Known Member
    Lehigh Valley, PA
    2008 tacoma dual cab, long bed, 4x4, TRD Spor
    3" lift 265/70/17 nitto, Grille Craft Grille, Tinted windows, 17x9 Moto Metals Matte Black, Carrier barring drop
    I would lean more towards wheel bearing there isn't mUch in a cv axel that would make a metal on metal noise. Or try draining you front diff oil and check it. You would feel a different from driver to passenger if that bushing is messed up.
  3. Jul 30, 2012 at 1:45 PM
    #83
    HumboldtTaco707
    HumboldtTaco707 Well-Known Member
    Humboldt
    2006 4x4 Blackout
    Dynomax cat-back with super turbo muffler dumped before axle, JBA LT headers, rear fox shocks w/ piggyback, wet okoles, 1 10" square kicker, husky liners, URD short throw, URD maf calibrator
    couple quick questions here. Im about to replace my cv axle and i was wondering if i NEED to replace any seals/gasket and where would i get those? and also how should i push them back on if i dont have those tools n i also live 45min out of town on a dirt road so i cant really get it to a shop
  4. Jul 30, 2012 at 1:59 PM
    #84
    mak90
    mak90 Well-Known Member
    Central Coast, Ca.
    06 Tacoma 4x4 TRD Off Road 6 spd
    TRD Exhaust, TSB springs,Weathertech mats,Bed mat, Wet Okole seat covers, TRD Pro Suspension
    sub'd
  5. Jul 30, 2012 at 3:19 PM
    #85
    TacoNH
    TacoNH Well-Known Member
    Nü Hampshire
    07 Blue Tacoma 4.0/6speed
    887s, 5100s, Light Racing UCAs, Nitto 285s, Leer Cap.
    Any write ups on draining the front dif oil?
  6. Jul 30, 2012 at 3:20 PM
    #86
    4banger4x4
    4banger4x4 Probably should'nt have done that.
    Eric
    Whorelando, Fl
    Pull the fill plug, pull the drain plug. Drain onto garage floor
  7. Jul 30, 2012 at 3:27 PM
    #87
    TacoNH
    Nü Hampshire
    Makes sense
  8. Aug 10, 2012 at 4:05 PM
    #88
    HumboldtTaco707
    Humboldt
    2006 4x4 Blackout
    Im in the process of doing this right now but i dont know how to get the cv axle out! i yanked on it and eventually it broke right before the flat part and now i cant get the rest of it out someone help please!
  9. Aug 10, 2012 at 4:33 PM
    #89
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    So what you are saying is that you broke the cv axle and only the stub shaft is still inside of the diff?
  10. Aug 10, 2012 at 4:57 PM
    #90
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    where it enters the diff either use a slide hammer with a hose clamp or a crow bar or better yet a large brass punch
    there is only a c clip holding it in
    pics would help us out more
  11. Aug 10, 2012 at 5:00 PM
    #91
    HumboldtTaco707
    Humboldt
    2006 4x4 Blackout
    exactly
  12. Aug 10, 2012 at 5:02 PM
    #92
    brutalguyracing
    F.U> GUYZ
    broken mods
    a pic would realy help out alot
    if the spline is the only thing still in there
    you might have to get creative
    mabye some fishing wire with a nose on the end
  13. Aug 10, 2012 at 5:07 PM
    #93
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Not quite, you just pulled the bearings out of the housing, the cv should still be usable after you pack it with grease and put a new boot on.
    Here is his help thread
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/233777-help-removing-cv-axle.html
  14. Aug 28, 2012 at 5:13 PM
    #94
    HumboldtTaco707
    Humboldt
    2006 4x4 Blackout
    When i look up Differential Seal - 710419 (Timken) how come it says its for 95-05 tacomas?
  15. Aug 28, 2012 at 8:16 PM
    #95
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
  16. Aug 28, 2012 at 9:47 PM
    #96
    HumboldtTaco707
    Humboldt
    2006 4x4 Blackout
  17. Aug 28, 2012 at 10:01 PM
    #97
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
  18. Sep 5, 2012 at 2:02 PM
    #98
    Badwin45
    Badwin45 Well-Known Member
    OKC
    '10 DC 4x4 & '00 Pre-Runner
    Aries 4" Oval step tubes, Brute Force Fab rear bumper, Weathertech digifit floor liners.
    Will a 6 ton bench top press be sufficient to do this job or would one need a larger floor mounted press?
  19. Sep 6, 2012 at 6:10 AM
    #99
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    You can give a try but my 20 ton had few struggle moments. Try putting some ATF fluid on hub where bearing races slide. It should help.
  20. Sep 8, 2012 at 9:15 AM
    #100
    triple6
    triple6 Well-Known Member
    oli
    Fallbrook, CA
    04 Double Cab Stock ;)
    all beaneer designz
