How To Remove CV Axle+Replace Front Wheel Bearing 2nd Gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KenpachiZaraki, Nov 22, 2011.
  1. Dec 21, 2012 at 8:33 AM
    #121
    faller
    faller Active Member
    Vancouver Island
    Tacoma
    Bilstein 5100's @ 0.85, Toytec/Eibach coils, 1.5" AAL fbconvert's DIY AUX Input
    Some things were harder than I thought and some easier than I thought. Getting the axle out with a slide hammer was super easy. Probably the easiest step. Getting the bearing removal tool to sit right in the void between the spider gears and the bearing was a pain in the ass. Took a bunch of tries and tapping with a punch to get it in flush. Also, putting in the bushing was tough. Hard to keep it straight when getting it started. I put it in the freezer and used lots of oil. The oil seal was a jerk too. Had to use the slide hammer with the three jaw attachment to get the bloody thing out. To put hte new one in I found and empty soup can just the right size and then put a bunch of layers of electrical tape around the rim to make it soft. Kind of hard to get it in, and I wasn't sure how far to drive it in, but it looks like its doings it's job.
    All in all the vibrations are gone so I'm happy. I'm a little concerned because the longevity of the bushing isn't proven yet, and if it does wear out I assume it will put deep grooves in the axle and require it to be replaced, and I hope the removal tool will fit in behind the bushing if need be.
  2. Dec 21, 2012 at 8:55 AM
    #122
    KenpachiZaraki
    KenpachiZaraki [OP] Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    glad it came out ok!! I was going to install my NST lightweight crank pulley last week and i noticed the passenger side oil seal was leaking, so looks like i'm gonna have to get that one done as well :(.
  3. Dec 21, 2012 at 12:13 PM
    #123
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I've put almost 40k miles on the bushing so far, and it seems to be just as good as the first mile. I did use the puller to het the bushing out, so yes, it will work for that. As for the oil seal, I used a $5 seal puller from pep boys to get it out. After it came out, the seal was un usable, but took a total of 2 minutes. As far as the new seal, you drive it in as far as it will go. I used a piece of hard plastic off of my shop vac to drive it, I've also heard of guys using PVC pipe to drive it as well. For the bushing, I used the back end of a large socket to drive ot in, large enough to fit over the bushing, and just smaller than the inside of the race so I would have the bushing flush and not accidently drive it too far. I think thw thing that helpwd me the most was having a second person there to help. Thanks Skadumz.
  4. Dec 26, 2012 at 7:02 AM
    #124
    ms4x4outlaws
    ms4x4outlaws Well-Known Member
    Darren
    GULFCOAST, MS
    4X4 TRD OFF ROAD
    MUD TIRES
    So I just got done with doing the ECGS and replaced the seal and everything is tight but I cant get it too stop leaking!!!
    I really need help with this guys.
    I have had it apart 3 times now, and cant figure it out?????
    I thought i had pushed the seal into the diff too far because after i did a test drive it was pouring out.
    So i pulled it out to reset it near the edge of the diff. now it only has a small drip.....
    only thing i can think is that i might have damaged it pulling it out to reset it..?
    My question is do I push the seal all the way in or leave it at the edeg of the diff?
    thanks!!
    Also this seal is not a oem, should i go with an oem seal?
  5. Dec 29, 2012 at 7:10 PM
    #125
    RetiredPunk
    RetiredPunk Member
    troy
    Va Beach , Virginia
    13 Tacoma Dcab trd 4x4
    Thanx for the pic details ,,, Makes it easier knowing what i need to look for .
  6. Jan 7, 2013 at 6:37 AM
    #126
    Redsoxnation
    Redsoxnation Well-Known Member
    Pa.
    PreRunner TRD 4X4 Impulse Red
    none yet...
    Holy Crap! I hope I never tear a CV boot... but nice work.. that job is out of my pay scale.. That's why I ask all those silly questions abotu mine.. I do
    appreciate the professional advice..
  7. Jan 8, 2013 at 5:25 AM
    #127
    ms4x4outlaws
    Darren
    GULFCOAST, MS
    4X4 TRD OFF ROAD
    MUD TIRES
    I got my all seal up I went back to oem seal
    Ironcross6921 likes this.
  8. Jan 8, 2013 at 7:30 AM
    #128
    KenpachiZaraki
    Alex •﹏•
    Lubbock
    yea i went with oem, its the only one that i've seen that works without it leaking again. unfortunately i haven't seen a suitable replacement (timken, skf etc)
  9. Jan 11, 2013 at 6:28 PM
    #129
    4lo
    4lo Well-Known Member
    El Campo, TX
    2017 TRD Sport
    some stuff
    Bent my spindle/knuckle and this post was super helpful gettin this effer back on the road. Thanks!
  10. Jan 30, 2013 at 8:45 AM
    #130
    lilgerber
    lilgerber Well-Known Member
    Aaron
    Fresno, CA
    06 4x4 off road Speedway blue
    Front: Total Chaos 3.5 4x4 LT kit, Engage off-road one piece hood, Caged front end, TC gussets. Rear: Fiberworks fenders, King 14" 3.0 triple bypasses, boxed/braced frame, extended brake lines, 63" chevy leaf springs, U bolt flip kit, TC lower shock mounts. Preformance: URD intake, Doug Thorley headers, Flowmaster 40, 2.5 tubing. Interior: Weather techs, LED's, Double DIn, kicker 10" subs, Kicker componet speakers, Exterior: Method wheels with OMF beadlocks, Custom made bumpers, Retro headlights.
    Oil Seal(s) - ??? There are two on the cv axles, one closer to the differential, the other towards the outside or close to the wheel bearing. The same ones i didn't replace [​IMG] I need part numbers for these.
  11. Jan 30, 2013 at 9:47 AM
    #131
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    from Toyodiy.com
  12. Feb 11, 2013 at 10:15 PM
    #132
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Anyone having problems with Moog bearings failing early?
  13. Feb 17, 2013 at 2:31 PM
    #133
    romafern
    romafern Hug diz nuts
    Rob
    80918 Let's meet!
    Paid for and saving a shit ton of $$$$$
    Thinking of adding a second battery...
    does anyone have the pdf that is linked to the ncttora site? when I click on it, it comes up as gone!
  14. Feb 17, 2013 at 6:54 PM
    #134
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    toyota made them take it down. I highly advise you download and save these because it will be next. http://www.customtacos.com/tech/files/05FSM/repair.html
    slcsez2000 likes this.
  15. Feb 18, 2013 at 1:00 PM
    #135
    romafern
    Rob
    80918 Let's meet!
    Thanks for the link. I had started at one time....lost track of it but I've finally got the whole manual
    cheers!
  16. Feb 18, 2013 at 3:27 PM
    #136
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
  17. Feb 18, 2013 at 3:36 PM
    #137
    eric3187
    eric3187 Well-Known Member
    anyone have any helpful tips to get the hub out of the spindle? i have beat the hell out of it with a BFH and it wont move any more than the 1/8" gap it is at now.
  18. Feb 18, 2013 at 3:39 PM
    #138
    romafern
    Rob
    80918 Let's meet!
    Brutal,
    right click on the link, you should get a menu....find the one that says something like save link as...and save!
    enjoy
  19. Feb 18, 2013 at 3:45 PM
    #139
    brutalguyracing
    F.U> GUYZ
    broken mods
    unsure what your asking?
    are you trying to brek free upper ball joint from spindle?
    or are you trying to seperate the bearing assembly from the spindle?
    will try it thanks
  20. Feb 18, 2013 at 3:48 PM
    #140
    eric3187
    bearing from the spindle. ive loosened all 4 bolts holding it on and beat it with a BFH and used pry bars upto 24" in length and it will not budge any more.
