How To Remove CV Axle+Replace Front Wheel Bearing 2nd Gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KenpachiZaraki, Nov 22, 2011.
  1. Feb 18, 2013 at 3:49 PM
    #141
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    dont think that works
    if i disconnect from internet i can not access
    must be another way
    because if they close it the link will disappear
    anyone else have a n easy way to save the pdf's???
  2. Feb 18, 2013 at 4:25 PM
    #142
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I already tried to send it to him... Get a kid (5 to 14 years old) to do it for you.
    You take off the center crown and nut??
  3. Feb 18, 2013 at 5:55 PM
    #143
    romafern
    romafern Hug diz nuts
    Rob
    80918 Let's meet!
    Paid for and saving a shit ton of $$$$$
    Thinking of adding a second battery...
    Good one Sandman! "Get a kid (5 to 14 years old....)
  4. Feb 18, 2013 at 9:34 PM
    #144
    eric3187
    eric3187 Well-Known Member
    yes, both axles are removed from the hub presently as well
  5. Feb 19, 2013 at 6:54 PM
    #145
    4lo
    4lo Well-Known Member
    El Campo, TX
    2017 TRD Sport
    some stuff
    Not totally sure I'm following but if the four bolts are backed off the spindle and the 35mm nut is removed try a three prong wheel puller. Basically pushes the cv through the spindle. Had the same issue swapping my efffed up spindle last month and this was the fix. Free rent at AZ
  6. Feb 22, 2013 at 11:09 PM
    #146
    skygear
    skygear                    
    I think someone should start a torrent with ALL these. Would be a better preservation of data. OR an ANON server overseas.
  7. Feb 23, 2013 at 12:39 AM
    #147
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    rolling head pry bars maybe...
  8. Feb 23, 2013 at 10:00 AM
    #148
    skygear
    skygear                    
    Anyone know about the MOOG?
  9. Feb 23, 2013 at 11:13 PM
    #149
    skygear
    skygear                    
    What are the bearing part numbers for a 4wd? and what is the grease people were using in them?
  10. Feb 23, 2013 at 11:21 PM
    #150
    skygear
    skygear                    
  11. Feb 24, 2013 at 7:29 AM
    #151
    Sandman614
    Tim
    '06 SR5 Off Road
  12. Feb 24, 2013 at 12:09 PM
    #152
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Supposedly they are top of the line, but I am having a problem with both of the fronts I just put in. I swapped out both front bearings and all seals except for the one attached to the CV. I put about 5k miles on em, and now they are growling. I read in a couple of spots that folks are having an issue with them on toyota vehicles, one was on Advance Auto review of Moog wheel bearings. When I pressed mine in, I noticed they were slightly difficult to rotate, but paid it no mind to it. I am going to do it again in a few weeks, but I am going to see if parts store will let me exchange for a different brand. If not, I was going to measure the OD of the hub and the ID of the Moog bearing to see if that is the trouble. Only downfall is I have to buy all new seals, though rock auto has all but the o ring and the CV seal for $25, which I'm gunna order here in a minute. I do wonder if any one else using Moog bearings on this site is having the same problem, or am I just doing something wrong.
  13. Feb 24, 2013 at 1:05 PM
    #153
    brutalguyracing
    F.U> GUYZ
    broken mods
    YEA YOUR NOT REPLACING THE SEAL ON THE CV WHICH IN TURN IS MAYBE LETTING IN CONTAMINANTS
  14. Feb 24, 2013 at 1:09 PM
    #154
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    I thought about that, and when I pull em, I am going to look to see if there is any evidence of water, or salty crap. So in reality, 4wd trucks have 4 seals on each side to replace when doing a bearing job. Outer, O-ring, inner, and CV.
  15. Feb 24, 2013 at 1:16 PM
    #155
    brutalguyracing
    F.U> GUYZ
    broken mods
    3
    YOU SHOULD HAVE THE O RING THE INNER "BETWEEN THE HUB AND BEARING" AND THE CV TO SPINDLE SEAL
    THE ONLY OTHER SEAL IS THE FRONT DIFF SEAL
  16. Feb 24, 2013 at 1:31 PM
    #156
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    There are 2 seals at the CV and bearing. One attached to the spindle, and one attached to the CV. I didn't replace the one attached to the CV.
    Part#s 43501k and 43502k
  17. Feb 24, 2013 at 3:46 PM
    #157
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    I think I may have found another option for the Part#s 43501k and 43502k, National part# 710159. I just ordered them for $11 and when they get to me, I make sure they are correct and post.
  18. Feb 24, 2013 at 5:21 PM
    #158
    skygear
    skygear                    
    Fine, can someone link or put ALL the part numbers needed? Please? I am considerin doing both at the same time. Just to make sure all is well.
  19. Feb 25, 2013 at 6:01 PM
    #159
    DR Da_da
    DR Da_da Infrequent Member
    Alabama
    '06 4x4 V6 TRD Offroad auto access cab
    ToyTec ultimate lift, LR UCAs, TRD gen 1 CAI, TRD cat-back, bull bar, anytime fog lights, lighted 4x4 switch, factory SS step tubes, factory interior lighting package, factory VIP 3200 alarm, FJ TRD center caps, rear diff breather relocate, tint, bug deflector, Weather Tech liners
    I recently replaced the driver side inner seal (the one attached to the inside of the spindle) with one made by National. It actually also said Moog in a small section on the box. I bought it at Advance Auto, and the part is #710573. So far, so good, but it's only been a few hundred miles.
  20. Feb 25, 2013 at 10:42 PM
    #160
    skygear
    skygear                    
    http://www.youtube.com/watch?v=xkbaGzZTWOg
