How to remove factory fog lights?
Discussion in 'Lighting' started by 06Bluez, Feb 22, 2010.
  1. Apr 19, 2013 at 10:37 AM
    Greenbergler
    Greenbergler Well-Known Member
    Corey
    Orange County, CA
    2017 trd sport DCLB 4x4
    this is annoying. i cant get the back clip out.
  2. Mar 17, 2014 at 2:04 PM
    ESWOOSH
    ESWOOSH Member
    Magnaflow Exhaust Custom AirIntake Custom MB Rims 1.25" Wheel Spacer Custom Headlights Hid Headlighting 2 12" JL Subs Custom Interior Lighting Custom Interior Shifter
    okay i know this is a blast from the past but you keep saying that they dont come apart like the headlights. what do you mean? you can take stock tacoma headlights apart without having to heat the jbweld or cut it open? this is news to me and i can only imagine that the foglights work exactly like the headlights do (in my thought, please correct me if im wrong) which means if you take a heat gun (or just put the whole housing in the oven for 15 minutes) to the edge where the clear plastic meets the opaque plastic and the clear part should just come right off from the opaque.
    Now that im typing this im starting to see that perhaps you cant heat the foglight to remove the clear plastic and that maybe is what you mean by they dont come apart like the headlights. in which case i would greatly appreciate your response / correction of this thought
  3. Mar 17, 2015 at 4:18 PM
    FARNORCAL
    FARNORCAL Well-Known Member
    06 Tacoma4x4 DC LB Silver TRD Sport
    SEE BUILD
    Thanks for the help
  4. Aug 28, 2015 at 11:20 PM
    Hannar5037
    Hannar5037 New Member
    05 blue tacoma
    when taking the fog light lens out the adjustment bolt is not letting me take the light out how do I take that screw off to get the light out
  5. Mar 25, 2020 at 11:33 PM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    Do you mean the clear "lens"? Or the whole housing (clear+black)?
    If you mean the clear lens, I think it's bonded to the black portion of the housing--in other threads people have cut the clear portion off with dremels.
    If you mean the whole housing there are two small Phillips head screws holding each in place on the sides furthest from the center of the truck, in addition to the two tabs.
    edit: Apologies, just noticed you have an '05. I have '15, so it's likely not the same.
