How to remove pickup bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by justablur, Mar 6, 2012.
  1. Mar 6, 2012 at 5:12 PM
    justablur
    justablur [OP] New Member
    Brent
    Kailua
    debadged
    Anyone removed the bed before and know what needs to be done. I need to move the bed out a little to get to the bolts so that I can remove the side panel. I know I have to drill out the rivots for the gas filler and door, but I am not sure what else needs to be done. I am sure that someone has done the side panel removal before.
  2. Mar 6, 2012 at 5:20 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    bump. I bumped a thread on this a while back because I am also interested but I never got a response.
  3. Mar 6, 2012 at 9:40 PM
    DIVERMAN
    DIVERMAN Well-Known Member
    Cullen
    Louisiana
    2012 Pyrite Mica 4x4 TRD O/R SWB
    Tailgate theft prevention, Locking rear window, Blind spot mirrors, Fogs on anytime, Rear diff breather relocated, Bed storage locks, LEDs in/out, Relocated trailer plug(custom!), OEM bed mat, OEM running boards, OEM bed divider, Bed lights, Rev lights, Raptor lights, WeatherTech floor mats and window vents, Extra D-rings, ImMrYo Bracket, UWS low pro black toolbox, Carhartt seat covers,
    remove bed bolts, remove filler neck, remove wiring connectors for tails lights, remove bed.
  4. Mar 7, 2012 at 1:51 AM
    Mach375
    Mach375 Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    And on a related note....
    Anyone familiar with any trucks whose beds match our POS plastics? I'm toying with the idea of putting in a REAL bed from a JY.
  5. Mar 7, 2012 at 4:46 AM
    ckeeton
    ckeeton Bazinga
    Duluth, GA
    2011 DC Trd Sport Gray
    trd sport with avid off road light bar, avid rock sliders. OEM roof rack, 12' LED light bar, and Sock monkey decals.
    x2. i've put mine through hell and back and nothing is wrong with the liner only a few scratches.
  6. Mar 7, 2012 at 4:49 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Build a flat bed. :notsure:
    What makes you think the Tacoma bed is a POS, have you managed to crack or break the bed somehow? Also, PSU Taco is right, it's not plastic...
  7. Mar 7, 2012 at 4:49 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Not to mention doesn't rust or need heavy bedliner coatings.
    Key-Rei, cyberocker and PzTank like this.
  8. Mar 7, 2012 at 4:56 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Really the only negative with our beds in the light weight- other then that it is alot stronger then needed for our trucks. No dents, paint scratches, etc. that lead to rust to deal with. If its not broken why fix it? First, try to get the "POS Plastic" bed to fail for you. Its actually not plastic, but I bet you would have a hard time getting this bed to fail. :cool:
  9. Mar 7, 2012 at 6:25 AM
    Mach375
    Speak for yourself. If you do nothing but haul beer coolers and sleeping bags in it, then yeah, it's pretty good.
    But if you haul tools, supplies, equipment, anything needing to be tied down substantially, or anything heavy, then sorry, but the bed is going to be an issue.
    :crapstorm:These plastic beds have only been around for what, six years? Not enough time to determine what effect UV has on them. I don't care what the material is- unless it's metal, there is going to be some kind of UV degradation over time. I just sold my old minitruck that my Taco replaced, and it was 18 years old and going stronger than ever. Sure, the bed looked like it had seen 18 years of heavy use. But despite scratches and dents and gouges, there were no holes I didn't purposely drill, and no rust, and no breakage. And I beat the living shit out of it, including torquing things down to the point I snapped more than a couple of quality ratchet straps.
    There is a fundamental difference between metal and anything plastic, plastic-based, "composite," fiber, or anything else. Metal may deform a bit when put under tremendous stress, but that deformation will occur long after any "composite" material would practically explode.
    Oh, and plastic vs. composite? Composite is just a phancy plastic with a bit more strength. It's plastic with fiber mixed in. But you know what? It's still plastic. If it looks like plastic, contains mostly plastic, acts like plastic, why would I call it anything but plastic (unless I'm in marketing, of course)?
    Now for the flamers about to get on my case about "Oh, you should have bought a full-size truck, if that's what you're doing with it!" Why? So I can have a bigger truck? It's still a truck, isn't it? My old truck was a Mitsubishi Mighty Max, nearly half the size of the Taco that replaced it. But damned if that didn't do everything I wanted it to (except hold more than two people), and still asked for more. 3,500# of bricks? Yup- from San Diego to OC. All my tools? Yup- all over SoCal. Back-country adventures farther than most people with 4wd ever get? Yup- all over CA and AZ. Ever have a problem with the bed, or concern it couldn't handle what I threw at it? Nope. Cuz it was made of metal.
    Metal > Plastic, or Composite, or whatever. Every single time. Unless your only criteria is weight.:crapstorm:
    Taco_Da_Panda and aeok18109 like this.
  10. Mar 7, 2012 at 6:42 AM
    Pugga
    Massachusetts
    So... I'm going to take that whole rant as no, you haven't managed to break the composite bed yet... How about you just let us know if you do actually manage to break it and can back up your claims :rolleyes:
    You're not the only one that uses his truck like a truck and the rest of us have not had a problem with the composite bed so far.
    If you're breaking 'quality' ratchet straps because you're overtightening, you shouldn't be allowed to tie things down. Overtightening is dangerous and if you've tightened to the point the strap is failing, you risk losing the load.
    Lastly, get your facts straight... composite is not just plastic with little fiberglass mixed in.
  11. Mar 7, 2012 at 6:48 AM
    Whitecloud
    Whitecloud Cloudy-fabricator of things
    Johnathan
    Albuquerque, New Mexico
    Superwhite 06 DCLB
    ICON Extended travel Coilovers, Custom leaf pack, custom sliders and F&R bumpers, 295 75 17 Toyo Open Country MT's, On-Board air with F+R connectors, On-Board water with quick disconnect shower.Trimmed fenders and body mount chop. LOTS of wiring, dual battery setup, Solar charging system, with some random lights spread around here and there.
    Okay past all the rant bs......who has done this?? I need to pull it to rebuild the cross brace. Is this ^ everything? Or am i missing something?
  12. Mar 7, 2012 at 6:55 AM
    thatcarolinaboy
    thatcarolinaboy Well-Known Member
    Toby
    North Carolina
    19 TRD PRO
    Did a composite bed mess with your old lady somewhere down the line? damn...i could feel the hate.
  13. Mar 7, 2012 at 6:59 AM
    KCin HBCA
    KCin HBCA 2020 TRD Sport 4x4
    Keith
    Huntington Beach
    2020 Dbl Cab TRD Sport 4x4
    I removed the side panel without taking the bed loose... I used a universal joint on my 1/4" ratchet and about 12" of extension to get the top three bolts out, then went underneath to get the last 2 or 3. Had to remove the tailgate and rear lamp assy to get the plastic off to get to the couple of bolts under there. Otherwise I left the bumper on and removed and replaced the bed panel. (don't forget the fuel filler assy).
    NOTE: Tape up the corner of the cab to avoid scratching...
    Feel free to ask questions... took me about 1 1/2 hrs to take it off and about 45min to put the new one back on.
  14. Mar 7, 2012 at 7:00 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    lol
  15. Mar 7, 2012 at 7:07 AM
    KCin HBCA
    Keith
    Huntington Beach
    As one of the gals I work with would say... "He's angry on the inside... and it's leaking out..."
    GilbertOz likes this.
  16. Mar 7, 2012 at 7:13 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    There is nothing wrong with the composite bed, I bet that it will inspire other truck manufactures at some point to put it in their trucks as well, not to mention it would cut down production costs in half probably. Go ahead and try to break it, good luck!
  17. Mar 7, 2012 at 7:31 AM
    98tacoma27
    Ben
    Not Beech Creek
  18. Mar 7, 2012 at 7:39 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Correct. I cut away some parts of mine to see what the composition was, and it seems as if there is some fiberglass, or the like, mixed into the matrix....I can attest it being pretty dam strong, as I broke a bolt off in mine 4 years ago, and still havent been able to get it out.
  19. Mar 7, 2012 at 2:56 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
  20. Mar 7, 2012 at 3:02 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    ^ that's totally a myth. Composite is about as strong as a plastic milk jug.
