How to remove power window motor?
Discussion in 'Technical Chat' started by Veccster, Aug 8, 2008.
  1. Aug 8, 2008 at 5:23 AM
    Veccster
    Veccster [OP] bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    The passenger side motor in my 2004 went bad. I need to get the motor out but am not sure how to disconnect the motor from the actuating arm that raises and lowers the window. I have door panel off and speaker removed. I see the 5 bolts that hold the motor in place but can't figure out the actuating arm.
    Any advice?
    Thanks.
  2. Aug 8, 2008 at 5:54 AM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    You the same Veccster from TT?
  3. Aug 8, 2008 at 6:15 AM
    Veccster
    Eric
    2020 Pro
    I feel like I'm famous :D
    Yup, same one. I haul my 2005 200exc with my 2004 Taco.
    The truck is going on the market soon as I have my eye on a 2009!
  4. Aug 8, 2008 at 6:21 AM
    dually
    dually Low and slow
    Nice, I figured it was you since, i remember that pic^ posted on the forums. Im sarge1991
  5. Aug 8, 2008 at 8:46 AM
    Mingy
    Mingy Well-Known Member
    Milton, Ontario
    V6 uble Cab TRX/Towing
    Lear cap.
    On another Toyota, there was a sort of sliding clip (looks like a slotted duck bill) that you push off the pin (the clip rides in a slot on the pin). Then you have to force the pin out of the hole, which may be a pain so you might have to use a small screw driver to lever it out.
    You lower the window to the right spot to remove but I don't know how you do that if the motor doesn't work.
    You might download the manuals - very handy ...
  6. Aug 8, 2008 at 8:54 AM
    Siafu
    Siafu Eat My Dirt
    Redlands!
    V6 Camry XLE
    Limo tint on Windows, Removed all emblems, Powdercoated Rims Black
    hey. anyway of installing a motor that makes the driver side auto up and down?
  7. Aug 8, 2008 at 9:18 AM
    Veccster
    Eric
    2020 Pro
    From my understanding, I need to remove the window first then the motor and regulator come out together. I see all of the bolts that will loosen the regulator/motor.
    I now need to figure out how to remove the window.
    Siafu, may want to ask around on that but I have that option on my Jeep and hate it. I push down and it starts the auto down, I then push up and it starts the auto up. I do this 3 or 4 times before I get it to stop in the middle = PAIN IN THE ARSE!!!
  8. Aug 8, 2008 at 9:22 AM
    Mingy
    Milton, Ontario
    Lear cap.
    From the manual (download at http://www.tacomaworld.com/out.php?url=http://www.ncttora.com/fsm/ - as per the sticky), after you extract the files and open the item R.M. 2006::Engine Hood / Door: Front Door (w/ Power Window): Disassembly (Tacoma) the procedure shows you remove the inside panel plate, remove two bolts and tip the window out.
  9. Jul 24, 2012 at 9:43 AM
    ironsides
    ironsides New Member
    K J
    rimrock, AZ
    PreRunner SR5 V6
    TRD package
    I have a 2005 Toyota Tacoma SR5 prerunner TRD. I need to replace the passinger window motor. I have loosend four bolts that hold the motor assembly,but I am not sure how to proceed from here.
