How to remove the insturment cluster?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cfrea, May 10, 2012.
  1. May 10, 2012 at 5:03 PM
    cfrea
    cfrea [OP] Well-Known Member
    2012 Tacoma Double Cab TRD Sport
    So I did a search and there was one link that showed how to remove the instrument cluster but the instructions aren't that clear. The first step is to remove the two screws, but on my 2012 there are no screws, instead its two circular plastic pieces. I don't know if I'm supposed to stick something underneath the gap and attempt to pop it out or what?
    http://www.customtacos.com/tech/index.php?article=225
  2. May 10, 2012 at 6:09 PM
    tango down
    tango down Policy Ninja
    jeff
    peoples republik of IL
    12 Taco DCSB TRD Off Road
    LED interior, rail mounted ammo cans
  3. May 10, 2012 at 6:18 PM
    cfrea
    thanks but its the old design :( mine isnt like that instead its just a plastic piece with a hole in it. [​IMG]
  4. May 10, 2012 at 6:28 PM
    fvtalon
    fvtalon Well-Known Member
    Southern BC
    07 DC TRD/Yamaha
    285/65/18 BFG ATs on MKWs Leer Cap
    With that style clip you should be able to push the center in with something (a pen with the ball point retracted or whatever) and the clip should either fall out or get loose enough that you can gently pry it out with a small flat blade screwdriver or something similar. When you push the button in it will just sort of pop in stop again, leave it there.
    When it's out just push the pin back out so it sticks out of the 'washer' to reset it then get it in place and just pop the button in flush. Use one hand to hold the trim pieces tight together when you pop the button in or you risk breaking the fastener.
  5. May 10, 2012 at 6:33 PM
    cfrea
    that worked. thanks!
