how to remove this crap..
Discussion in 'Detailing' started by radcat692000, Oct 6, 2011.
  1. Oct 6, 2011 at 2:53 PM
    radcat692000
    radcat692000 [OP] Well-Known Member
    Rob
    Clayton N.C.
    95 tacoma 4x4 sr5
    none
    the person who i bought the truck from had vent visors,,,problem is they were all broken,,so i finished pulling them off and there is that sticky foam type stuff left on the paint...problem is its been up there so damn long you cant even scrape it off....now what...?????
  2. Oct 6, 2011 at 2:55 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Goo Gone and elbow grease works pretty good.
  3. Oct 6, 2011 at 2:55 PM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    I think you can use WD40. Somebody correct me if I'm wrong. Just be sure to clean the WD off real well.
  4. Oct 6, 2011 at 2:57 PM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    that really sucks! maybe goo gone? stuffs pretty good and getting sticky stuff off, i just dont no how it will work with paint. Pretty sure some guys around here said they used it when they were debadging there tacos, but if its been on there a while your going to need alot and i dont know how alot of goo gone will work with ur paint. Good luck
  5. Oct 6, 2011 at 2:59 PM
    jcgarvey
    jcgarvey Well-Known Member
    SFV, Los Angeles, CA
    V6 PreRunner 4x2 TRD Off Road
    WD-40
  6. Oct 6, 2011 at 3:00 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    I've used Goo Gone for debadging, removing the factory pinstripes, and window tint adhesive. I like the stuff.
  7. Oct 6, 2011 at 3:10 PM
    radcat692000
    Rob
    Clayton N.C.
    95 tacoma 4x4 sr5
    none
    ill try it...
    goo gone and wd-40 thanks... should i use a plastic scraper???as well with it soaked??
  8. Oct 6, 2011 at 3:11 PM
    Oat
    Oat Well-Known Member
    Florida
    2001 Prerunner
    Gibson Exhaust, Painted factory steel wheels, Chrome wheel caps, K&N Air intake, Tint, Regular Bilstein (yellow/blue) all around, Leveling spacer kit upfront, Partially de-badged, Westin Bullbar with skidplate, White, Double Cab Prerunner SR5
    goo-gone should do it used it on some pvc pipe today took that shit right off
  9. Oct 6, 2011 at 3:15 PM
    jcgarvey
    I would avoid using a scraper as it can leave scratches, use a microfiber towel that you can toss after. If there is still some adhesive on the truck after you got the majority of it off I would use an auto clay bar and some quick detailer.
  10. Oct 6, 2011 at 4:41 PM
    radcat692000
    Rob
    Clayton N.C.
    95 tacoma 4x4 sr5
    none
    man goo gone is not even comming close to removing this stuff...:(
    im goning to have to go to a automotive paint store and get some real auto decal remover. ive used it before..made by 3m...
  11. Oct 6, 2011 at 4:43 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    cant you use a blow dryer to heat it up the adhesive and it might help a tad bit?
  12. Oct 6, 2011 at 4:45 PM
    radcat692000
    Rob
    Clayton N.C.
    95 tacoma 4x4 sr5
    none
    heres what i'm trying to get off..the plastic was busted but the damn foam adhesive is soo strong and old,,its almost like it has baked up there,,must have been on truck a long long time,,you can tell.
  13. Oct 6, 2011 at 4:48 PM
    Nolawall
    Nolawall "And there I was just minding my own business"
    Nick
    Virginia Beach
    2002 Dbl Cab Tacoma
    6" Fabtech Suspension Lift. K&N Air Filter Cobra 18 CB with 2 3' firestik II antennas
    I used goof off and it cam right off just make sure you wash the area after. But if you use this it dont take nothing but a paper towel to come off
  14. Oct 6, 2011 at 4:49 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    I've seen goof off remove paint in seconds.
  15. Oct 6, 2011 at 4:49 PM
    Catcrazed
    Catcrazed Love is Dogs and Toyotas
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    91 Flatbed, 4.88's, ARBs, SAS, 3.4 Swap, 35s, M8000, lots lights, Aux tank, Protech
    If you go to an auto parts store that sell/ mixes paint and has a large auto body section. they make a lil wheel thats made out of pencil eraser it has a stud in the middle and i use my cordless drill smokes that shit rite off. the i use some heavy cut cleaner/ buffing compound to buff it clean it up.
  16. Oct 6, 2011 at 4:50 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Sherpa Grand Teton/Crows nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights
    heat gun and a plastic scraper...then remove what's left over with the goo-gone.
  17. Oct 6, 2011 at 4:52 PM
    jsmarine
    jsmarine Well-Known Member
    Jeff
    Dallas, TX
    2005 Tacoma SR5 Crew Cab 4x4
    ARB front & rear lockers ARB bull bar Warn XP9000 winch IPF lights
    Goo-Gone sucks...I have never had that stuff work.
    Get a plastic putty knife and some WD-40. I know others said the putty knife might leave small scratches but you need to get the foam tape off first before you tackle the adhesive.
    You are just trying to get rid of the foam tape, not the adhesive, dont try and scrape it all the way down to the paint.
    After you get most of the foam tape off, WD-40, a terry cloth towel, and some elbow grease should remove most of the adhesive residue.
  18. Oct 6, 2011 at 4:52 PM
    radcat692000
    Rob
    Clayton N.C.
    95 tacoma 4x4 sr5
    none
    i do believe we have one at work along with the scraper,,,i'm trying that tomarrow..
  19. Oct 6, 2011 at 4:53 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    I did all this on my Ram to remove the fading door trim. Took a lot of time, elbow grease, and patience. Not sure if it will hurt but I did even use alcohol, mostly afterwards to clean it up.
  20. Oct 6, 2011 at 4:54 PM
    TacoDawgfan
    Georgia
    Oh and let the WD or Goo Gone soak should help too.
