How to remove transfer shift actuator.
Discussion in 'Technical Chat' started by NeonHeights, Sep 8, 2017.
  1. Sep 8, 2017 at 3:57 PM
    NeonHeights
    NeonHeights [OP] Well-Known Member
    Im trying to troubleshoot a problem with my 4LO not engaging when in 4HI. I was reading another topic that talked about removing the transfer shift actuator and manually popping the case into 4LO. I removed all three 12mm Bolts that hold the actuator onto the case and tried pulling it off but had no luck. I didnt want to yank on it too hard, I assume theres something that im not doing which will allow me to free the actuator from the rod that goes into the transfer case (So that I can manually push/pull on the rod to adjust the gearing). Do I have to possibly disassemble the actuator while its on the case still and remove some sort of washer/nut thats holding it in place?
  2. Sep 9, 2017 at 8:55 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
  3. Aug 18, 2018 at 7:16 PM
    jmarquez808
    jmarquez808 Large Member
    Jess
    Hawaii
    07 4x2 reg cab / 12 4x4 double cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    Hey guys im gonna share the issue i had with my 4x4 in my build page might help some who were having issues, with removal and also installing ut correctly in the right place.
    nednic likes this.
  4. Sep 21, 2018 at 3:41 PM
    nednic
    nednic Active Member
    Nic
    2010 TRD S Double Cab Ext Bed
    Toytec Boss Toytec add-a-leaf SPC Control Arms Nitto 275/75/17 Ridge Grappler
    I’m waiting for your post on how to do this!
