How To: remove UCA (A-arms)
Discussion in 'Suspension' started by davisr_86, Oct 18, 2009.
  1. Oct 18, 2009 at 8:08 PM
    davisr_86
    davisr_86 [OP] DVAN
    Broomfield, Co
    06 Tacoma TRD
    6" Pro Comp suspension lift kit, Flow master dual Exhaust, Volant CAI, Missing Tailgate (some asshole stole it)
    I am in the process of installing a Pro Comp 6" suspension lift on my 06 tacoma. I removed the A-arm on the passenger side, however, I cant remove the A-arm on the Driver side. I'm don't know much about the A-arms and am not exactly sure how to remove it. Any help would be greatly appriciated.
    Thanks,
    Davis
  2. Oct 18, 2009 at 8:17 PM
    johnny12345
    johnny12345 Well-Known Member
    vancouver island, canada
    09 tacoma SR5
    Where are you running into problem as opposed to the passenger side? You gotta bend the inner fender a bit to get the long bolt out, remove the nut below the uni-ball/balljoint, whatever ya ca wanna call it, and hit the bolt once the nut is removed with a hammer and it should pop off!
  3. Oct 19, 2009 at 6:25 PM
    davisr_86
    davisr_86 [OP] DVAN
    Broomfield, Co
    06 Tacoma TRD
    I am having problems getting the bolt out of the rear bushing of the driver side A-arm. I hit the crap out of it with a hammer, I used a Impact gun, breaker bar with a pipe on the end of it, all no luck. I already bent the fender for the front and removed all of its hardware. I'm afraid that its rusted on or something.
    thanks again,
    Davis
  4. Oct 20, 2009 at 12:40 PM
    HOSS454
    HOSS454 Well-Known Member
    Pukalani
    08 Sport
    Bolt ons here and there
    i just cut the long bolt right next to the head and got new bolts from toyota... it was about $30 for the 2 bolts... was easy to get out after that and no banging on anything to get the bolts out...
  5. Oct 20, 2009 at 12:51 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    were you able to get the bolt to move at all?
  6. Oct 21, 2009 at 11:21 PM
    davisr_86
    davisr_86 [OP] DVAN
    Broomfield, Co
    06 Tacoma TRD
    So today I just cut the bolt out and bent the frame to pull the A-arm out. The bolt is still stuck in there but that shouldn't be a problem to get out, I'm going to drill it out or maybe press it. So looking ahead I don't know how I'll be able to put the A-arms back into the new frame. The new frame is hardened steel and doesn't look like it will bend.
    Thanks for the help so far,
  7. Oct 22, 2009 at 6:17 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
