How-To: Replace OEM Antenna (in-fender)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yoshio, Feb 2, 2013.
  1. Nov 26, 2015 at 10:45 AM
    #61
    Mon Leb
    Mon Leb Well-Known Member
    St-Jean-sur-Richelieu, Quebec, Canada
    2009 4X4 SR5-TRD Sport
    Hi.
    I just did mine and this post really helped me getting the job done by knowing what to do right off the bat, and having right part numbers too. Saved a lot of time.
    Thanks a bunch. :thumbsup:
  2. Nov 29, 2015 at 8:45 AM
    #62
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    OP, sweet write up!
    Sub'd!
  3. Feb 28, 2016 at 2:25 PM
    #63
    supernewf71
    supernewf71 New Member
    Dave
    Ottawa, ont.
    09 access cab
    My bezel is all corroded and broken in half. Time to tear it apart and replace. Antenna is still good.
  4. Apr 20, 2016 at 11:18 AM
    #64
    ISLANDER1089
    ISLANDER1089 Well-Known Member
    James
    Bracebridge, ON, Canada
    2012 Black Tacoma TRD Sport DCLB
    Supreme Suspension 3" front lift, T-Rex billet grill, Cree aux. LED backup lights, WeatherTech floor mats, window and hood deflectors, LED interior lights, Pro Comp wheels, Redline hood struts, stainless side steps, LED light bar in grill
    I have the exact same problem on my 2012 TRD Sport. Two questions that nobody asked or answered in the three previous pages:
    1. what causes the antenna base to loosen in the first place?
    2. can you replace the antenna base by itself and just reattach the old antenna cable at the new base so you don't have to go into the dash panel and "A" pillar?
  5. Jun 10, 2016 at 7:24 PM
    #65
    matt1515
    matt1515 New Member
    2013 Toyota Tacoma TRD+Leather Spruce Mica
    Thanks for this helped a lot did this on my 2013 only 3 years old had to drill it out I used a 1/2 inch bit but wonder if 1/4 would do the job and save the ornament part from damage ($29.99 part in Canada) I used the smallest allen key I could find to help pull the plugs out didn't break any and used to the two smallest allen keys and vice grips to tighten the chrome nut down. I also put some dielectric grease on the parts to hopefully slow corrosion process
  6. Jun 15, 2016 at 6:26 PM
    #66
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Great write up. Thank you! I also had to drill mine to get it out.
    Islander1089, I am unsure of what causes it to loosen in the first place as mine didn't have that problem. I broke mine off and had to get the new base since the threads were trashed.
    You could most likely just insert a new base and splice the wires together but unfortunately the only plug is inside and access to that requires taking the pillar apart. It was only two bolts though in the handle and the plastic lifted right out of there without a problem. Then u just have to take the glove box out (just squeeze the black sides they flex) and you have access to the grommet and connection.
    Hope this helps,
    Rob
  7. Jun 25, 2016 at 10:17 AM
    #67
    SWM
    SWM Well-Known Member
    Sean
    Ontario
    2006 TRD DCSB
    I just finished replacing the antenna thanks to this writeup. Was totally disintegrated and the lower part inside the fender wasn't attached to the bolt anymore.
    I broke a bunch of those black clips. They are actually screw grommet's that are meant to stay in the hole and hold a screw but looks like Toyota is just using them as clips. Which is why they are such a pain to remove.
  8. Jul 27, 2016 at 6:52 AM
    #68
    tgear.shead
    tgear.shead Well-Known Member
    1) The aluminum base turns into aluminum oxide, which is powdery and falls off.
    2) The wire is part of the antenna base, which is a good thing, because it means that there are no plugs out there to potentially lose conductivity. Dont worry though, the work on the inside is *really easy*. The part under the dash is just feeding the new wire and grommet through the hole, and snapping it into place. The A-piller comes off easily with a #10 socket.
  9. Jul 30, 2016 at 10:11 AM
    #69
    ISLANDER1089
    James
    Hey guys, I went ahead and replaced the whole assembly which turned out to be easier than expected. I busted a couple of the clips that secure the fender flare but haven't replaced them yet. I did find that my radio reception improved so that was an added bonus. I appreciate the write up because I wouldn't have known where to start otherwise.
  10. Sep 17, 2016 at 7:22 PM
    #70
    Coolerman
    Coolerman Well-Known Member
    Dan
    Rochester, NY
    2005 4x4 SR5 AC / 2007 4x4 FJC / 2021 Tesla Y
    Pro/2015 Coil-overs n shocks, Icon progressive AAL, Firestone Ride-Rite Air Bags and cradles, ECGS clamshell bushing, Extang Solid Fold Tonneau cover, 2014 Navigation radio and backup camera, Wet Okole seat covers, rcbs204 lighted 4x4 switch, Weathertech digifit floor mats and in channel window vents, Scanguage II, Hayden 678 Trans cooler, Western Suburbanite plow, Pop and Lock PL8521
    Thanks to the OP, this write up was very helpful. I ended up having to grind/cut off the nut on my base. That was the hardest part of the job followed closely by removing those black plastic plugs. :thumbsup:
  11. Oct 20, 2016 at 8:03 PM
    #71
    JHZ55
    JHZ55 New Member
    Jhz55
    2015 Toyota Tacoma, 4 door, 4wd
    pro comp 4" lift kit.
    Thanks, your thread helped me out. I was able to go to the dealership and stock up on "soon to be broken" clips.
  12. Oct 24, 2016 at 4:06 AM
    #72
    eppy
    eppy Well-Known Member
    Rob
    Maryland
    05 V6 TRD OFFROAD
    Homer M3 thin lip Satoshi, BAMF Light Bar, BAMF Batwing Tie Downs, Coupe Custom Battery Hold Down, Mattgecko Bed light kit, nj636 hub/wheel bearing set-up,Shorty Antenna, JL Audio & Boston set-up, 4x4 switch light MOD, Icon 2.5 coil overs and rear shocks, All Pro flip kit, Wheelers AAL, OcTaco SS brake lines, Light Racing UCA's and custom 6 speed Ellis Precision Shift knob. Coupe modified short shifter, AISN clutch pack, URD TOB kit, and Sachs flywheel. Mobtown's rocking tailgate skin!
    Guys I to need to replace my entire set-up because I installed a stupid ass stubby and the new insert rusted into place and can't remove it to put my antenna back on. My question is do I need to drill out the insert, or if I can remove the locking ring will the whole assembly come off. Also does anyone have the part number for the new wire assembly itself?
    Thnx,
    Eppy
  13. Oct 24, 2016 at 6:02 AM
    #73
    BassAckwards
    If you can get the bezel nut ring off of there then it should come apart. but mine was corroded so i had to tear mine apart when taking it off.
    The part number for the antenna assembly is: 86300-04070
    The rest of the part numbers you may or may not need should be in the OP
  14. Oct 24, 2016 at 9:59 AM
    #74
    JHZ55
    JHZ55 New Member
    Jhz55
    on my 2015 tacoma, Once you remove the locking ring, its still secured in place under the wheel well by a clip and a 10mm bolt. I dont' know if your tacoma has the same bolt. I used a cheese cloth, soaked with that PB loosener stuff, and wrapped it around that nut overnight. Then I used a pair of pliers (and the cloth) to loosen the locking ring.
  15. Oct 24, 2016 at 2:24 PM
    #75
    eppy
    Rob
    Maryland
    05 V6 TRD OFFROAD
    Thanks man, I really appreciate the heads-up and will be tackling this soon.
  16. Nov 19, 2016 at 4:22 PM
    #76
    bgsmith
    bgsmith Well-Known Member
    Brian
    Hingham, MA
    06 Speedway Blue TRD Sport 4x4 DCSB
    ATX Mojaves with 265/75 16 Hankook Dynapro ATMs, Spidertrax 1.25" spacers (front and rear), Bilstein 5100 all around up front set at 1.75", Blacked out badges, Pioneer AVIC D3 DVD/NAV Head Unit, K&N Air Filter, Tyger Tri Fold Tonneau Cover, Rockford Fosgate Punch Speakers.
    Just ordered the parts as my antenna is a mess, will hopefully get this done next week.
  17. Dec 25, 2016 at 3:59 PM
    #77
    nico3367
    nico3367 New Member
    2005 Tacoma TRD 4X4
    My antenna broke too, and I'm ordering the parts. Read the write up and Im pretty clear on the process. BUT, from the diagram and photos I cant figure out what happens in the Piller area, above the dash? From the exterior it looks like the antenna (with a cable) goes through the rubber plug in the fender into the cabin glove box way below the Piller. So where is the detaching connector located, in the Piller or behind glove box? And are both glove box and Piller trim necessary to remove depending on where the detaching connector is? Any help is appreciated - nico
  18. Dec 25, 2016 at 8:13 PM
    #78
    BassAckwards
    Iirc, the connection where the wiring for the antenna connects is in the a pillar. You will also need access to behind the glove box though so you can run the new antenna wiring up through the grommet and up to the A pillar where it connects
  19. Dec 30, 2016 at 7:51 AM
    #79
    nico3367
    nico3367 New Member
    2005 Tacoma TRD 4X4
    Ahh ok, that makes sense. Thank you sir!
  20. Dec 30, 2016 at 7:54 AM
    #80
    BassAckwards
    No problem! Good luck, let me know if you have any more questions
