How-To: Replace OEM Antenna (in-fender)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yoshio, Feb 2, 2013.
  1. Dec 30, 2016 at 8:00 AM
    #81
    nico3367
    nico3367 New Member
    2005 Tacoma TRD 4X4
    I do in fact. Last night out of the blue, both my low beam headlights stopped working. Previous owner installed some kind of after market headlights. High beams and all other lights work. I hear a switch when I turn them on but not low beam.
  2. Dec 30, 2016 at 8:37 AM
    #82
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Ive never had this happen to me before, so i cant be of much help with this one.. maybe try creating a new thread in here:
    https://www.tacomaworld.com/forums/lighting.60/
    Im sure someone has had this happen before. They can most likely lead you in the right direction
    Edited to add: on the tacomaworld site, the search function is basically useless. I always just go to google and type what im looking for in the search bar and then after it write site:www.tacomaworld.com. This will give u search results for just this site. There is tons of great info on here, its just a matter of finding it.
  3. Dec 30, 2016 at 9:06 AM
    #83
    nico3367
    nico3367 New Member
    2005 Tacoma TRD 4X4
    ok thank you for tip. i think it might be the headlight relay switch, at least that what i am hoping for. To Auto Zone!
    BassAckwards likes this.
  4. Feb 21, 2017 at 7:21 AM
    #84
    Buffdeez
    Buffdeez Well-Known Member
    Hamilton, Ontario, Canada
    2008 DCLB SPORT
    Great write, mine just broke after a few months of a new underground parking spot for work so a repair will be needed for future.
    Cheers
  5. Mar 17, 2017 at 1:36 PM
    #85
    Htrddah
    Htrddah New Member
    Harvey
    06 tacoma
    I have a question. do I have to take the fender flare all the way off to get into the antenna? I have to replace the antenna on my 2006 Tacoma. Not picking up radio stations very good anymore. Not sure how to get the flare off before the plastic liner and the other way around. Don't want to break anything doing this and have the new antenna and some new blue clips and black clips to do the job.
  6. Mar 17, 2017 at 1:38 PM
    #86
    BassAckwards
    I didn't when I replaced mine, but you do have to remove the screws that hold it onto the inner fender liner. you will also have to remove the mudflap so you can remove that portion of the fender liner too. Pretty much all I did when I replaced mine was peel the fender liner back so I could get in there and have access to where the grommet goes into the cab
    Htrddah[QUOTED] likes this.
  7. Mar 17, 2017 at 1:56 PM
    #87
    Htrddah
    Htrddah New Member
    Harvey
    06 tacoma
    Thank you rjbiii. That's what I was thinking I'll take the wheel off and just loosen it up to get in there. Thanks
  8. Mar 17, 2017 at 2:07 PM
    #88
    BassAckwards
    No prob, good luck
  9. Mar 18, 2017 at 2:34 PM
    #89
    Htrddah
    Htrddah New Member
    Harvey
    06 tacoma
    Thanks for the great write up Yoshio. Thanks for the help rjbii took it apart this morning and replaced with no mess ups. You guys are great help. Did have to drill out the old bezel nut but with this write up it was very easy thanks guys
  10. Apr 8, 2017 at 6:10 PM
    #90
    Jayhawker
    Jayhawker New Member
    Kansas
    stock 06
    Thanks. This thread saved me a lot of money.
  11. May 9, 2017 at 8:59 PM
    #91
    andrewcdx
    andrewcdx New Member
    Ditto, stealer wanted ~$500 to replace, saved ~$400 replacing antenna/bezel/nut/clips myself using new online oem parts.
    It's amazing how easy these trucks are to work on if you know the tricks ie. serpentine accessory belt in 10 minutes etc.
    Thanks!
  12. May 10, 2017 at 6:05 AM
    #92
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Nice write up OP! I see this happening in the near future.
  13. May 31, 2017 at 5:16 AM
    #93
    smcgill
    smcgill Well-Known Member
    Sean
    South Easton Mass. not enough time in Cocagne NB
    Camry and Ram 1500 with a "HEMI "
  14. Jun 7, 2017 at 5:56 AM
    #94
    smcgill
    Sean
    Around $86 plus tax
  15. Jun 7, 2017 at 6:04 AM
    #95
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    I need to replace my serpentine accessory belt. Is there a write up you can link me to?
    Thanks
  16. Jun 13, 2017 at 6:18 AM
    #96
    smcgill
    Sean
    The install info was very helpful.
    I had it replaced in a couple of hours ! :bananadance:
    The reception is a little better ....is there a breaking in period?
  17. Jul 19, 2017 at 6:09 AM
    #97
    Norton Guy
    Norton Guy Well-Known Member
    North East
    2011 Double cab SR5 Sport
    No break in period, should work as well as it's going to right away.
    Mine was a clump of corrosion when I took it apart, worked great when I installed the new parts. Toyota should be eating these.
  18. Jul 21, 2017 at 11:23 PM
    #98
    Deathcure
    Deathcure Well-Known Member
    Wheeling WV
    12 Tacoma Off Road
    sub for later
  19. Aug 5, 2017 at 2:18 PM
    #99
    drewskie
    drewskie Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    I have a question for you guys. I did the antenna change on my buddy's truck, and it was pretty easy except that now I can't get the rubber boot piece over the threads to install the little lock nut. There isn't another way to put the antenna in so I don't know why it won't fit.
  20. Aug 6, 2017 at 3:30 PM
    #100
    drewskie
    Drew
    Burbank, CA.
    ?? Bump
