How-To: Replace OEM Antenna (in-fender)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yoshio, Feb 2, 2013.
  1. Nov 21, 2022 at 5:10 AM
    #161
    CharcoalToy
    CharcoalToy Active Member
    Dusty
    2013 Charcoal Taco TRD 4.0 4WD
    WOW! This is good info thanks!
  2. Nov 22, 2022 at 6:11 AM
    #162
    Moto_dj
    Moto_dj Well-Known Member
    Michigan
    2012 White Tacoma TRD
    I did this replacement several years ago, think i even referenced this thread…so thanks for that!
    However, the real problem here is a poor design from toyota that quickly results in galvanic corrosion causing poor reception, stains, etc.
    I ended up switching to fiberglass fenders about 2.5yrs after i replaced the antenna. When doing so i found the corrosion on the antenna to be the same or worse than it was originally. I didnt even bother to re-install the antenna (usually listening to satellite or Spotify anyways). But i do miss having the local stations sometimes…
    Moral of the story, someone should step up and design a better antenna!
    ACEkraut likes this.
  3. Nov 22, 2022 at 10:30 AM
    #163
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    I wonder how well reception would be if the antenna was tucked out of the way in the headliner?
    SR-71A likes this.
  4. Nov 22, 2022 at 5:43 PM
    #164
    DailyTacoMD
    DailyTacoMD Well-Known Member
    Jeremiah
    2006 2.7L AC 4x4 5spd
    Glad i found this, was thinking my radio was the issue. Still planning to change the stocker out sometime soon.
  5. Nov 22, 2022 at 5:47 PM
    #165
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
  6. May 30, 2024 at 6:44 PM
    #166
    number9
    number9 Member
    Does anyone know the part # for the actual antenna mast? Didn't see it posted in this thread anywhere.
    Have to do the same, my boy's antenna broke off in the car wash today.
    ETA - found it. 86309-04110
    theolee and Rick's 2012 like this.
  7. Jun 11, 2024 at 8:04 PM
    #167
    number9
    number9 Member
    Ordered the exact drill bit and extractor as above a week or so ago. Have sprayed penetrating fluid in the antenna base a few times since then while waiting for the parts to arrive. Me and my son removed the broken antenna stud from his truck today. 2015 with 135,xxx miles. Followed the process above and it worked like a charm. Slow and easy, took our time, and it came out with no fuss.
    2009Access4x4 likes this.
  8. Jun 11, 2024 at 8:34 PM
    #168
    2009Access4x4
    2009Access4x4 Well-Known Member
    Shane
    2009 Silver 4x4 access cab 6cyl
    Do you happen to have the links to order the bit and the extractor?
  9. Jun 12, 2024 at 9:59 AM
    #169
    number9
    number9 Member
    Ordered them off Amazon
    BOSCH CO2132 1-Piece 5/64 In. x 2 In. Cobalt Metal Drill Bit
    Irwin Tools 53401 SCREW EXT #1 SPIRAL
    2009Access4x4[QUOTED] likes this.
  10. Jun 12, 2024 at 1:53 PM
    #170
    dtaco10
    Dave
    The fastener holding mine on is frozen. What are people using to break it loose?
  11. Jun 12, 2024 at 4:22 PM
    #171
    82lightfighter
    82lightfighter Well-Known Member
    Donald
    San Francisco
    09 AC TRD Sport 4x4
    So, I've been putting off replacing my antenna for a few years since is was damaged by a falling branch, and I found a stubby antenna that I liked, and thought this would be a fun, easy, and quick project.
    I found this thread and a video before I started on it, and I'm glad I did - had to cut off the original "antenna ornament" as it had fused with the base of antenna assembly... Picking up the replacement parts (antenna assembly, antenna nut, and "ornament") tomorrow, oh how I love removing the stupid plastic clips and rivets...
    PXL_20240610_204019500.jpg PXL_20240611_235804329.jpg PXL_20240612_003816717.jpg PXL_20240612_005846669.jpg
    srspicer and SR-71A like this.
  12. Jul 7, 2025 at 12:54 PM
    #172
    buck
    buck Don't sweat the petty - pet the sweaty
    Ontario, Canada
    15 DC V6 4x4 TRD Magnetic Gray
    High-flow coconut smiley-face air freshener.
    Replaced mine as well, thanks to the info in this thread. I had the corrosion stain on the fender and poor FM reception.
    I had to drill my base out. Be sure to tape around the area to save your paint in case of an oopsie. I first used a 3/8" bit, then 7/16". The corroded grommet finally broke loose of the base. I didn't need to remove the fender flare to get enough access. Just the mud flap and a portion of the fender liner. This is a good opportunity to clear out any dirt/leaves debris behind the fender liner. It's not too difficult, just take your time.
    Replacing the antenna base improved the FM reception. Success!
    All Done!
    ACEkraut and SR-71A like this.
  13. Jul 7, 2025 at 2:01 PM
    #173
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    OP.....I know this is a bit of an old thread but that was a pretty solid write up.
  14. Jul 8, 2025 at 6:31 AM
    #174
    Ory69
    Ory69 Member
    2007 Tacoma Sport Access Cab in Speedway Blue
    has the fancy Pioneer stereo - video thingy that I can't figure out
    Just thought I'd add a remedy here that I undertook, and am VERY glad I did. I installed a "shark fin" type antenna on the roof of my '07 Taco. It was NOT an easy job because of the headliner and all the attachments, (handles, hooks, sun visors, etc.).
    I opted for a 12 volt assisted one and the reception is incredible. Only cost a few bucks on Amazon.
    My only issue has been trying to find a nice looking piece (preferably contoured specifically) to cover the hole on the fender. I ended up using some scrap black plastic and dremeling it to look half way okay.
