how to replace rear O2 sensor on 2003 xtracab?
Discussion in 'Technical Chat' started by jmm2003, Aug 24, 2008.
  1. Aug 24, 2008 at 2:48 PM
    jmm2003
    jmm2003 [OP] New Member
    Northeast New York
    2003 Tacoma 2.7 4WD
    I have a P0136 error code with a readout of bank 1 sensor 2 sensor malfunction. I learned that this is the rear O2 sensor. I found the sensor under my truck, but the wiring runs from the exhaust pipe into a rubber gromet in the floor under the passenger seat. I want to replace the sensor myself but do not know where I should look for the connector. Do I need to remove the passenger seat to find the connector?
    Thanks,
    Jim.
  2. Aug 24, 2008 at 3:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Removeing the passenger seat is easy. The you would need to remove the door trim, and you should be able to reach it under the carpet from there. Its an easy thing to do. :)
    PS Welcome to TW!!!!
  3. Aug 24, 2008 at 4:28 PM
    jmm2003
    Northeast New York
    2003 Tacoma 2.7 4WD
    Thanks for sharing your know-how and thanks for the Welcome. I will order a sensor and give it a try.
  4. Feb 1, 2009 at 3:52 AM
    SNIPES
    SNIPES Well-Known Member
    NY
    04 Access Cab
    Did changing just the rear 02 solve the problem? I have been told this code may also be a faulty cat....:mad:
  5. Feb 1, 2009 at 4:46 AM
    dud122
    dud122 rabble rabble rabble
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    OME up front, Dakar in the back, Elite front bumper, Warn winch, Tactical rear bumper with tire swing/jerry cans/hi lift, Revenge Fab. sliders, Tundra brakes, Camburg UCA's, Safari Snorkle, FJ TRD wheels, Lights, CB, Switches, skids, LED's... OH MY!
    did you order that sensor yet??? I'm also in NY and have a NIB sensor i can give you a deal on.
  6. Feb 1, 2009 at 5:58 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
