How To: Replace Upper Ball Joint
Discussion in '1st Gen. Tacomas (1995-2004)' started by curtis998x2, May 29, 2016.
  1. Sep 14, 2022 at 9:32 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Yes, you can use pretty much anything to clean the knuckle before installing the new ball joint. I usually use brake cleaner. I also suggest applying a small (like the tiniest amount you can) dab of grease or anti seize to the knuckle bearing surface before pressing the new ball joint in.
  2. Sep 14, 2022 at 4:46 PM
    YotiLove
    YotiLove Member
    I must’ve sliced a small hole in the boot when I was struggling to get the c-clip on, because after I put it back together and greased the zerk - grease curled out of the back of the rubber boot!! My buddy said it’s such a small hole it’ll still hold up for a few years. What y’all think?
  3. Sep 14, 2022 at 4:51 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    You put the boot on before the c clip? That was backwards, but water under the bridge.
    Are you sure there is a hole in the boot, or did come from the top or bottom?
    If it's a small hole just get some rubber glue (shoe glue) and put a dab on there.
