How To: Replacing 2nd Gen Fog Light Switch Bulb
Discussion in '2nd Gen. Tacomas (2005-2015)' started by andlours, Jan 31, 2015.
  1. Nov 27, 2023 at 3:57 PM
    #161
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Yeah, it’s a skill but by no means difficult to master. Certainly not as intimidating as welding. For some of these switches a 3mm led doesn’t require any, you just have to jerrymander the two leads through and around the brown plug.
    Some aftermarket switches have smd leds(surface mounted device) and some have axial leads. Those don’t generally fail though and I only mess with them because OCD to match colors and brightness.
  2. Nov 27, 2023 at 10:43 PM
    #162
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    All you need is a t3 neowedge white led bulb. The only issue with some cheapo aftermarket bulb bases is the retention tabs that twist in to the switch suck. Usually I unbend the small wires of the aftermarket LED and swap the led over to the OEM bulb base after discarding the OEM bulb.
  3. Dec 20, 2023 at 6:14 AM
    #163
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Did that hook method end up working for you? I spent the better part of a few hours messing with fishing line trying to get that damn fog light switch out. No chance that was going to work for me. I have no idea how OP did it...
  4. Jan 19, 2024 at 1:45 PM
    #164
    SR-71A
    Zack
    Southern Maine
    Anyone else have any other ideas how I might pop the fog light switch out without tearing the whole dash apart? We are still limited on daylight here in the great white north, and that burnt out bulb has been bugging me lately
  5. Feb 7, 2024 at 2:39 AM
    #165
    Bachman10
    Bachman10 Active Member
    Thanks for posting this! None of my switches on that side are lit except for the rsca off switch
  6. Feb 7, 2024 at 4:45 PM
    #166
    bagleboy
    Scott
    Norcal, Santa Rosa
    If you can’t repeat the OP’s method you’re stuck. Toyota layered the panels in a way that forces you to do it a certain way to get up there. Door sill & dead pedal < kick panel< knee panel with lower switches. Still, it’s not all that big of a deal if you can work in a heated space, maybe 15 minutes tops to get the panels off and the switch out. The radio is more than twice as much crap to remove.
    Naveronski likes this.
  7. Feb 8, 2024 at 5:01 AM
    #167
    SR-71A
    Zack
    Southern Maine
    Thats my issue. No heated shop, and Maine is not exactly warm this time of year..
    The paper clip was not stout enough for me, but I hope to try something else once I get some free time
  8. Feb 8, 2024 at 11:00 AM
    #168
    SomeGuy_GRM
    SomeGuy_GRM Well-Known Member
    2009 Tacoma SR5 TRD Off Road
    You can pop the switch out with a two small screwdrivers.
    That's all I did to replace the whole switch with a two button unit. And I fished the new wires through only needing to pull the fuse cover off.
  9. Feb 8, 2024 at 11:08 AM
    #169
    bagleboy
    Scott
    Norcal, Santa Rosa
    If it’s that cold you also risk breaking the button. Definitely risk gouging both it and the panel. Wait until you can do it the right way or be prepared to endure any consequences.
  10. Feb 8, 2024 at 8:14 PM
    #170
    SomeGuy_GRM
    If it's that cold just let the truck run with the heat on for awhile.
  11. Feb 8, 2024 at 10:16 PM
    #171
    bagleboy
    Scott
    Norcal, Santa Rosa
    :thumbsup:
